Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 07-10-2012, 08:09 PM   #76
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
The nipple furthest from the electrical plug goes directly to the intake manifold. The other nipple goes to the metal line under the intake manifold that ultimately goes to the firewall and all the way back to the tank area.
Stephen
IA Performance is offline   Reply With Quote
Old 07-11-2012, 04:50 PM   #77
scootarida1
Member#: 154534
2017 Forester 2.0XT
Okay I think that might be the problem if I understand correctly. Here is how I had it hooked up and was getting the cel.
SO your saying to hook it up like this then?
scootarida1 is offline   Reply With Quote
Old 07-11-2012, 05:19 PM   #78
IA Performance
Member#: 25194
Dark Gray
2nd way is correct. Did you fabricate coolant tank or was it a moroso universal?
Old 07-11-2012, 05:25 PM   #79
scootarida1
Member#: 154534
2017 Forester 2.0XT
alright thanks and i fabricated it to for where i located the turbo
Old 07-18-2012, 03:15 PM   #80
Keif
Member#: 107302
I think there's a bit of confusion about what nipple on the solenoid goes to what. Maybe it's different on cars.
This is how my MY06 WRX is setup.
Originally Posted by jdeyo6 View Post
Here is how my car is setup from the factory.
The bottom nipple feeds to the T-fitting, evap pipe and purge valve and the top nipple feeds directly and only to the intake manifold.
I'm guessing I should keep this configuration when I do the delete?
___
Man, I'm glad I came across this thread. My purge valve is dry rotted and the local dealer gets $50 for them! SubaruGenuineParts gets $27.
Keif is offline   Reply With Quote
Old 07-18-2012, 04:18 PM   #81
05subysti
Member#: 268190
2005 STi
I'm missing my purge valve solenoid. Would this cause my car to pump gas really slow? I'm thinking I need to fix it.
05subysti is offline   Reply With Quote
Old 07-18-2012, 08:43 PM   #82
TurboQueef
Member#: 86700
2005 STI
Silver/Black,[email protected]
My 05 was same as yours..
___
TurboQueef is offline   Reply With Quote
Old 07-18-2012, 11:27 PM   #83
Keif
Member#: 107302
I noticed there's a directional arrow on the solenoid and there's a diagram on the hood for the purge system, if anyone gets confused.
__
I was able to get it sorted today. I was hoping to find a bolt for the nipple on the manifold but had no luck. I even tried a big industrial fastener place.
The thread pitch is 0.90mm and I believe the diameter is 8mm? Might be able to get it online.
But Autozone had some nice nipple caps.
Good stuff. Happy to clean up the engine bay a bit and remove something that could cause issues.
Old 07-20-2012, 11:15 PM   #84
scootarida1
Member#: 154534
2017 Forester 2.0XT
__
I believe the thread pitch is 1/8 NPT thread. Also how did you route the hoses based on the arrow?
Old 07-22-2012, 12:00 AM   #85
scootarida1
Member#: 154534
2017 Forester 2.0XT
are you sure? in your pictures the stock setup has the nipple closest to the plug going to the manifold and the nipple furthest away going under the manifold.
why would they be switched when deleting everything?
Old 07-22-2012, 12:51 AM   #86
Keif
Member#: 107302
I actually have a thread measuring tool, it's 0.90mm.
The flow is from the evap pipe to the intake manifold/purge valve. So evap pipe goes to the nipple with the arrow.
That is the post that was confusing me too. I don't see any reason for swapping them so maybe he just made a mistake.
__
So I ran this "re-routing" by Matt at 555 Motor Sports (he's my tuner) and he suggested to remove the solenoid all together and vent the evap pipe to atmosphere. He said there are start up issues when routed like the JDM cars.
Old 07-22-2012, 01:48 AM   #87
Keif
Member#: 107302
Actually, you may be right. Wiki says 1/8 NPT thread pitch is 0.94mm. It did look like it was tapered too.
Old 07-22-2012, 11:22 AM   #88
scootarida1
Member#: 154534
2017 Forester 2.0XT
Yah I used a 1/8 NPT plug and it seems to be working fine. So did you just add some extra hose so it reached under the car with it vented?
Old 07-22-2012, 03:53 PM   #89
Keif
Member#: 107302
Cool, I'll try that.
Well it's just vapor. The only problem I could see, if you don't run a hose underneath, is maybe some fuel smell in the cabin. I just sent Matt an email about that. I'll let you know what he says.
Old 07-22-2012, 06:10 PM   #90
scootarida1
Member#: 154534
2017 Forester 2.0XT
Sounds good. I'm sure a CEL will be thrown without the solenoid but that wouldn't be difficult to turn off.
Old 07-22-2012, 08:29 PM   #91
Keif
Member#: 107302
Ok, Matt said he doesn't get any fuel odors with his car and that it will cause a CEL but it can be disabled.
Old 07-23-2012, 09:33 AM   #92
3k1n
Member#: 83043
05 sti
Does anyone have the part number to that black connector thats circled in the pictures? I snapped mines yesterday and need the a replacement one. Couldn't find anything close to matching at the local parts store, so will need to purchase it directly from Subaru...
3k1n is offline   Reply With Quote
Old 07-24-2012, 07:22 PM   #93
scootarida1
Member#: 154534
2017 Forester 2.0XT
I can't remember if that is straight through or not but maybe lowes or homedepot will have them in the plumbing section
Old 07-24-2012, 10:50 PM   #94
Keif
Member#: 107302
You can find the part number here
http://opposedforces.com/
Old 08-06-2012, 11:03 AM   #95
jayblizzo
Member#: 58957
2010 WRX STI
SSM
Here is another option, it is free and avoids the hassle of the hoses coming off in the future. This is how the JDM ver7/8 STi cars are setup. We have lots of customer cars running this configuration without any CELs or negative side affects.
will it work if you delete the solenoid and just leave the evap line to vent to atmosphere?
jayblizzo is offline   Reply With Quote
Old 08-06-2012, 07:44 PM   #96
scootarida1
Member#: 154534
2017 Forester 2.0XT
I think that is what Keif said his tuner did. Im sure you will throw a Cel by doing that but you can probably just turn it off
Old 08-13-2012, 07:04 PM   #97
dalesti
Member#: 72636
2005 WRX STi
This is the part number for the new hose assembly with the black plastic connector you are looking for. It's not that much to replace all the hoses and connectors
dalesti is offline   Reply With Quote
Old 08-13-2012, 07:09 PM   #98
dalesti
Member#: 72636
2005 WRX STi
Stephen
Mine was hooked up with the nipple closest to the plug going to the Manifold, I showed it in my pictures. Not sure why it's the opposite on others but mine is an 05 STI
Old 08-21-2012, 05:01 PM   #99
808_wrx
Member#: 256205
i broke the nipple closer to the plug side. what do i do about removing this setup an plugging lines. just connect outer nipple to intake manifold right an can i just leave the broken one vent
808_wrx is offline   Reply With Quote
Old 08-21-2012, 09:24 PM   #100
IA Performance
Member#: 25194
Dark Gray
808_wrx - my advise is to fix it properly with a new/used unit. It's simple, pay for your mistake and move on.
If you have zero dollars then remove the solenoid and try to JB weld it in place, but I can guarantee it will break over time. Leaving anything open to vent to atmosphere will harm the motor and kill your HP and most certainly result in a CEL.
Stephen
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 09:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 06:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 08:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 05:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 05:36 AM
