Old 07-14-2012, 09:28 AM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default 1987 mid engine EG33... now with driving video
Introducing the Subercoupe
Started out live as a FWD 5 speed, SFI 1.8L N/A
Now with:
50% more Cylinders (H6 EG33)
100% more Rear Wheel Drive
100% more Subercharger (Eaton M90)
100% more tail pipes (dual Exhaust)
100% more body Kit (stock RX body kit)
100% more tuneability (standalone ECU)
1000X more awesomeness!!!
and the engine has been moved back about 10 feet...
Took it to the tuner yesterday. the clutch held up for 2 pulls to 4K, then started to slip big time... guess a stock EJ18 Clutch will not hold the torque of an EG33... looking for a new clutch... and trans...
First Startup:
Real Quick Dyno pull with clutch slip...
more pictures to come... I promise you that...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 07-14-2012, 10:10 AM   #2
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
That is a pretty insane set up you got there. More details would be nice like the engine set-up. Are you running a stock shortblock? That intake manifold looks pretty nice too, did you fab that up yourself to accommodate the supercharger?
What are your intentions for this car? I'm assuming it will be tracked judging by the cage! This thing will make one hell of a track car!
Details details details!!
Jessekrs123 is offline   Reply With Quote
Old 07-14-2012, 10:56 AM   #3
shark_22
Member#: 310794
2000 impreza eg33
subscribed
shark_22 is offline   Reply With Quote
Old 07-14-2012, 10:59 AM   #4
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
This makes me moist
Psychoreo is online now   Reply With Quote
Old 07-14-2012, 01:42 PM   #5
wrxhard
Member#: 108091
Flyin half mast right now. That is just fat titties on my dong.
wrxhard is offline   Reply With Quote
Old 07-14-2012, 09:18 PM   #6
suberdave
Member#: 101865
88 GL-10 STi
this is just a fun project car, i may take it to the track when its done, but the cage was more for a foundation for the "fire wall"
right now it is a stock EG33 long block that i bought from a junk yard.
and yes i made the manifold to accommodate the supercharger. not bad for some exhaust tubing and a cheep walmart flux core welder... and it has no leaks...
and as promised here are a few pics from the big northwest subaru show.
-=Suberdave=-
Old 07-15-2012, 11:49 AM   #7
05subysti
Member#: 268190
holy **** this is awesome!
05subysti is online now   Reply With Quote
Old 07-16-2012, 11:10 AM   #8
2DrunkenMonkeys
Member#: 312700
2002 WRX Waggy
PSM w/ funk-roof
^^ What he said.
2DrunkenMonkeys is offline   Reply With Quote
Old 07-16-2012, 03:40 PM   #9
3MI Racing
Member#: 200987
hahahaha that is awesome!! Thanks for sharing guys
Old 07-16-2012, 03:41 PM   #10
wrxsubaru
Member#: 65133
That's awesome. What engine management are you running? I have been out of the SVX scene for a while now so I am a little out of the loop.
wrxsubaru is offline   Reply With Quote
Old 07-16-2012, 04:22 PM   #11
wittmer25
Member#: 102970
2004 STi gt30r
Hey, what a fun/neat project! How did the link engine management work with the S/C eg33? Looks like you are running stock ignition too? Are you running stock crank sensor timing sprocket or did you add a different one? Are you running both crank sensors or just one? Looks like a lot of fun.
wittmer25 is offline   Reply With Quote
Old 07-17-2012, 12:12 AM   #12
suberdave
Member#: 101865
88 GL-10 STi
yeah i am running a Link G4 Extreme. it runs it with no issues as of yet.
i am running the stock crank sensor, but only using the 12 tooth gear and the cam gear. not using the other crank sensor at all.
i am using the stock coil packs. i could not find a SVX ignitor so i am using 3, 2 Channel Impreza ignitors. you can see them on the back of the intake manifold.
and yes so far it has been a whole lot of fun...
-=Suberdave=-
Old 07-17-2012, 12:32 AM   #13
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Respect! With a decent firewall it could be a daily driver
Marnix is offline   Reply With Quote
Old 07-17-2012, 12:36 AM   #14
eg33GC
Member#: 206851
99 V4
EJ20K RS
dave if you need an ignitor i have one you can have
Old 07-17-2012, 11:10 AM   #15
suberdave
Member#: 101865
88 GL-10 STi
it does have a decent firewall. i just need to get some mufflers on it and it will be a daily... i don't see any point in having a car that you can't drive to work every day...
thanks for the offer, but what i have now works awesome, and the wiring is already done for it. but if i have any issues, ill remember you...
-=Suberdave=-
Old 07-18-2012, 08:52 AM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
This is pretty awesome, do you have photos of the rear suspension and engine mounting?
Nice work!
Ben
PHATsuby is offline   Reply With Quote
Old 07-18-2012, 11:47 AM   #17
OddBallRacing
Member#: 136429
1996 ImprezaBrighton
Gawdawful Green
One gigga-billion more awesome!
OddBallRacing is offline   Reply With Quote
Old 07-18-2012, 03:16 PM   #18
JustinOlson
Member#: 102227
1977 280Z
Love it! Do you have more pictures of the rear floor pan and how you are supporting the motor? Are you using a front subframe from an impreza? What did you do to eliminate the steering rack?
JustinOlson is offline   Reply With Quote
Old 07-18-2012, 05:52 PM   #19
suberdave
Member#: 101865
88 GL-10 STi
i will get more pictures next week when i can get it back up on a rack.
as for the engine, it is sitting in a stock Impreza cross member. it has front lower control arms, and front steering knuckles, brakes and struts.
the steering rack is still in the rear. i pulled it. tightened down the lash adjustment, so it wont move, then welded the input shaft in place, so it cant move. i will be replacing it with a solid piece before to long.
-=Suberdave=-
Old 07-19-2012, 01:33 AM   #20
RallySport Direct
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Wow, this is insanely awesome! I just love stuff like this, great work and keep us updated!!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-21-2012, 07:21 PM   #21
LatentWagen
Member#: 50315
0508 Saabaru / specB
MBP / DGM
Insanity
How much did you have to tilt the motor?
LatentWagen is offline   Reply With Quote
Old 07-21-2012, 07:42 PM   #22
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
Eligh was telling me about this (I had to work, so no BNW for me) I just assumed he was drunk
****ing sick, can't wait to see it in person!
Old 07-23-2012, 10:46 PM   #23
D3F0
Member#: 265799
1995 Impreza L AWD
WHITE BEDLINER
WOW YES! I have two eg33s I am supercharging too nice build!
D3F0 is offline   Reply With Quote
Old 07-24-2012, 04:14 PM   #24
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Wow, that's just awesome!
BeBop86 is offline   Reply With Quote
Old 07-26-2012, 01:32 PM   #25
BMG905
Member#: 151533
2006 Legacy GT LTD
Regal Blue Pearl
Thinking about taking it on the ferry to Bainbridge or Vashon? Might wake up the locals and give the guys at the ferry terminal something to talk about.
BMG905 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 08:59 PM.
