Old 07-29-2012, 02:09 PM   #1
colacan
Member#: 303931
Default Stage 3 & ewg?
I was wondering if you can use the cobb stage 3 with either a vf39 or 16g turbo and use an ewg settup?
colacan is offline   Reply With Quote
Old 07-29-2012, 02:24 PM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
http://www.cobbtuning.com/AccessPORT...x/WRX-Map-Grid
Looking through the maps made for your car would be a start.
Year, model and other Mods also.
As far as i know, an ewg and an aftermarket turbo would require a protune.
bacalhau16 is offline   Reply With Quote
Old 07-30-2012, 08:44 AM   #3
Cobb Tuning
Member#: 4803
An EWG will require a custom tune with any of our OTS maps. You can check out the map notes for any given map by going to the maps section at cobbtuning.com. The map notes will tell you exactly what hardware is required. The listed turbo, injectors and intake that are compatible with the map must be used, otherwise a custom tune will be necessary (which can be accomplished via a protuner with the AccessPORT).
Bill
Old 07-30-2012, 12:05 PM   #4
colacan
Member#: 303931
alright thanks bill for the info. ill stick with the IWG for the moment
