Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 03-27-2012, 11:50 PM   #1
donald.o.dupuis
Member#: 285257
2006 impreza 2.5i
greyish lol
Default ej205 into a 06 2.5i
worth it ????gettin the motor for 450 w/ turbo n whatnot gunna rebuild the motor gasket ring and bearing overhaul just to clean it up will it bolt up to a 2.5i tranny? what all would i need to do? i know people are going to say search the forums but this search is getting tedious, in advance i appreciate all of your input thank you
donald.o.dupuis is offline   Reply With Quote
Old 03-28-2012, 01:32 AM   #2
donald.o.dupuis
Member#: 285257
2006 impreza 2.5i
greyish lol
help me out please
Old 07-25-2012, 11:54 PM   #3
Shinji Hirako
Member#: 301002
08 Impreza Wrx
i wanna know the same thing!!!
Shinji Hirako is offline   Reply With Quote
Old 03-20-2014, 12:43 AM   #4
Hoochface_GDB
Member#: 385119
find anything out??
Hoochface_GDB is offline   Reply With Quote
Old 04-06-2014, 09:55 PM   #5
subiforlife1428
Member#: 374049
2007 Legacy
black
I recenctly did this swap in my 07 Legacy. All is well other then figuring out how to do the AVCS system. The 2.5i has the AVCS and the 205 does not. I'm searching now to figure this out. My car is in safe mode. Only 4000 rpm. I've got 4500 miles on the engine so far with 7psi of boost.Like I said it runs great other than the issue.
subiforlife1428 is offline   Reply With Quote
Old 04-13-2014, 09:44 AM   #6
NGTD
Member#: 61979
2002 Subaru WRX
I am about to try this. I have an offer made on an 07 wagon and I am going to put my 02 WRX drivetrain into it. As I understand, you need a lot more than the motor. The best option is to have a donor car. From my research, you need a turbo ECU, motor wiring harness and possibly other items. In my case, I need more since the 07 is an auto. So I need transmission, pedal assembly, rear diff, etc.
Edit - you also need the cross member out of a turbo car.
NGTD is offline   Reply With Quote
Old 10-26-2014, 02:51 AM   #7
Derka003
Member#: 356729
2006 Impreza 2.5i
CGM
Anybody have an update on this AVCS issue, or how to resolve it? I'm thinking about doing this particular swap into my 06 sedan to replace my tired 253, but don't want to start a new thread, if it can be answered here..
Derka003 is offline   Reply With Quote
06 STI HVAC into 06 2.5i ? jezzy Electrical & Lighting 17 01-20-2014 01:13 PM
04-07 WRX Cluster into a 06 2.5i? MS88 Electrical & Lighting 1 01-26-2009 09:44 AM
06 2.5i 5mt trouble going into reverse snowman87 Transmission (AT/MT) & Driveline 4 11-05-2006 11:36 PM
06 WRX HVAC Swap into 06 2.5i ? jezzy Interior & Exterior Modification 0 10-23-2006 04:37 PM
STi gauge cluster into an 06 2.5i? dl337j00 Electrical & Lighting 0 05-19-2006 03:41 PM
