#1 |
Member#: 320500
TXIC
Vehicle:2004 Subaru Wrx silver |
i currently have a spun bearing in my ej205 04 subaru and i recently bought an ej255 06 new short block! i was wondering if everything interchanges?
i appreciate any insight thanks! ![]()
#2 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
Why would you purchase a new block, THEN after you buy it..... as this question??!!
hope you did youre homework on hybrid swaps...... if not youre in trouble. Last edited by UK-Wagon; 07-04-2012 at 04:37 AM. |
#3 |
Member#: 320500
TXIC
it is a turbo ej255 short block and did some home work says everything should bolt up
i just was wondering if there was anything else i should know about this type of build |
#4 |
Member#: 149806
The cr ratio is gunna b high so u should cnc the heads to make things work, also thicker gasket, other than that ur all set . O ye theres that thing called tuning ur gunna need
#5 |
Member#: 320500
TXIC
oem ej257 head gaskets good? im sort of new to this hybrid setup
im gonna port match the heads. i may have to change pistons to get the right compression some say cnc? |
#6 |
Member#: 320500
TXIC
#7 |
Member#: 305392
NESIC
Vehicle:2002 WRX Wagon Aspen White |
I used sti headgaskets and just cleaned up my heads. You don't need a cnc unless you want crazy boost and timing. My tuner preferred the bump in compression for off boost torque and said my setup would love e85. Just my experience.
#8 |
Member#: 320500
TXIC
every time i read most of these threads i never see the ej255/ej205 hybrid build
its always the ej257/ej20 i appreciate any and all info thanks |
#9 |
Member#: 320500
TXIC
oh yeah whats cnc?
#10 | ||
Member#: 305392
NESIC
#11 |
Member#: 320500
TXIC
thanks that helps out alot
#12 |
Member#: 320500
TXIC
should i run my stock injectors or after market?
#13 | |
Member#: 305392
NESIC
#14 |
Member#: 320500
TXIC
well at the moment ive just been trying to get all my parts ahead before i even start the build i want to make sure i have everything i need i hate searching for parts. i think it will be a great experience and allow me to learn more about these Subaru engines
thinking about rc 1000cc injectors arp head studs port the heads i currently have a stock turbo perrin manual boost controller- i dont think i shoud use it though i have a godspeed 3" turbo back to a 4" outlet thought about electronic cut out a competition stage 2 Kevlar racing clutch injen cold air intake hks turbo timer greddy rs bov cobb acess port good tuning any other insight on what i may also need? |
#15 |
Member#: 296748
Vehicle:2005 WRX |
A bigger than stock fuel pump will be required.
#16 |
Member#: 320500
TXIC
bumpski
#17 |
Member#: 328402
I have 2004 WRX and currently running 06 EJ25 in it. EVERYTHING will bolt up the same way.
Few things to consider: EJ25 heads have AVCS setup and 2 cam positioning sensors, one on the back of each intake cam. EJ20 has one cam sensor in front of driver side intake sprocket. You need to modify your EJ25 head to use EJ20 sensor http://elementtuning.com/technical/ej25_install.htm 06 uses electronic throttle body so you'll need to reuse your intake manifold You can use your existing wiring harness and ECU as long as you make cam sensor mod. Otherwise you'll have to buy 06 ECU with complete harness and immobilizer. I have no issues with mine running it with completely stock 05 ECU. Yes, you'll need to tune it for larger displacement but its pretty safe as it is. Let me know if you have other questions, I just finished messing with mine a few days ago |
#18 | |
Member#: 320500
TXIC
#19 |
Member#: 320500
TXIC
i keep you posted
#20 |
Member#: 320500
TXIC
what year and size sti head gasket should i use 1.5 1.3 ?
#21 |
Member#: 320500
TXIC
.020 .030 .040 .050 .060?
#22 |
Member#: 320500
TXIC
any who
#23 |
Member#: 320500
TXIC
help!!
#24 |
Member#: 287974
I'm doing a hybrid build also and y tuner recommended the .051 cometics just to lower my compression a little bit since I'm using 8.9.1 pistons in my build but I would just contact your tuner and see what would be easier and better for him
#25 |
Member#: 265783
RMIC
Vehicle:2008 wrx wr blue |
