Old 07-14-2012, 09:32 AM   #1
Mosting3
Member#: 296753
2005 V7 JDM STI swap
Default STI JDM Version 7 swap, Inverted NPS for a working AVCS?
Hello,
A Question:
I have a full Version 7 JDM STI swap (ECU, Harness, Engine, Transmission).
to let the AVCS work, i have heard that we need to invert the Neutral switch.
my current readings:
value = 1 @ neutral
Value = 0 @ gear
Is this right? read subaru fixed the issue on Ver.9,, can't really know.
Isn't inverting the NPS is right when having US transmission with JDM Engine?!
Thanks in advance.
Mosting3 is offline   Reply With Quote
Old 07-14-2012, 10:07 AM   #2
tintnsound
Member#: 301593
2002 WRX EJ207 V8
Version 7 will work with USDM 2004 STI 6mt NSS. They reversed in 2005/6 STI
tintnsound is offline   Reply With Quote
Old 07-14-2012, 10:10 AM   #3
tintnsound
Member#: 301593
2002 WRX EJ207 V8
2004 STI NSS is closed in gear - ground. Part number. 32008AA091
2005 STI and up is closed in neutral part number 32008AA160
Old 07-14-2012, 10:32 AM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
if you have the matching ecu and transmission you should be all set if the NSS is intact. Just add the AVCS wires.
Old 07-14-2012, 01:10 PM   #5
Mosting3
Member#: 296753
I think you misunderstood me, what am saying is that i have the Ver.7 JDM Transmission!so no need to install USDM one.
To let the AVCS work properly, shall i invert the functionality of the neutral switch?
Old 07-14-2012, 07:32 PM   #6
tintnsound
Member#: 301593
2002 WRX EJ207 V8
As long as you have the V7 ECM to match the V7 trans you will be fine. Double check the ECM and transmission part numbers. When I bought my V8 drivetrain they mistakenly gave me a V7 ECM So I had to change my NSS. If you have to change the NSS the part numbers above are the USDM part numbers that will work with the JDM trans.
Old 07-14-2012, 07:39 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Let's say I have a EJ207 v9 (and ecu) mated to a 05 USDM 6MT. Will i still need to change the NSS?
Old 07-14-2012, 08:33 PM   #8
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
No you should not they are both set as inverted, I have this combo.
Old 07-15-2012, 03:28 AM   #9
Mosting3
Member#: 296753
I think i might have this issue, my engine is EJ207DW4, which is 2002 Ver.7 and the ECU is 03 JDM STI, but i couldn't check the Transmission.
Old 07-15-2012, 10:32 AM   #10
tintnsound
Member#: 301593
2002 WRX EJ207 V8
I would physically check the NSS with a multimeter. If your drivetrain is already in the car, The NSS is on the top of the trans about 3/4 of the way back towards the shifter. The harness runs down the drivers side of the transmission, it is a two pin plug (I think it's white). If you have the right NSS it will be closed in gear and open in neutral. Hopefully you have the right one. It is a real PIA to change it,, but it can be done without completely removing the trans.
Old 07-15-2012, 10:36 AM   #11
tintnsound
Member#: 301593
2002 WRX EJ207 V8
2005 for both JDM and USDM seems to be the year the NSS inverted. I don't know for sure on the JDM 6mt maybe someone else could chime in on this.
Old 07-15-2012, 07:23 PM   #12
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
There is a little fuzziness as to when they switch things in Japan, seems to be a half a year earlier than in the US and sometimes happens at the end of the prior production year.
I am happy that I can just select the proper signal in the rom, just one checkbox.
Old 07-21-2012, 07:48 PM   #13
Mr.Bug_02
Member#: 296317
ok i have a similar question, i have a 2002 WRX with a v9 swap, i did wire the AVCS harness and i am running the 2003 v8 ecm... is my stock wrx 5 speed NSS correct? im using RomRaider when i'm in neutral it says 6 when in gear it says 1, but i noticed when logging if i'm in 2nd it says 3rd but then switches to 2nd when at WOT... this is bugging me to much
Mr.Bug_02 is offline   Reply With Quote
Old 07-21-2012, 11:16 PM   #14
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Copy your gear determination ratios over from your 5-speed WRX rom and put them into this table on the JDM rom
Old 07-22-2012, 01:25 AM   #15
Mosting3
Member#: 296753
Yeserday i have check my NPS logging using romraider logger, when doing WOT, i have noticed there is a chance that Neutral Position Switch = 1 while am on gear and therefor the AVCS wasn't working!
Old 07-23-2012, 11:47 AM   #16
Mr.Bug_02
Member#: 296317
i believe this is happening to me as well, mu car does not seem to pick up as well as everyone has told me it should
