Old 07-26-2012, 11:16 AM   #1
NikeCheck246
Member#: 175478
2002 WRX Stage 3
Default Rota Grid 18x9.5 and 265/35R18
I am looking at purchasing 18x9.5 Rota Grids and 265/35R18 tires. I can get a terrific deal on tires in this size. What kind of stretch am I looking at, if any at all? Pictures would be great, just want to make sure these tires will fit well and look good.
Not that it matters, but I have an 02 Bugeye Sedan with Megan coilovers.
Disclaimer: I did search, couldn't find exactly what I was looking for.
NikeCheck246 is offline   Reply With Quote
Old 07-26-2012, 11:20 AM   #2
Badler
Member#: 133597
The stretch is going to be getting those to fit on your car. What offset?
Old 07-26-2012, 11:27 AM   #3
sc00by4life
Member#: 97135
It matters greatly what car it is.
If you want those wheels you need smaller tires unfortunately.
Old 07-26-2012, 11:54 AM   #4
NikeCheck246
Member#: 175478
2002 WRX Stage 3
+38 from Wheeldude.com...what can i do to get them on there? I am not dead set on the tires, but it is a great deal. How would a 8.5 +44 look and what tire for it?
Old 07-27-2012, 03:40 PM   #5
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
Personally I wouldn't go with any less than a 245/40R18 on a 9.5" wide wheel but that's not to say people don't stretch more. A 245 is a slight stretch but doesn't look crazy it will also give you a slight tilt in the sidewall to help with fitment. I am not familiar with the 2002 Bugeye's body but there are plenty of them on here running 18x9.5" Grids. I would search the Rota Thread and the Bugeye Thread for similar fitments and PM the guys there to see what was required for fitment. To fit these with proper camber adjustments I would assume Coilovers, Camber Plates, Camber Bolts, and possibly Control Arms were required but I'm not familiar with 2002's so start doing some digging.
As far as the 8.5" +44's goes they will have much less concavity but will generally require much less work to get them to fit. You can run a 235 or 245 on the 8.5" pretty easily.
Improbus is offline   Reply With Quote
Old 07-27-2012, 03:45 PM   #6
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
Ask an you shall receive.
265/35R18 Dunlop Star specs on 18x9.5 +38 Rota Grids.
They rubbed a little. a little fender roll took care of that.
Car is for sale if anyone wants to know.
Dirty25RS is offline   Reply With Quote
Old 07-27-2012, 04:47 PM   #7
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
+1
Wheel width is fine, fitment for the car will not be without modification.
woody06967 is offline   Reply With Quote
Old 07-27-2012, 07:55 PM   #8
NikeCheck246
Member#: 175478
2002 WRX Stage 3
Thanks guys, really appreciate the help. Car looks good Dirty!
Old 07-27-2012, 09:16 PM   #9
vicious_fishes
Member#: 158864
2003 SOHC destroker
go with +44.
Old 07-30-2012, 07:35 AM   #10
Dirty25RS
Member#: 56731
I would go with +44 vs. +38 if available as well.
Old 07-30-2012, 12:56 PM   #11
vicious_fishes
Member#: 158864
2003 SOHC destroker
even the +44 9.5 is clearly not going to fit though. just look at the shot posted - they're sticking out a hell of a lot more than 6mm.
Old 07-30-2012, 02:17 PM   #12
Badler
Member#: 133597
Yeah, I mean they are technically on the car but they really don't fit.
OP: Are you actually trying to get more tire on there for a purpose(ie: Dirty2.5RS), or are you just looking to go hellaflushtard?
Old 07-30-2012, 02:33 PM   #13
Dirty25RS
Member#: 56731
Yeah +44 will still stick out. I think mine stick out 1.5inches (38mm) in the front.
Old 08-02-2012, 10:01 AM   #14
vgsrule
Member#: 319018
Wow I really like that width and fitment, that would be a great setup for a track day! Looks very functional
vgsrule is offline   Reply With Quote
Old 08-02-2012, 10:33 AM   #15
hakira
Member#: 74211
SSM WRX 4DR
Looks like monster truck wheels sticking out that far
hakira is offline   Reply With Quote
Old 08-02-2012, 04:24 PM   #16
vicious_fishes
Member#: 158864
2003 SOHC destroker
it would NOT be good for a track day. it would slice the tyres to pieces on the fenders.
now, if it was +44 and cranked over with the sort of camber you see on the track? well then it might be.
Old 08-02-2012, 04:37 PM   #17
Dirty25RS
Member#: 56731
Actually it doesn't rub or slice at all. This car gets tracked a lot. thats its purpose in life.
Its hellafunctional.
Old 08-02-2012, 05:19 PM   #18
hakira
Member#: 74211
SSM WRX 4DR
Must be some super stiff suspension
what about passengers or bumps?
Old 08-02-2012, 05:27 PM   #19
Dirty25RS
Member#: 56731
I'm sure if I loaded it down enough and/or hit a big enough bump fast enough it would rub hard. The fender is within the kinematic range of the tire so it definitely could happen, but it hasn't yet.
I've had these tires on for about 2 months. I had 255/35R18 RE11s on before.
Old 08-05-2012, 03:47 AM   #20
Cole635
Member#: 328191
2012 STI
Hi guys, New to the forum. Just got a 2012 STI hatch back in march. I am confused because I've been reading posts about how 18X9.5's won't fit on our cars and yet i see them on tons of STI's. Ive even seen some where the rear fenders are rolled and there is plenty of room, doesn't even look like it would be anywhere near rubbing. So correct me if I'm wrong but would they fit if you had spacers in the front (so it would fit over the Brembos) and a slight roll of the fenders in the rear?
Cole635 is offline   Reply With Quote
Old 08-05-2012, 05:29 AM   #21
vicious_fishes
Member#: 158864
2003 SOHC destroker
what suspension do you have?
cole 9.5's will fit in the 2011 widebody just fine. it's just brake clearance you need to factor in. people saying they won't fit are probably saying they won't clear the brakes.
Old 08-05-2012, 10:22 AM   #22
Cole635
Member#: 328191
2012 STI
Okay thank you vicious_fishes, I'm probably going to put 5mm spacers on the front when I get mine next spring.
Old 08-05-2012, 10:38 AM   #23
vicious_fishes
Member#: 158864
2003 SOHC destroker
well just see if you can confirm the brake clearance. don't run a spacer unless you absolutely have to.
Old 08-05-2012, 02:53 PM   #24
sc00by4life
Member#: 97135
With those grids and brembos, you have to run at least a 5.
Old 08-05-2012, 06:30 PM   #25
tomofo
Member#: 230978
2002 VF43 Stg III
Ok, who said he has Brembos? He has Megan coilovers. So, from experience, I have XXR +48 8.5" 17 inch rims with 225 45 17's. I have very little room between the strut housing and the widest part of the tire (section width) and the 225's are at their limit on a 8.5" rim. So, the +44's on the 8.5" would fit better and give you a bit of room depending on what size tire you chose than the 9.5" +35 265"s.
tomofo is offline   Reply With Quote
