07-06-2012, 04:52 PM | #3626 |
Member#: 284693
Vehicle:1999 Impreza 2.5 RS STM |
Need help diagnosing some stuttering/hesitating issue
Got a 99 RS with an ver 9 ej207. Only engine related mod is a walbro 255. 93 octane. The car seems like it isn't getting the normal power it used to get, and stutters a lot at full throttle and seems like the power slightly fluctuates while just generally cruising at ~40 mph (was running fine yesterday.) Feels like power cuts out randomly. No CEL. Same symptoms with and without a/c running. The only thing maybe out of the ordinary is that it's been hot around here lately (100* F when I just drove it a moment ago). I don't have that air intake trumpet that goes over the radiator (not sure what fits), so maybe the combo of all the hot air isn't helping? FWIW, the engine isn't overheating (running at about the 1/3-2/5 mark on the temp gauge). Kinda stumped--any thoughts?
07-06-2012, 05:07 PM | #3627 |
Member#: 86107
E. Canada
here goes the new build ! Found this lying around @ Subaru Canada's part depot. 300 $ lol !! Version 9 spec C double crossdrilled nitrided crank wtf I think a fan motor is more expensive |
07-06-2012, 07:02 PM | #3628 |
Member#: 174706
SCIC
Vehicle:2008 LGT-B DGM |
Nice find!
07-07-2012, 04:16 PM | #3629 |
Member#: 315635
Vehicle:04 STi Aspen White |
does running no cats trip a "check engine" light every now and then on the ej207? my car feels to be running great but the engine light keeps coming on and off, now it has came on and stayed for a a day , which is the longest yet.
07-07-2012, 04:41 PM | #3630 |
Member#: 131272
Vehicle:2003 WRX Wagon |
It can. Have you pulled the code to confirm what it is?
07-07-2012, 06:01 PM | #3631 |
Member#: 315635
not yet, been waiting to have my buddy plug his reader into it but its such an onn and off thing, hard to catch it with the engine light on while he's around.
do the codes store on the ecu after the CEL is off? |
07-07-2012, 09:42 PM | #3632 |
Member#: 284693
Need to get new spark plugs--what are the oem ones? If not oem, what's the most common? No mods other than walbro 255 lph.
I'm seeing NGK BKR7EIX a lot, but not sure if those are oem or not. Thanks |
07-07-2012, 10:11 PM | #3633 | |
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT 12.9@103MPH EJ205 4EAT |
07-08-2012, 05:09 AM | #3634 | ||
Member#: 255716
Vehicle:Itsa bugeye 04, V9 RHD and it makes me smile |
I learned alot from reading this thread and I appreciate everyones advice/knowledge. |
07-08-2012, 05:11 AM | #3635 | |
Member#: 255716
07-08-2012, 12:25 PM | #3636 |
Member#: 276065
South East
Vehicle:2002 207 wrb |
I clean it again and it went away as it did the first time. Its took about half an hour begore it came bavk. Ill see how long it last this time. I also still have my mine from my 205. I'm going to swap them if it comes bak again. It hasn't came back since you replaced it?
07-08-2012, 03:16 PM | #3637 |
Member#: 224785
Vehicle:2005 wrx-jdm207 i went black... |
dont forget you need a new gasket for it^ or it will leak like crazy and your car will hunt to find its idle
07-08-2012, 03:17 PM | #3638 |
Member#: 284693
07-08-2012, 03:21 PM | #3639 | |
Member#: 21339
HIIC
07-08-2012, 03:27 PM | #3640 | |
Member#: 287080
NGK 2667 is the same item but some places recognize that part number and not the other. |
07-08-2012, 04:34 PM | #3641 |
Member#: 284693
What should I be running in a stock engine then?
07-08-2012, 04:37 PM | #3642 | |
Member#: 287080
07-08-2012, 04:43 PM | #3643 |
Member#: 284693
Yep, tuning is no problem. Brother is good with romraider. Guess I'll go ahead and grab a pack of those then.
07-08-2012, 05:19 PM | #3644 |
Member#: 269361
Vehicle:2004 xt 03wrx Rallycar |
28 bucks on ebay with free next day shipping when i got my spark plugs should take a look
07-08-2012, 05:51 PM | #3645 | |
Member#: 255716
07-09-2012, 08:21 PM | #3646 |
Member#: 86107
E. Canada
anyone know the size of the oil pump a spec C V7 comes with ? Since the crank is different, should I change this ?
07-10-2012, 08:01 AM | #3647 |
Member#: 276065
South East
07-10-2012, 08:19 AM | #3648 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
07-10-2012, 08:56 AM | #3649 |
Member#: 131272
So I heard from a local tuner that my V7 engine is not much stronger than a standard USDM EJ257. And so now I'm confused because everything I've read says otherwise. Anyone able to shed some light here?
07-10-2012, 09:58 AM | #3650 |
Member#: 22605
Vehicle:2002 JDM STI/WRX WRB |
Never go back to that tuner, he has no idea what he is talking about
Similar Threads | ||||
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
