Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 03-16-2012, 06:27 PM   #1
Qbanz
Member#: 120048
2008 STI
Default Problem reading ECU of 08 USDM STI
Hello all,
I recently purchased my08 STI and i am trying to at least read the ecu from it. i plan on doing some light bolt-ons so i need the access.. I used to have a my02 bug which i was able to read and write to ecu with my old 1.3 cable.. now i have purchased the OP 2.0 from tac trix and i am having a hell of a time trying to connect. always get the same error.
[13:10:46.296] EcuFlash Version 1.43.3150
[13:10:46.296] OS Version Windows XP
[13:10:46.296] Qt Version 4.6.2
[13:10:46.312] 62 memory models read.
[13:10:46.312] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[13:10:46.656] 354 ROM metadata models scanned.
[13:10:46.656] checksum module "subarudbw" loaded.
[13:10:46.656] checksum module "mitsucan" loaded.
[13:10:46.656] checksum module "mitsuh8" loaded.
[13:10:46.656] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:10:46.656] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:10:46.656] flashing tool "wrx02" loaded.
[13:10:46.656] flashing tool "wrx04" loaded.
[13:10:46.656] flashing tool "sti04" loaded.
[13:10:46.656] flashing tool "sti05" loaded.
[13:10:46.656] flashing tool "mitsukernel" loaded.
[13:10:46.656] flashing tool "mitsukernelocp" loaded.
[13:10:46.671] flashing tool "mitsubootloader" loaded.
[13:10:46.671] flashing tool "shbootmode" loaded.
[13:10:46.671] flashing tool "shaudmode" loaded.
[13:10:46.671] flashing tool "subarucan" loaded.
[13:10:46.671] flashing tool "mitsucan" loaded.
[13:10:53.500] J2534 API Version: 04.04
[13:10:53.500] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[13:10:53.500] Device Firmware Version: 1.11.3209
[13:10:53.500] Device Serial Number: TAzk6LOh
[13:11:02.000] kernel get version
[13:11:02.218] VIN : JF1GR89638L825492
[13:11:02.218] CVN : 369893B7
[13:11:02.218] SSM2 init
[13:11:02.265] SSM2 ECU ID is 5A12784107
[13:11:02.265] Requesting Seed...
[13:11:02.265] Sending Key...
[13:11:02.265] interface close
[13:11:02.281] interface close
I have updated the drivers to the Tactrix open port.. i have uninstalled and reinstalled both ecuflash and the drivers to the tactrix 2.0 dongle.. with the older drivers i can reset the ecu with romraider but still cannot read ecu.. I have tried searching thru all the forums but to no avail was not able to help.. I hope someone can assist me ..
thank you in advance and for your time
Rolando
Qbanz is offline   Reply With Quote
Old 03-16-2012, 10:21 PM   #2
quazimoto
Member#: 70395
Make sure you have the latest Ecuflash and latest definitions. 99% of the time it's user error. Manually tell Windows where the driver is. If you are using Vista or 7 run as admin.
Old 03-16-2012, 11:26 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
if this keeps happening, you may have a locked ecu, most likely a cobb ap
Nuke209 is online now   Reply With Quote
Old 03-17-2012, 09:37 AM   #4
Qbanz
Member#: 120048
2008 STI
I am running this on Windows XP.. i will do the complete uninstall and reinstall again when i get home..
This is what i hope is not the case... if I do have a locked ECU.. what would be my solutions.. purchase ECU ?? Is there a way to tell what locked the ecu either a Cobb which is most likely or a ECUtek ??
Old 03-17-2012, 10:12 AM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Does the car have any mods? (ones that were installed when you bought it)
Old 03-17-2012, 11:29 AM   #6
Qbanz
Member#: 120048
2008 STI
Yes there were... Invidia downpipe and a K&N Typhoon Intake....
its throwing me a P0420 cel due to the Catless downpipe... so my logic is if the ECu is locked with a Cobb or a ECUtek i wouldnt be getting the CEL right ??
Old 03-17-2012, 11:48 AM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
sounds like you have software and cable issues. I would suggest trying to downgrade your version of ECUflash to 1.42 and trying again.
Old 03-17-2012, 11:55 AM   #8
Qbanz
Member#: 120048
2008 STI
Thats what i am hoping it is... I dont know if its my timing but I have racked my brain and sweated my Arse off in the hot humid Miami weather.. LOL. but i will try again with a clean install
Old 03-17-2012, 12:09 PM   #9
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I do strongly suggest you get off the beta software though. Ive used 1.42.2595 on both XP and windows 7.
Old 03-17-2012, 12:48 PM   #10
Nuke209
Member#: 108089
2003 WRX
NF Performance
that shouldn't be the case
i'm using beta version and have no issues.
if you have op2.0 and ecuflash, it should read. if it doesn't and locks you out, well, you're locked.
Old 03-17-2012, 12:55 PM   #11
Qbanz
Member#: 120048
2008 STI
if the ECU is locked... is there any way to know who or what locked it ???
Old 03-17-2012, 01:15 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I'd rather switch my software back to an older and known good version, than go through the hassle of trying to figure out why my ECU is locked, and then potentially have to mail it out... etc etc etc.
troubleshooting... have you ever done it?
Old 03-17-2012, 02:08 PM   #13
Qbanz
Member#: 120048
2008 STI
thanks for your assistance gentlemen... i will continue to troubleshoot when i get home.... and post the update afterwards
Old 03-17-2012, 07:35 PM   #14
Qbanz
Member#: 120048
2008 STI
well and update..
i uninstalled and reinstalled 3 different versions of ecuexplorer and they all had the same results... I am believeing now that the ecu is locked...
now the mystery is who is it locked by... Cobb ??? or ECUTek... If it is locked by ECUTek can a ECUTek tuner remove the lock with my request ?? I read there was a way with the Cobb AP .. But i dont know anyone localy here in Miami that would help.. I guess i will post in the South East region and ask arouund...
thanks for all your help
Old 03-17-2012, 10:04 PM   #15
Nuke209
Member#: 108089
2003 WRX
NF Performance
I've been using beta version for over a year without any issues. if it's not letting you in, it's not letting you in lol.
you can sell the op and get an accessport and tune with that.
Old 03-18-2012, 08:18 AM   #16
Qbanz
Member#: 120048
2008 STI
Thats probably what i will do.. sucks cuz i already paid for a etune for the damm thing..
Old 06-14-2012, 03:31 PM   #17
CarverHouseRally
Member#: 315692
2005 WRX STi
What did you end up doing Qbanz? Mine is doing the same thing.
CarverHouseRally is offline   Reply With Quote
Old 06-14-2012, 05:03 PM   #18
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
i had this problem when i was using a laptop with vista, vista for some reason doesnt want to work with the newest update, once i switched to windows 7 it worked perfect
freddy121389 is offline   Reply With Quote
Old 06-15-2012, 10:52 AM   #19
CarverHouseRally
Member#: 315692
2005 WRX STi
I'm using windows 7 I will try another computer just in case.
Old 06-26-2012, 03:48 PM   #20
wgr73
Member#: 232458
2008 STi (OBP)
CAMTuning ftw
There's issues with Java too. Uninstall that and reinstall. Could be that
wgr73 is online now   Reply With Quote
Old 07-02-2012, 12:16 AM   #21
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
my car wouldn't hook up with the tactrix either. i heard it's because 08+ are canbus??? i don't know what that means but i heard that's the issue
michael_cano is offline   Reply With Quote
Old 07-02-2012, 09:54 AM   #22
quazimoto
Member#: 70395
The 2.0 Tactrix cable supports CAN-BUS cars. I highly suggest reading ALL OF THE FAQ'S on Romraider's site.
Problem reading ECU with ECUFLASH Subyroo2.5 Open Source Reflashes 3 02-10-2008 11:02 AM
Photos of 2007 USDM STi Intake Ports compared to v7 JDM STi Intake Ports... wow Wrinkleboi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 09-11-2007 01:09 PM
How would you describe the difference in handling of the USDM STi and the BMW 330i? Zoso General Community 4 01-04-2004 08:01 PM
In defense of the USDM STi. Siper2 New England Impreza Club Forum -- NESIC 23 08-23-2003 09:49 PM
Anyone know the price and p/n of the USDM STi seat pittkid333 Interior & Exterior Modification 16 05-23-2003 11:22 AM
