Old 07-18-2012, 06:03 PM   #26
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Well I've been driving the car fixed couple boost leaks. throttle body gasket. Just ditched the down pipe gasket junk.
Hopefully I can drive it and get the o2 sensor ready and the evap isn't ready I'm over due for inspection. I did delete the evap solenoid when I had the hydra.
I Put 400 miles on the car this post weekend. The motor is great no smoking on start up or at all catch can hardly has anything in it. Tony did a great job.
I already have my spare block ready for him to do if possible.
Besides that if anyone has any input on getting it ready for inspection that would be helpful. the o2 sensors are original but where removed for the two years the hydra was in the car.
They seem to be moving normally while driving. I'm hoping it was just because my coupler leak, throttle body gasket, and down pipe gasket that caused those systems not to ready at least the o2 sensor the heater is ready.
spoolinsti05 is online now   Reply With Quote
Old 07-18-2012, 10:45 PM   #27
lee586
Member#: 212926
97 Wrx
what headstuds you running?
lee586 is offline   Reply With Quote
Old 07-19-2012, 04:03 PM   #28
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Basic arp2000 block is o-ringed.
Old 10-06-2012, 12:55 PM   #29
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Well car's been re tuned since on 24psi it pulls good and run's good pretty smooth considering everything that's been done. I've got about 2500 miles on it. about 4 4 hour round trip's total. with no issues with anything.
just got one small problem still won't pass emissions no cel on o2 monitor not ready or evap system.
Evap is probably from not having my evap solenoid in.
o2 is ether the ultimate racing down pipe? or my rear o2 sensor is responding slow witch is what I'm seeing when logging the voltage. and I've had the po139 code about 4 times before my re tune.
but again I found a small fuel leak after the tune on the return line from the fpr and a small vac leak on the adjuster for the afpr. so I fixed those now the car rev's above 6500 rpm's it wouldn't while getting my re tune. but it goes rich under boost and lean above 6500rpm's so I'm guessing I need a re tune again.
hopeing jr can fit me in. But I'm stumped as if the evap and o2 are even the issues for my emissions troubles or if it's just the tune off again after i fixed my last two issues.
oh an she smokes sometime on initial start's not all the time. we think it may be there valve stem seals as they are stock granted the low mileage on my car. Could even be the ring's honestly maybe they didn't seal fully from all that fuel she was dumping at first.
Doesn't matter right now will fix that another time. Basically I'm just working on getting it passed threw emissions so we can put the aem in and go for kill motors gotta come back out anyways.
Old 10-09-2012, 02:21 AM   #30
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
so I took my wastegate off and found a tear in the diaphragm. ordering a new one hopefully that'll solve any recent issue's.
update: took it off again and put pressure on the diaphragm not leaking. I put some silicone on the little slit just to see what I get. I recently noticed a slight flutter with the wastegate an that the body of it would spin. so when i had it off noticed the nut under the diaphragm loosened the set screw tightened the big nut and now the body of the gate is actually locked in place. seem's like it just loosened up with use.
Old 11-26-2012, 10:45 PM   #31
subarufan555
Member#: 255117
2000 RS
RED
Any updates?Nice build
subarufan555 is offline   Reply With Quote
Old 11-27-2012, 03:28 AM   #32
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
3k miles daily driving it stays cool in traffic granted I avoid it when possible. Just trying to figure out is we can get these ID2000 ready on pump 93 for inspection witch they should as the AFR don't matter here in NY. Will see I suppose I fixed a lot of problems car had. Just down to bigger pump and better lines and fittings.
Then going back to put it on the dyno with pump then E85 still also debating on stock ecu or aem v2. And thanks she's a work in progress and under construction gonna plasti dip the car this winter.
Old 11-27-2012, 03:51 AM   #33
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I am jealous! Building a similar engine but no e85 here
aboothman is offline   Reply With Quote
Old 11-27-2012, 10:13 AM   #34
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Don't be jellin man. I'm sure your car will be fun also. I'm debating on pump E85 or the canned goods! I don't like the octane instability in the pump E85 can't test that using a ethanol content tube. Time will tell the tale my friend.
Old 11-27-2012, 06:27 PM   #35
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
Very nice!! Im going to be running something similiar, definitely in for moar! Ive had the whole 93 VS e85 running around in my mind and i really want to play with e85. Is E85 at the pump inconsistent, like you might get a bad tank?
KillerRabbit is offline   Reply With Quote
Old 11-27-2012, 06:56 PM   #36
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I personally after reading a lot about e85 wouldn't use it at the pump unless you have.
1. Tuning capabilities.
2. An AEM Infinity with a Ethanol Analyzer.(or similar EMS like a Vipec)
If you have non of the above and want safety on a daily just buy E85 from VP or one of the other fuel manufactures. Granted some have luck really depends on how lean your tune is. You may be able to test the content of alcohol but you can't test the octane the tool's required just aren't cheap at all.
Old 11-27-2012, 08:22 PM   #37
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
so nice!envy you!
EROCS04SBRUSTI is offline   Reply With Quote
Old 11-28-2012, 02:02 AM   #38
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by EROCS04SBRUSTI View Post
so nice!envy you!
Lol thank you sir.
Old 12-07-2012, 02:07 PM   #39
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
What valves are you using?
Old 12-07-2012, 10:54 PM   #40
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
OEM at this moment.
Old 02-14-2014, 08:43 AM   #41
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Just wanted to update you guys on this. The car spun a bearing #3 iirc. It's got a new crank and bearings this time around I went with .001 Etta oil clearance.
Tony used STD size acl. "Manley I beams" the .001 netted me .017 clearance. So from what I can see STD bearings on these rods are TO TIGHT... But I should also mention I had missed a shift. My idea of cutting/welding my shifter probably gave me that outcome. I later found out that you need to add materiel to the lower section of the shifter doe.
Also when doing the rebuild in my home garage I figured what the heck might as well go the extra mile on my exhaust ports. Since last time I kept the porting to a minimal on the dog legs and bowl areas.
Well I found the thin area on the inside turn of the dog leg port right on the divider. And it started thin then I started poking it and it caved in like the sink hole that swallowed the corvettes.
I'm now using v25b heads as I got a good deal on them and they showed no signs of burnt oil. I did clean them up good but don't think I'll be porting these. I'm actually thinking of keeping the stock 07 cams in also. They are so lite!
Old 02-15-2014, 08:10 PM   #42
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Wanted to give another update upon further visual inspection one of the valves are bent on these v25b heads. So I broke out my dial indicator and a wooden v block I made. I'm not one for wasting metal lol.
The runout showed all the intake valves to e out of spec. I still need to break down the other cylinder head. The good thing is the exhaust valves showed zero runout. So I'll be lapping in the valves from my other b25 heads or buying new still unsure will see.
Old 02-16-2014, 01:15 PM   #43
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Yup I have experienced the cave in on the exhaust ports. But mine where on my Cos worth heads. They blew out the first pass. I personally like to see just a cleanup on the exhaust side
02WRX2.5 is offline   Reply With Quote
Old 02-17-2014, 09:41 AM   #44
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Well I found the spots I can and can't dig deep on the b25 heads problem is my new heads are v25b and I don't have the funds to find the weak spot on these.
But I am looking at getting some d25 heads that are missing a avcs cam cap an possibly running my b25 can cap on if not I'll hit the choice spots where I feel flow can be drastically increased and hit those spots.
My b25 heads I was able to take so much meat off I. The dog leg port that it nearly had no turn! I wish I stayed sways from that divider they'd still be in commission. I'm going to see about having it welded. But once I do that coolant flow in that area will be deterred.
Old 02-17-2014, 09:47 AM   #45
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Wow really cosworth heads? Ouch that's a hearty price tag. I have a really good competent welder by me if you want to try and salvage them i can put you in contact with him.
He's going to see about fixing mine when I get them off the car. I'm good on freezing lol only take me a few hours anyways so I'll wait till spring. Plus they will be for back up or sale.
I actually prefer doing exhaust porting over intake on boosted cars. Depending on turbo and exhaust system really.
Old 02-17-2014, 10:24 AM   #46
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Just cleaning up the short side radius and opening up the throat size on the seat to the correct ratio for the valves will account for a great increase in flow. On the exhaust side, I usually just smooth the short side, minor reshape of the short side and bowl, radius valve job, and sand the rest of the port mostly just to clean up the old carbon. On the intakes, depending on how much time I have all that is really needed is an 80* bowl hog, and then a sanding roll to blend the pocket. But I usually end up making it look pretty because I am OCD lol.
Crystal_Imprezav is offline   Reply With Quote
Old 02-17-2014, 11:07 AM   #47
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Any pics of these cave in's?
Old 02-17-2014, 12:01 PM   #48
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Ah I cleaned my heads up nicely with wire brush and carb cleaner. I'm trying something new which is just a polish technically. But not using sanding rolls you'll see stick around.
When the heads come off ill post pics of my crater lol
FS/FT : CA: Darton sleeved built ej257 blkwagon Engine/Power/Exhaust 12 06-11-2011 06:26 PM
ej257 pinned sleeves GoofyLGT Built Motor Discussion 51 03-19-2011 04:40 PM
EJ257 Darton dry sleeve engine break-in procedure mtcs Built Motor Discussion 3 08-07-2010 09:59 AM
FS: Built EJ257 shortblock! 99.5 CP Pistons, Eagle Rods, ACL Main and Rod Bearings 06TRDude Engine/Power/Exhaust 12 12-22-2009 09:24 PM
04 sti ej257, darton sleeves, 03 ej20 suby1man03 Engine/Power/Exhaust 26 11-26-2009 06:07 PM
