Old 07-23-2012, 06:36 PM   #26
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Here's my analysis after first oil change at 4,025 miles, and no more gentle than recommended break-in.
Element Actual PPM / Typical PPM
Aluminum 5/2
Chromium 0/1
Iron 24/7
Copper 152/5
Lead 1/5
Tin 4/1
Molybdenum 927/53
Nickel 1/0
Manganese 10/4
Silver 0/0
Titanium 0/0
Potassium 3/1
Boron 163/44
Silicon 306/10
Sodium 8/15
Calcium 1783/2187
Magnesium 11/266
Phosphorus 784/771
Zinc 905/937
Barium 6/0
Result / Should Be
SUS Viscosity @ 210F: 48.6/46-56
cSt Viscosity @ 100C: 6.84/6.0-9.4
Flashpoint 405F/>385F
Fuel % <0.5/<2.0
Antifreeze % 0/0
Water % 0/<0.1
Insolubles % 0.2/<0.6
Comments: High wear and silicon are common finds in new engines, such as your new Impreza. The excess wear metals are from new parts breaking-in while silicon is from sand-casted parts and sealers used when assembling your engine. Both should improve with subsequent oil changes. Universal averages for this type of engine are based on an oil run of ~4,200 miles. With a few more oil changes your wear should read at or below universal averages. Subaru makes nice engines, so this should be a good one for you. No contaminants or problems found.
Haunty is offline   Reply With Quote
Old 07-23-2012, 07:51 PM   #27
finklejag
Member#: 318622
2012 Impreza
Thanks for the UOA. It looks like the Viscosity gets beat up a little on the FF on our Imprezas.
finklejag is offline   Reply With Quote
Old 07-23-2012, 08:55 PM   #28
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
What do you mean by "on the FF"?
Old 07-24-2012, 09:44 AM   #29
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Factory fill.
Old 07-24-2012, 10:01 AM   #30
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Originally Posted by Commander Keen View Post
Factory fill.
Thanks.
Since the UOA report doesn't provide "Actual/Typical" data with regard to the Viscosity numbers, how do you know that the viscosity takes a beating on the factory fill oil? I don't understand the viscosity numbers well enough to understand how you determined this.
Regardless, I did my first oil change at two days ago 1700 miles, using Amsoil OE 0W20 and a Subaru oil filter (the correct "160" P/N filter). I also installed a Fumoto valve.
Oh, and I love my new jack, which reaches the lift points deep under the car very nicely (and yes, I did use jack stands before sliding myself under the car):
http://www.harborfreight.com/rapid-p...html-7814.html
I replaced the thin rubber pad in the jack's saddle with a hockey puck, which provides lots of cushioning.
Old 07-24-2012, 10:24 AM   #31
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by sgoldste01 View Post
Thanks.
Im curious i didnt see an exact lift point i just lifted from one of the 2 body formed rails under the car
auskip07 is offline   Reply With Quote
Old 07-24-2012, 10:32 AM   #32
Commander Keen
Member#: 319157
See this image: http://www.bobistheoilguy.com/bitogw...11/03/visc.jpg
A cSt of 6.8 is on the lower end of the 20 range, though we don't really know its viscosity from the factory.
Old 07-24-2012, 10:34 AM   #33
finklejag
Member#: 318622
2012 Impreza
Most 0W-20 oils on the market have a starting Viscosity @100c between 8.0-8.7. The Amsoil OE 0W-20 has a starting viscosity 8.3.
With his oil having a Viscosity of 6.88 at the end of the oil change interval. It sheared down a little. It's still a 20 weight oil though. Most 5W-30's shear down to a 20 weight after a long oil change interval. But 5W-20's usually stay pretty much where they start. The car is breaking in, so that's why the Viscosity is where it's at.
Old 07-24-2012, 11:05 AM   #34
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Send me a PM with your email address, and I'll send you a scan from the shop manual that identifies the lift points to use when raising the car with a floor jack (both for the front and the rear of the car).
After I use a jack at these lift points to get the car up in the air, I use jack stands to support the car at the rails.
By using this process to first lift the front end of the car, and then the back end of the car, I can get all four tires up in the air, which is useful for tire rotations, brake line bleeding, and so on. For my oil change last weekend, I only raised the front of the car.
Old 07-24-2012, 01:03 PM   #35
Haunty
Member#: 319378
I updated my results with the Typical
Old 07-24-2012, 01:19 PM   #36
archmikus
Member#: 323805
2012 Impreza Sport
Sage Green
This thread is very helpful. Thanks guys.
I already have 1250 miles on my new Impreza and I'm taking my new ride and a couple kayaks on a nice vacation to the Adirondacks tomorrow (approx. 500 miles roundtrip). Once I return, I plan on doing my first oil change… so that should be right around 2000 miles. I'll probably just go with the Mobil 1 from Walmart - the price is right, and its highly convenient.
I'm thinking of installing a fumoto valve, but I'm not sure which model is right for my 2012 Impreza. I've searched the forums, and some people say the F-105N is the right one, but others say its the F-108N. Can anyone set the record straight?
archmikus is offline   Reply With Quote
Old 07-24-2012, 01:24 PM   #37
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, I just installed the F-108N this past Sunday.
Old 07-24-2012, 02:03 PM   #38
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
As stated above. I ordered the F-108N
Old 07-24-2012, 02:12 PM   #39
archmikus
Member#: 323805
2012 Impreza Sport
Sage Green
F-108N it is. Thanks guys!
Old 07-24-2012, 05:17 PM   #40
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
subscribing
Old 07-24-2012, 10:42 PM   #41
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
I have a f-108n awaiting installation. Maybe I can have the Dealer tech put it in when I take it for its free first change in a few hundred more miles. And If I ask really nice maybe they will fill the little sample bottle for me as well.
(If not I'll do it myself at a later date)
ZionZR2 is offline   Reply With Quote
Old 07-25-2012, 05:19 AM   #42
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Is there anyone else who doesn't think that performing a Used Oil Analysis on the factory fill is very informative? You know the metals and silicon readings are going to be abnormally high. So why bother?
I'm thinking that pulling a sample from the 2nd or maybe even 3rd oil change would be more useful.
Old 07-25-2012, 07:51 AM   #43
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Im going to be doing my 3rd because of that reason.
Old 07-25-2012, 10:46 AM   #44
Haunty
Member#: 319378
Since it's a brand new engine, I think any analysis would be informative. Also comparing different break-in styles.
Old 07-26-2012, 12:35 PM   #45
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i see the Amsoil OE and XL (I currently have XL in mine) start at 8.3, but the Signature series starts at 8.7. and is what I have been planning to run starting next fill.
Old 08-03-2012, 05:35 PM   #46
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
after looking at these UOA's and a few others on BITOG i kinda wish I had run the factory oil a little longer as it had a really high MOLY, and most 0w-20's do not.
Old 08-03-2012, 09:25 PM   #47
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Remember that moly from factory fills may not be an additive, but from a piston coating applied at the factory. In other words, the oil may not be the source of the moly in a UOA from a factory fill.
Old 08-03-2012, 10:16 PM   #48
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I read that after i posted. I think subaru uses Moly coated pistons so you are probably correct. My mind is just messing with me
Old 08-10-2012, 05:08 PM   #49
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
I went a tad early for my first free oil change at just a hair over 3K miles instead of the recommended 3750. The tech took a sample for me as I requested. It was taken from my car and mid stream during the drain. I watched so there was no dipping in the mystery fluid container.
Sent the sample in and here are the results.
I am due in again at the 7500 mile point to get the tires rotated and another oil change so this batch of Subaru 0w20 will get about 4500 miles. After that the 7500 mile OCI is what is prescribed. That will kinda depend on the results on the next couple UOA results I get. I think I'd feel better with 5K OCI.
Old 08-22-2012, 11:46 PM   #50
finklejag
Member#: 318622
2012 Impreza
Miles on oil 4,491
Miles on engine 7,491
Havoline Synthetic 0W-20
It looks like the Silicon is treading down nicely. Both the Silicon and Moly is from the assembly. They should be near zero on on the next OCI. I don't know why they flagged the viscosity. This oil has a viscosity @100c of 8.0. So it was pretty much rock solid during the 4,491 miles.
The oil analysis thread (blackstone, etc). Nimbus09 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-22-2010 07:52 PM
0W-30 Oil Analysis richeich Newbies & FAQs 9 10-29-2000 07:36 PM
