#376 |
Member#: 298800
Tri-State
Hazleton had a TON of 3rd, 2nd and 1st gen's with alot of GC impreza's, and 1 4th gen LGT
#377 |
Member#: 248768
SCIC
Vehicle:96 rhd l wagon green |
playin' with the postal |
#378 |
Member#: 12588
SCIC
Vehicle:Four Count 'em GF5,BDA,BD5, BP5 |
Going to put on two new rear wheel bearings and front O2 sensor today. Should be fun in the heat.
CK - 5th gen looks amazing. mdk - cold-side looks pretty close to the positive battery terminal. Couldn't tell, were you able to keep your coolant overflow tank? How was fitment around the front. Keep the fogs? soloz - good choice on color - looks great on the car. ras - did you cut to fit or just cover? What are you using for camber control? |
#379 |
Member#: 305000
MWSOC
Vehicle:2005 Legacy GT 5MT Bright Silver Metallic |
#380 |
Member#: 160325
MAIC
Vehicle:98 Legacy DSP |
#381 | |
Member#: 285454
NESIC
Vehicle:2005 LGT stg 2 FMIC RBP |
![]() Last edited by mdksdmf; 07-01-2012 at 01:02 PM. Reason: ADHD |
#382 | |
Member#: 155142
RMIC
Vehicle:1996 Legacy Granola Edition |
#383 |
Member#: 160325
MAIC
Installed the jdm projectors.
#384 |
Member#: 275511
MAIC
Vehicle:1999 legacy outback winestone |
Got.my timing belt covers in the mail and my heads pressure tested. Hopefully the headgasket job will be done soon. I miss driving my wagon(even though im driving an SVX in the meantime)
#385 |
Member#: 324912
MAIC
Vehicle:2005 Legacy blue |
got my accessport for my leggy stage 1 91 oct
#386 |
Member#: 263699
Tri-State
Vehicle:2005 Legacy GT Wagon Black |
Got it a few weeks ago, sold the WRX and pick up this, so far installed Whiteline F&R Sway bars and end links, tinted windows, had XM hardwired, and flashed to Stage 1. new tires will be next, and took it to the house upstate!!
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
#387 |
Member#: 193928
Tri-State
Vehicle:2003 Legacy L White |
ordered some new tires, Hankook Ventus v12 evo110s, fixed some rust spots and...thought about this, how much will an underweight pulley take away from my power steering? If anyone has done a pulley swap how difficult was it?
#388 |
Member#: 185580
SWIC
Vehicle:2013 Forester 2.5X P DGM |
Yearly TX inspection. I've been putting it off long enough.
#389 |
Member#: 325746
i changed the oil and balanced the tires on my 98 legacy GT
#390 |
Member#: 275511
MAIC
Uploaded some new pictures onto my build thread on subaru legacy international(www.sl-i.net) *cough*JOIN*cough*
#391 |
Member#: 275511
MAIC
My legacy is back from the shop with brand new head gaskets!!
#392 |
Member#: 326980
MWSOC
Vehicle:05 legacy gt pearl black |
My 05 legacy gt was in a front end accident in May, got it repaired got it back in June and I drove it 550 miles to Denver. On my way I heard a POP I thought it was a tire blowing on a camper passing by because the car showed absolutely no indication something happened. After driving around Denver for a couple days the check engine light and cruise control light came on. Brought it for a diagnostic. Misfire on cylinder 1 and two compression tests saying cylinder 1 lost 50 psi of pressure. I took it back to a collision shop and they said all my coolant lines are leaking my valve gasket covers are leaking and apparently my turbo coolant hose is too small? Not my doing. Oil cooler is leaking. My main concern is the engine. It's got 102,000 miles on it and at 94000 my complete vehicle inspection says my valve gasket covers were good. What caused this? Insurance is trying to say preventive maintenance but I take great care of my car pay $30 just to have everything inspected every time I bring it in. Please help :-( oh and they cleared the codes gave me no conclusion to what's wrong with the car. I drove it 550 miles back to junction city ks. Check engine light came back on when I stopped for gas.
#393 |
Member#: 326667
NWIC
Vehicle:1997 Legacy L Wagon Green |
Took mine to the shop for an oil change/transmission flush. Now my car feels like it can climb up a hill again!
#394 |
Member#: 326980
MWSOC
#395 |
Member#: 160325
MAIC
CD changer died yesterday. Ordered an aftermarket head unit with aux and usb inputs. Finally join the 21st century....
#396 |
Member#: 327286
Vehicle:1995 Legacy L Wagon Grey/Green |
I just bought my Legacy, 1995 Legacy L, has 132k miles on it with the 5 speed. My co-worker is selling it to me for 3k. Monday I am gonna be giving her a bath and I am already looking into seats I could snag for cheap to replace the ones I have as they are getting a little worn.
Anyone know if Impreza seats would bolt in with no real issue? I will probably be putting some pics up later on after I clean her up a bit. |
#397 | |
Member#: 160325
MAIC
#398 | |
Member#: 327286
Also thinking of finding a NASIOC.com sticker to put across my back window so I stand out from the half a dozen soccer moms in my area driving the same thing, at least until I start being able to talk my wife into letting me put money into the thing ![]() |
#399 |
Member#: 269722
NESIC
Vehicle:2009 Impreza Grey |
Well, I didn't do it today, but I killed my Legacy two months or so ago... I was driving on my way to work, it was raining a little and I lost traction while traveling in the center lane. Did a 360 and hit the guard rail in the front and back of the car. Came to a stop in the breakdown lane. Highway was empty enough at the time, so I managed to do this all while nobody else was around. Here's the aftermath...
![]() ![]() Was really bummed that I lost her. It was my first manual car and I put over 110k miles on it myself. She went down with just under 150k total. I also like the Legacy look a lot as well. The Impreza hatchback I got as a replacement is nice and it has a few more bells and whistles, but she doesn't handle quite the same. I guess when all was said and done, I turned my Legacy into an Impreza... ![]() |
#400 | |
Member#: 160325
MAIC
| Thread Tools | |
| Display Modes | |
| So what mods have you done to your baja? | 2003Baja | Baja Forum | 22 | 07-16-2004 03:31 PM |
| What mods have you done to your WRX? | Diesel7 | Canada Region Forum | 3 | 11-02-2002 12:16 AM |
| What have you done to your RS lately? | CosmoTheCat | North West Impreza Club Forum -- NWIC | 8 | 03-27-2001 10:55 PM |
| What have you done to your impreza? | Hades69 | General Forum Archive | 2 | 02-17-2001 07:39 PM |
