Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 07-01-2012, 07:23 AM   #126
Ropes4u
Member#: 323526
Originally Posted by Strider
It'll carry kayaks with no problem. I'm carry a 75lb canoe on mine, although I don't use any specialized carrier.
Thank you!
Ropes4u is offline   Reply With Quote
Old 07-01-2012, 06:01 PM   #127
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by Coshmack View Post
so https://www.subaruonlineparts.com/pr...oducts_id=1437
Is my only option if I have a naked roof? Without doing something drastic.
I believe so. You can check your roof to make sure you have the openings for the rails on your roof
Old 07-02-2012, 01:56 PM   #128
Angelus911
Member#: 89967
2012 Impreza Sport
Originally Posted by Oddbaru View Post
Went with a local shop in Portland called ReRack. Rack Attack also sells them.
I don't think it's possible online, but maybe. Since I went with a shop, they were able to mix and match without any additional cost.
Just to confirm, those are the Whispbar Rails correct? They fit in between the factory rails and not on top right?
Old 07-02-2012, 03:19 PM   #129
vigil05
Member#: 322861
2012 Impreza Spt Ltd
Dark Grey Metallic
I've a question/s..
Would it make sense to purchase aerobars and get fairings? Aesthetics aside, are there any other benefits? Aerobars are pricier than the standard square/round load bars.
What differences are there between Yakima's Railgrab and Thule's Crossroads systems?
I have a Sport Limited with Moonroof - my first "real" car!
Thanks all!
vigil05 is offline   Reply With Quote
Old 07-02-2012, 03:42 PM   #130
Strider
Impeded.
Member#: 2197
an inconvenience,
properly considered.
The Yakima Railgrab uses round bars, and the mounts clamp to the crossbars independently to the clamp on the roof. When you remove the Yakima, the mounts stay firmly attached to the crossbars. The mounts themselves use a claw/tab that grips the factory rail.
The Thule Crossroad uses square bars, and tightens to the factory rail using a rubber coated metal strap. When you tighten the strap to the factory rail, it also clamps down on the crossbar, so when you remove the mount from the car, the mount slides free of the crossbar.
Strider is offline   Reply With Quote
Old 07-02-2012, 05:08 PM   #131
Oddbaru
Member#: 315869
2015 Crosstrek
Quartz Blue Pearl
Yes. The ones I have are just the rails. They are a bit more expensive than the OEM, but they really are quiet and I like the added deterrent of having them locked down since I've got some expensive items on there at times. I still would never leave it unattended for long though.
I feel like the S44 could work for both, since the measurements fall between what the distance between our rails are, but for whatever reason the shop felt the 43 and 45 were a better fit.
Oddbaru is offline   Reply With Quote
Old 07-03-2012, 01:19 AM   #132
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
If you get the Subaru Sport Aero bars, can you still use the Yakima kayak holders, for example, on them? I thought that the Yakima kayak holders would only fit on Yakima bars.
Did not realize the aero bars limited the options of what you could mount. That would explain why they're so cheap.
BigVoxjammer is offline   Reply With Quote
Old 07-03-2012, 01:29 AM   #133
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
Oddbaru, the next time you have your roof rack clear, could you snap a pic of how those whispbars look? I would like to see that.
Old 07-03-2012, 01:43 AM   #134
Coshmack
Member#: 324760
2012 Impreza Premium
So, a bit off topic. But I am drooling over the sport's roof rails but also looking at that roof spoiler/lip? It looks like a different one thats on my regular premium. Can I put that on my car? I saw it on the site I listed earlier that has my option for a rack. It looks awesome
Coshmack is offline   Reply With Quote
Old 07-03-2012, 05:23 PM   #135
vigil05
Member#: 322861
Dark Grey Metallic
Thanks for the info. Another question...
Lots of Yakima and Thule users here. Anybody using Inno bars? Orsdirect carries them as well and prices are pretty competitive. Thanks all.
Also what would be a reasonable length for crossbars (any brand) I don't want to have them extend too bar beyond the side roof of the car.
Old 07-03-2012, 11:47 PM   #136
ans2k
Member#: 315631
2012 Impreza Sport
I pulled the trigger on the oem aero bars and the yakima load warrior. the heavy duty oem cargo carrier has the exact same dimension and the yakima load warrior. except the yakima is cheaper.
Old 07-05-2012, 10:05 PM   #137
Angelus911
Member#: 89967
2012 Impreza Sport
Just ordered the S44 Whispbars, figured that they would fit good enough, they have about 36" - 40" of adjustability.
Old 07-06-2012, 04:11 PM   #138
ans2k
Member#: 315631
2012 Impreza Sport
Just ordered the load warrior off amazon. Holy crap!! Fast shipping, fast as amazon prime 2 day shipping and I bought it for 219 shipped to my door. Just sharing my experience. And it looks very sturdy. Now just waiting for my cross bars to come in.
Old 07-06-2012, 05:43 PM   #139
vigil05
Member#: 322861
Dark Grey Metallic
I think i'll pull the trigger and get the Inno roof racks. I'll post pictures (soon-ish).
Old 07-07-2012, 09:52 AM   #140
vigil05
Member#: 322861
Dark Grey Metallic
ooops. I realized i can't use a fairing if i got the inno racks. My sunroof will be blocked..
Any suggestions?
Old 07-07-2012, 04:07 PM   #141
ogle.benjamin
Member#: 325006
2012 Impreza Sport
Marine Blue Pearl
Any suggestions?
I don't know if it will work with an Inno rack system; but i got a Yakima Windjammer http://www.orsracksdirect.com/yakima-8001115.html for my Yakima roundbars/Railgrab system and it virtually eliminated the noise from the crossbars. I personally think it looks better than the fairing, you're not driving around with a big Yakima advertisement...a lot cheeper too.
ogle.benjamin is offline   Reply With Quote
Old 07-07-2012, 05:54 PM   #142
vigil05
Member#: 322861
Dark Grey Metallic
Yeah, that might be an option. Thanks for the info! I'll definitely look into that.
Old 07-07-2012, 08:15 PM   #143
archmikus
Member#: 323805
2012 Impreza Sport
Sage Green
I just received my Yakima Whispbar Rails from Rack Attack and can confirm the S54 fits perfectly.
archmikus is offline   Reply With Quote
Old 07-07-2012, 08:35 PM   #144
Angelus911
Member#: 89967
2012 Impreza Sport
The S54 or the S44?
Old 07-07-2012, 09:56 PM   #145
vigil05
Member#: 322861
Dark Grey Metallic
Care to post some pictures please? Thanks!
Old 07-08-2012, 02:14 AM   #146
jrands
Member#: 176522
2015 Crosstrek
ISM
To those of you with the roof spoiler, does it interfere at all with whatever racks you have? That is, can you open the truck all the way while you have your bike, or kayaks, etc...still on the rack(s)? Thanks, thinking of picking up the roof spoiler, but want to make sure that it won't interfere with the primary functionality of the car, its utility.
jrands is offline   Reply With Quote
Old 07-08-2012, 02:42 AM   #147
03Indigo
Member#: 87505
2012 WRX Hatch Black
2012 5door 2.0i red
Mine does not.....I have the Rockymounts rack, and even with my 29" wheel bike on it, factory base rack, not rails, there is no touching.
on a side note, here is one of my inno fairings...I have the same one, medium, on both cars. This one pictured is from the WRX, but it is the exact same fitment on the 2012 2.0i
03Indigo is offline   Reply With Quote
Old 07-08-2012, 02:53 AM   #148
vigil05
Member#: 322861
Dark Grey Metallic
Looks splendid. I have a sunroof. I don't think i can get a fairing and go crazy collecting stickers without reducing the usability of the sunroof.
Old 07-08-2012, 06:16 PM   #149
archmikus
Member#: 323805
2012 Impreza Sport
Sage Green
The S54 or the S44?
S54. The Whispbar Rail S44 has two identical bars that cover a span between 36-40 inches. The S54 has a rear bar that covers the same span, but the front bar covers a span of 38.5-42.5. I thought that would be more appropriate for the front rail span (which is 40").
I installed the bars as far forward and as far back as possible, which places each Whispbar about 33" apart. The Whispbars are super quiet when driving - I don't notice any difference in noise with or without them. Plus, they can be installed and removed in a matter of minutes. My only "complaint" is that the front bar hovers above the sunroof, but then again when they're loaded up with kayaks, there will be no reason to open the sunroof anyway!
Now, on to the pics. Didn't get a chance to really wash or clean up the car - I just snapped these 15 minutes ago. Here's my two-tone Sage Green Impreza with just 250 miles on her:
Got up on a ladder to snap a pic of the Whispbars from above:
Here's a close-up view of the front S54 Whispbar where it meets the roof rails. Protective cover removed so you can see the terminus of the rail (yellow oval). As you can see, the length of the aluminum extends almost all the way, which is a good thing. The shorter bar from the S44 might still work here, but because its not as long, it won't extend as far, thus possibly compromising support.
I'm going on a camping/kayaking trip next weekend, so I'll be sure to follow-up with some pics of the kayaks mounted on the Whispbars. Stay tuned.
Old 07-08-2012, 06:28 PM   #150
jrands
Member#: 176522
2015 Crosstrek
ISM
Thanks, appreciate it. Of course, you know what I'm going to ask now. Would you mind taking a pic with the trunk open while you have your 29er on top? Thanks. BTW, I love the wheels and lugs combo.
WTB : roof rack crossbars for 08+ impreza tnguye09 NWIC Private Classifieds 0 11-16-2011 12:51 PM
Roof rail options for a MY97 Impreza L wagon? Levvy Interior & Exterior Modification 1 08-21-2005 10:51 AM
Roof Rack Options for '03 mikebike357 Forester Forum 13 05-19-2003 10:01 AM
MY02 TS roof rack options AllWheelDrift Canada Region Forum 2 03-09-2002 09:31 PM
Roof rack question for those Impreza OBS owners SubyLova General Forum Archive 3 12-04-2000 10:23 PM
