Old 12-26-2007, 01:56 AM   #26
poopy
Member#: 142286
is there a system i could turn off from within the car? with the new Si drive, i could say run WI in 1 mode and a non WI map in another mode. if a problem arrived, turn the system off from within the car and changes maps wi the Si drive. this is basically what i am looking for in a WI system.
thanx, mike
poopy is offline   Reply With Quote
Old 12-26-2007, 07:59 AM   #27
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Any of our kits that have our Smart Injection unit have the ability to turn on/off any device including a water injection kit. To switch MAPS if that is simply sending a 12V, Ground or 0-5V, our system can do that. We have 5 outputs that can be used for things like this.
Coolingmist is offline   Reply With Quote
Old 03-11-2008, 11:43 AM   #28
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
You forgot one big player in the meth injection scene that has a great standalone and utilizes a HSV: FJO Racing www.fjoracing.com
ktm is offline   Reply With Quote
Old 03-11-2008, 04:00 PM   #29
WReXd
Member#: 114101
93 Impreza L Swap
I apologize, I don't think I've heard of Fjo before. Looks like they have some pretty cool stuff. Their controller can do a lot, and their HSV is affordable. Original post is updated, with a question for Coolingmist (Look for red font).
WReXd is offline   Reply With Quote
Old 03-11-2008, 04:27 PM   #30
Coolingmist
Member#: 67024
2009 BMW 135 I
space grey
Originally Posted by WReXd View Post
EDIT: I'm not sure Coolingmist's hsv works the way I thought. After doing some reading, it seems to me like their valve may be a proportional valve (works sort of like a variable restrictor) instead of a high-speed on/off valve. Maybe Coolingmist will chime in.
You can run this valve several different ways, its easily one of the most flexible valves on the market.
Option #1 is you can PWM the valve with a fixed frequency, increased current=increased flow. You can think of this as dutycycle based. This is identical to they way most progressive controllers PWM a pump except the valve is much faster, hence high speed. The term high speed refers to the fact that it can change the flow rate, very, very fast with low hysterisis.
You can use a 0-5V. Your 0-5V signal MUST be able to produce 5 Watts at 5V. This can work using NO frequency at all. No PWM signal. 5 volts means it opens all the way, 0 volts=closed, the orifice opening will be relational to the voltage. This is a very fast way to work the valve and the valve will not buzz like a bumble bee. If your circuit cannot handle 5 W at 5 volts you need a driver board (we can supply them for you). This driver board will take your 0-5V signal and amplify it.
You can increase the ontime of the valve and run it dutycycle wise. for example.
at 1000 HZ you can run 5 volts for 1/2 ms, go to 0 for 1/2 ms to obtain 50% dutycycle.
Program your circuit for how you want it to work.
We have this working on a Haltech as low as 30 HZ. Its max frequency is 15,000 HZ
David
Old 03-12-2008, 03:04 PM   #31
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
They call it a water injection system, but the pump is 100% methanol compatible. I am running the HSV and pump on my 240z build and controlling it via PWM with my engine management system (Wolf V500).
Old 07-17-2008, 03:22 PM   #32
IvanWRX
Member#: 106107
2003 EJ207 STi
Rally blue
Hi, I'm using an AEM kit (trunk mounted) and I'm having horrible lag issues with it . I don't know if it is a controller or pump problem. Any thoughts? Thanks.
IvanWRX is offline   Reply With Quote
Old 07-18-2008, 12:21 AM   #33
WReXd
Member#: 114101
93 Impreza L Swap
By "lag issues," do you mean the pump takes too long to reach peak pressure? I don't understand.
Old 07-18-2008, 06:50 AM   #34
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Sticky this mods.
DonkeyPunch is offline   Reply With Quote
Old 07-06-2012, 06:33 AM   #35
enjoilife1991
Member#: 322400
03 WRX 360whp
i like. very informative
enjoilife1991 is offline   Reply With Quote
How to choose a Doctor (PCP) Philsdabom Off-Topic 14 10-13-2004 09:13 PM
Motor Gurus: How to choose a built motor? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-04-2003 06:39 PM
how to choose a uppipe/downpipe Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-21-2003 11:11 PM
How to choose winter wheels? midnight Newbies & FAQs 3 11-29-2001 05:49 PM
(FAQ) How to choose a high flow cat??? MPREZYA Technical Forum Archive 0 06-02-2000 10:50 PM
