Old 07-10-2012, 06:51 PM   #151
Ksubi
Member#: 245510
'07 OBP WRX
ruined rally car
Ahh! Probably! I think there must be 4 or 5 silver hawkeye wagons around you guys. There's another slammed silver wagon with black wheels, but with red RA flaps.
Ksubi is offline   Reply With Quote
Old 07-10-2012, 07:07 PM   #152
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Comes in for new pictures... leaves disappointed! :-(
Old 07-11-2012, 10:02 AM   #153
DrnknZag
Member#: 138473
2007 WRXstealthwagon
6spd kindaflush
Blame Katelynn!
Need a new shoot soon, but I need to give her a good detail. I've been so busy working on the newly purchased house lately I haven't had a chance to do my spring detail yet (hello summer). I might be able to put a few hours to it this weekend and take some shots, but we'll see.
DrnknZag is offline   Reply With Quote
Old 07-11-2012, 03:21 PM   #154
Ksubi
Member#: 245510
'07 OBP WRX
ruined rally car
Sorry.
Just trying to up my post count, duh.
Old 07-11-2012, 03:34 PM   #155
DrnknZag
Member#: 138473
6spd kindaflush
Originally Posted by Ksubi
Sorry.
Me too!
Old 07-12-2012, 06:59 AM   #156
96accord
Member#: 145105
Damn n00bs trying to up their post count..
I don't need to do that.. ( look at my post count)
Old 07-12-2012, 10:55 AM   #157
DrnknZag
Member#: 138473
6spd kindaflush
If I'm gonna catch you, I gotta do everything I can, right?
Old 07-12-2012, 03:26 PM   #158
Ksubi
Member#: 245510
'07 OBP WRX
ruined rally car
exactly! How else are we supposed to catch up!
Now Joe, wash your damn car and post new pics so you can make the man happy!
Old 07-12-2012, 04:24 PM   #159
smallmat000
Member#: 302375
2011 Outback Sport
Camellia Red Metallic
i did a night photo shoot of my car right there. I am lovin your car
[/quote]
smallmat000 is offline   Reply With Quote
Old 07-12-2012, 06:15 PM   #160
96accord
Member#: 145105
Its called experience! And practice! lulz
Old 07-12-2012, 08:29 PM   #161
jvsoundwave
Member#: 66060
2007 STI Limited#534
Crystal Gray
Nice wagon!
jvsoundwave is offline   Reply With Quote
Old 07-12-2012, 10:10 PM   #162
slowguy
Member#: 4326
i'm not sure about you drnknzag, but i am anxiously awaiting shred season
slowguy is offline   Reply With Quote
Old 07-13-2012, 12:44 AM   #163
Etownwrx
Member#: 288003
Absolutely love your wagon, it has had much inspiration towards mine!
Etownwrx is offline   Reply With Quote
Old 07-13-2012, 03:38 PM   #164
96accord
Member#: 145105
You! Hush your mouth!!
Old 09-08-2012, 10:26 PM   #165
HLewis12
Member#: 25262
2006 LGT
BSM
I love your car. I have basically the same vehicle. Very similar power mods. I'm looking to do basically the same suspension mods but I have a few questions for you.
When switching to sedan lca's and lat links the extra length allows you to run sedan fitment struts without camber plates, correct? And if you continue with wagon struts you gain negative camber?
Also what are the advantages of going to sti lca's and lat links over wrx sedan?
I can't remember for sure which order you went with so this may not be relevant but did you ever use wagon axels with the conversion and if so did you have any issues?
Thanks in advance for your help.
HLewis12 is offline   Reply With Quote
Old 09-09-2012, 04:38 PM   #166
DrnknZag
Member#: 138473
6spd kindaflush
Thanks man!
Yes, with sedan or STi lat links and LCA's you'll be able to run sedan struts without losing the extra negative camber. And yes, if you keep the wagon struts, you'll gain even more negative camber. It's not much though, but a little bit.
Comparing the STi lat links and LCA's to a WRX sedan, the STi pieces are a bit wider than the WRX sedan. I don't remember by how much though. Plus the STi pieces are aluminum instead of steel (unless you get the LCA's from certain '06 WRX's).
There's a ton of threads that talk about whether or not you need to switch axles or not. Most threads say you'll be fine. A couple months after I did the swap, I ended up pulling a CV apart under full throttle. The retainer that keeps the CV from pulling apart broke. It's possible that the extra width caused the retainer to fail, but who knows. I ended up swapping in sedan rear axles after that and haven't had a problem. The front axles haven't been swapped and are still running strong.
Good luck with the swap!
Old 09-09-2012, 06:54 PM   #167
HLewis12
Member#: 25262
2006 LGT
BSM
Thanks for the help!
Old 04-04-2013, 03:11 AM   #168
Darth Wagon
Member#: 269713
2015 Forester XT
Originally Posted by DrnknZag View Post
Spring mode.
Awesome wheel/tire combo. I just picked up a set of 04 BBS wheels for my 07 wagon and am currently shopping tires. It looks like these are Goodyear Eagle F1s. Would you share what size they are? It looks like they're meaty enough to protect the wheel from curb rash.
Darth Wagon is offline   Reply With Quote
Old 04-04-2013, 09:49 AM   #169
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
They look like 225 or 235
awdorgtfo is offline   Reply With Quote
Old 04-04-2013, 10:30 AM   #170
DrnknZag
Member#: 138473
6spd kindaflush
Thanks man! They are 225. Can't fit anything bigger without rolling the rear fenders more.
Old 04-04-2013, 11:52 AM   #171
Darth Wagon
Member#: 269713
2015 Forester XT
Sweet! Thanks for the quick reply, I've been looking at 225s and theses look plenty wide enough for me. I'm on stock suspension for now but I'll be rolling the rears when I either put it on Swifts or go your route with the LCAs and lateral links.
Your car is such an inspiration, thanks for all the info in this thread and the calling all wagons thread.
Old 04-04-2013, 12:07 PM   #172
DrnknZag
Member#: 138473
6spd kindaflush
Without the STi LCAs and lay links, you could run 235's without rolling fenders, depending on your wheel offset and suspension setup. Possibility to rub on the inside though. I rubbed slightly on full lock on the front insides.
Thanks for the kind words, it means a lot! I don't get a lot of fanfare with my wagon because its not slammed and tucked or running huge power.
Old 04-05-2013, 08:25 PM   #173
DrnknZag
Member#: 138473
6spd kindaflush
Going through a few older pics and decided to reedit a few....
Spring is here....I'll spend a weekend detailing once snowboarding season is over, then it'll be photoshoot season. Didn't get any pics last summer, I'll make sure to get out there this year........
Old 04-07-2013, 10:23 AM   #174
Darth Wagon
Member#: 269713
2015 Forester XT
Looks good, I don't remember seeing that last one before. What are you shooting with?
Old 04-07-2013, 12:24 PM   #175
DrnknZag
Member#: 138473
6spd kindaflush
Those older shots are with a Nikon D40 and kit lens. I've since upgraded to a D90 kit lens. For being a budget camera, it takes decent pics as long as you kinda know what you're doing. A bit of editing magic always helps too.
See No Progress, Hear No Progress, Speak No Progress... rally_wannabe Political Playground 587 02-21-2010 01:44 AM
DrnknZag's Official SUPER Mad Props Thread (Fall '09 edition) DrnknZag North West Impreza Club Forum -- NWIC 23 10-02-2009 08:54 PM
DrnknZag's garage sale thread (car parts/snowboarding gear/baseball gear/other stuff) DrnknZag NWIC Private Classifieds 22 08-23-2009 09:09 PM
DrnknZag's Mad Props Thread DrnknZag North West Impreza Club Forum -- NWIC 30 04-21-2009 12:05 PM
Progress progresses progressively Janq Off-Topic 22 03-29-2006 02:53 AM
