Old 07-26-2012, 08:56 PM   #601
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
A performance enthusiast would tell you yes. The question really is "how dramatic of a difference will I see?" I've never upgraded to a thicker RSB, but have been told that when you jump up in size drastically that most people aren't at all prepared for how the car handles given the new dynamic. In my mind 1mm thicker would be a technical improvement, but you might be left wanting more since we tend to desire more noticeable feedback from our purchases and just assume that if something is "too much" that we'll adjust to it after a while.
So thats a NO
Old 07-26-2012, 09:51 PM   #602
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Originally Posted by auskip07 View Post
So thats a NO
Basically. I was trying to encourage critical thinking!
Old 07-26-2012, 10:11 PM   #603
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
The way i see it. If you are having trouble with the rear of your car sliding out from under you then its time for an upgraded sway bar. Or if you have the base model with no sway bar.
Similar to brakes. When you have put the best pads best tires and you cant break grip and you are still not happy then its time to get better calipers. Otherwise you are wasting money.
So basically what im saying is that every mod needs to serve more of a purpose than the just say "hey look at what i got"
Old 07-26-2012, 10:36 PM   #604
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
If the rear of the car is sliding out, then that suggests oversteer to me. Most people add sway bars to reduce understeer, not oversteer. So the way I see it, if you are having trouble with the front of your car plowing and not turning in, then you need a (bigger) sway bar.
Old 07-27-2012, 12:12 AM   #605
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Originally Posted by italia490
I can confirm the handling in the snow. I was up in Big Bear, CA this year during the last storm of the season. In about a 12 hour period there was probably over a 1.5 ft of snow. I bought chains because I new it was going to snow but never had to put them on. I ended up returning them to the store that I bought them from. I purposefully tried to get the car stuck but it never happened. Traction was amazing both with the traction control on and off. There were other non-Subaru "AWD" cars that were having difficulty maintaining traction. I have some pictures that I'll post in my build thread.
I thought you're not supposed to put chains on the car?!!!! Pretty sure that might void the warranty. I think every sales person in the building told me not to while I was waiting around.
apexracer is offline   Reply With Quote
Old 07-27-2012, 12:21 AM   #606
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Having the chains was more of a precautionary measure. The highway patrol can cite you for not carrying chains in those conditions. As far as voiding the warranty, I'd be curious to know if in fact that is true and why.
italia490 is offline   Reply With Quote
Old 07-27-2012, 12:41 AM   #607
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I personally would just get a 2011 STi 19mm rear sway bar for close to fifty bucks than a Perrin that is 3mm bigger but costs like $300 more.
Old 07-27-2012, 01:11 AM   #608
pRiMe DiReCtIvE
Member#: 301387
2012 Impreza HB
Black/Dark Grey
I have seller who has STi sway bars, front and rear for $50. It's from an '09, so 18mm. Should I go for it? Swap out my 16mm from the 2012 SP.
pRiMe DiReCtIvE is offline   Reply With Quote
Old 07-27-2012, 08:04 AM   #609
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
yep correct. i was mixed up.
Old 07-27-2012, 09:44 AM   #610
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
The manual says not to use tire chains because of lack of clearance, but you can use other types of traction devices that are SAE class S on the front tires only. And says that damage caused by using any traction device is not covered under warranty.
Haunty is online now   Reply With Quote
Old 07-28-2012, 08:08 AM   #611
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
In regards to the RSB on the 2012 Impreza Sport Limited, I just ordered a 2011 STI 19mm unit from Subaruonlineparts. I can just swap the OEM 16mm unit out and use the existing hardware right?
uspopo is offline   Reply With Quote
Old 07-28-2012, 10:20 AM   #612
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i have noticed this, how do i correct it?
flyboy1100 is online now   Reply With Quote
Old 07-28-2012, 01:55 PM   #613
Supple1
Member#: 316143
Yup. It should come with the bushings, as you will need to swap those too.
Supple1 is offline   Reply With Quote
Old 07-28-2012, 03:10 PM   #614
wavear15
Member#: 316907
2012 Impreza
Ice Silver Metallic
Talking
My 22mm Perrin kit is on the way! We'll get it installed the same day and try out each others car.
wavear15 is offline   Reply With Quote
Old 07-28-2012, 03:21 PM   #615
uspopo
Member#: 317014
ISM
Sounds good, awaiting shipping confirmation for my RSB and it should only take a day from Hicksville.
Old 07-28-2012, 05:36 PM   #616
FlyerHazen
Member#: 320610
2012 2.0L
Damn, you beat me to it. Definitely post about it. The Perrin RSB will be my next mod!
FlyerHazen is offline   Reply With Quote
Old 07-28-2012, 09:17 PM   #617
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
Will the stock bushings and endlinks work with the 22mm perrin rsb?
Wes_888 is offline   Reply With Quote
Old 07-28-2012, 09:33 PM   #618
Supple1
Member#: 316143
The bushing won't work. The sway bar should come with new ones I think.
Old 07-29-2012, 09:04 AM   #619
uspopo
Member#: 317014
ISM
For those of you who replaced the OEM DRL and Foglamp bulbs with LED units, any loss in the amount of light thrown out? I am looking the at ijdmtoy offerings in white but don't want to sacrifice throw to get the nice white color/appearance.
Stan
Old 07-29-2012, 12:08 PM   #620
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Anyone do some 2010-2012 WRX Suspension take offs on the new age Impreza yet? The set ups look nearly identical (minus STi).
In particular a 5 door.
BrysImpreza is online now   Reply With Quote
Old 07-29-2012, 12:09 PM   #621
WStrembitsky
Member#: 323877
2012 Impreza Limited
Stan
I replaced the fog light bulbs with Xenon White LED's. I don't know for sure that the output is equal to the OEM's, I do notice it more but that could be because the colour stands out more under city streetlights. The bulbs I got were not an exact fit, the little plastic ridges on the outside of the bulbs' base didn't quite match up and I needed to cut one off. The colour is just a touch more blue than the stock Zenon HID headlights but it's only really noticeable if you're looking for it or are very close. Overall, I'm very happy with them.
WStrembitsky is offline   Reply With Quote
Old 07-29-2012, 01:20 PM   #622
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Stan
I replaced both foglight and drl bulbs with leds. I don't believe the output on the foglights to be that substantial to begin with so switching over to leds was more for looks. Swapping out the foglights does in fact require some minor trimming of the housing to fit properly. The drls were swapped out for a pair of high powered 9005 leds. From what I have been able to tell, the light output is comparable to the stock bulbs....maybe even a bit brighter. These are plug n play. You can check out my thread "project baby sti " for pics and more details.
Old 07-29-2012, 02:48 PM   #623
uspopo
Member#: 317014
ISM
Thanks guys...looking at the iJDMtoy sight now...
Old 07-29-2012, 06:21 PM   #624
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
By replacing your DRL bulb to LED, don't you loose your high beams since it's the same bulb?
ST Eye is offline   Reply With Quote
Old 07-30-2012, 02:23 AM   #625
12ImprezaSL
Member#: 322198
2012 Impreza SL
Try to see if he'll just sell you the RSB. Say for $25?
It'll be worth it
12ImprezaSL is offline   Reply With Quote
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
