Old 07-10-2012, 08:36 PM   #1
petrakov08
Member#: 217146
1998 Impreza RS
Default Sti heagaskets on N/A EJ25 torque specs?
I'm putting together a 2.5 phase II block with phase I heads, from the research I've done 04-05 Sti headgaskets can be used for higher compression. What torque specs should I use since the gaskets are thinner and I'm putting DOHC heads on a SOHC block?
petrakov08 is offline   Reply With Quote
Old 07-11-2012, 12:28 AM   #2
alt14
Member#: 271928
2007 Impreza 2.5i SE
I'd go with the specs from the block itself otherwise you might over tighten them
alt14 is offline   Reply With Quote
Old 07-13-2012, 08:20 PM   #3
geronimo81
Member#: 154586
1996 ej22 Outback
Torque sequence/spec needs to match the heads. I hope this helps. Also need the DOHC head bolts as they are longer.
geronimo81 is offline   Reply With Quote
Old 07-16-2012, 08:38 PM   #4
petrakov08
Member#: 217146
1998 Impreza RS
Anyone else have an opinion? Am I matching block or head torque specs?
Old 07-16-2012, 09:23 PM   #5
jamal
Member#: 71875
98 2.5GT
my wheels fit
Heads. Same sequence for all DOHC cars. You may want to double check piston to head and piston to valve clearances with the thinner HGs though. I was under the impression you have to use the thicker phase 1 gaskets.
jamal is online now   Reply With Quote
Old 07-17-2012, 03:22 PM   #6
petrakov08
Member#: 217146
1998 Impreza RS
Gotcha, the sequence in which you tighten the head bolts is the same but what about the actual torque specs on each bolt? Does anyone have any opinion on the valve clearance? From what I've read there aren't issues with the thinner gaskets.
Old 07-17-2012, 04:09 PM   #7
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
my thread:
http://forums.nasioc.com/forums/show...ght=headgasket
no issues with valve clearance
Old 07-24-2012, 09:14 PM   #8
petrakov08
Member#: 217146
1998 Impreza RS
Originally Posted by AliBenn View Post
my thread:
Thank you.
Can anyone confirm the torque specs I've found?
(That's DOHC heads on a SOHC block with EJ257 Sti Gaskets)
Torque to 22ftlbs
Then to 51
Loosen 180*
Loosen 180*
Torque 1-2 to 25
3-6 to 11
Tighten 80-90*
Tighten 80-90*
Message Board Statistics All times are GMT -4. The time now is 10:57 PM.
