Old 05-31-2012, 09:17 PM   #76
lodown1
Member#: 200596
98 Forester 3.0R
nice thanks for finding that, I will probably just get one of those and not worry about the abs at all, I dont car much for abs anyways.
lodown1 is offline   Reply With Quote
Old 07-30-2012, 02:26 AM   #77
lodown1
Member#: 200596
98 Forester 3.0R
Default New Intake designs- EZ30R ITB project
I finally spent sometime this weekend doing some machining for a new project i will be working on over the next few months. I figure some nice Individual throttle bodies for my ez30 will be a fun project that isn't as involved as some of my other ideas. These photos are of the adapters needed to fit the ITB's from the triumph speed triple motorcycle.
[/url]
[/url]
[/url]
[/url]
Old 07-30-2012, 07:11 AM   #78
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Wow! How much were those
Adapters? I sure would like a set.
slow03 is offline   Reply With Quote
Old 07-30-2012, 01:12 PM   #79
lodown1
Member#: 200596
98 Forester 3.0R
Well, I am a bit lucky I have 24/7 access to a cnc miling machine so the cost was about 24 hrs of machining time.
Old 07-30-2012, 02:28 PM   #80
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Keep up the good work. Love how you just dove in and made it work.
geronimo81 is offline   Reply With Quote
Old 07-30-2012, 06:35 PM   #81
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
Wanna make me a set. I'v been wanting to make my own intake for so long, but I am limited by tools and the stupid odd sized oval inlet shape.
Very nice work!
Old 08-01-2012, 09:15 PM   #82
CatRover
Member#: 327177
99 rs25
Looking good. I love swapped Foresters.
CatRover is offline   Reply With Quote
Old 08-07-2012, 01:45 PM   #83
lodown1
Member#: 200596
98 Forester 3.0R
Very nice work!
Well it would take quite a bit of convincing lol... but of course if you are patient this first set is really only meant for a test set using cheap of the shelf throttle bodies. I would like to do a full custom set that bolt directly to the head with no adapter, it is just a bit more involved machining wise
Old 08-07-2012, 07:12 PM   #84
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
I will certainly be in line to take these off your hands , if they ever become a burden.
Old 08-20-2012, 04:51 PM   #85
roccotrapani
Member#: 136650
2004 STi
wr blue
nice project you got going here.. keep it up
roccotrapani is offline   Reply With Quote
Old 12-11-2012, 06:31 PM   #86
slow03
Member#: 93625
2002 Outback H6
'12 Fiesta hatch
How's the throttle body project going?
Old 12-27-2012, 10:19 PM   #87
lodown1
Member#: 200596
98 Forester 3.0R
Oh slow, have not made any more progress on that since school takes over my life during the fall and spring. I need to get data logs going on the edu so can figure out what to change when i swap to the ITB throttles. Otherwise a few other projects the involve brakes, and wheels I will snap some pics and post up what i have been up to
Old 12-29-2012, 10:03 AM   #88
Type2
Member#: 200436
2004 Forester XT
Updates?
About 99.9% sure I saw you buzzing by around 9th & Connecticut a few weeks ago. Your exhaust is REALLY hard to miss. lol... Also, I was getting parts for my engine swap around the same time, and some kid that works at O'reilly Auto Parts said he got smoked by your car. He swears you had a big turbo on your car. Said he could hear it spooling up. I politely told him it was an NA H6 swap. He didn't believe me. I don't think the kid has any idea what a turbo sounds like...
You ever get dyno'd? Even Airboy would be interesting.
Type2 is offline   Reply With Quote
Old 12-31-2012, 08:17 PM   #89
lodown1
Member#: 200596
98 Forester 3.0R
Not much progress on the car since summer, but it is still running real good, I might see about getting a baseline dyne run in before school starts up again in a few weeks.
Other wise I have been slowly making progress on a few parts, remeber that picture of the ATS DTM center lock wheels well here are some photos of various parts needed to convert the stock sit hubs to run centerlock wheels
Pressure disks, centering cones, and a prototype center bolt.
Close up view of center bolt and underneath of centering cone showing the pockets for preventing the bolt from backing off.
Modified hub, I cut a "castle" pattern into the hub register so the centering cone can lock into the hub and prevent the bolt from backing off.
assembled parts ready for wheel, the lock ring prevents the centering cone from moving away from the hub.
18x10 ATS DTM centerlock wheel
So nearly done with all the parts. I still have to machine the actual adapter bolts the one in the pictures is a prototype aluminum, the real ones will be 6al-4v titanium. Once i get those done it will be a matter of getting tires and making my fenders wider
Old 05-25-2013, 10:44 PM   #90
lodown1
Member#: 200596
98 Forester 3.0R
Default Stay tuned for some coming summer attractions... Wide track forester
This is a modified front hub, I machined the castle pattern into the hub register
Here is the new titanium axle nut adapter
with the new hardcoat aluminum locking hub register, with a retaining clip this piece both centers the rim as well as prevents the new bolt from backing off.
Complete assembly with pressure washer and nut to hold the wheel on to the hub... there will also be a safety pin to prevent the nut from backing off.
Lots of room for brake calipers inside these wheels
Now need to widen the fender 2.5"
Old 05-25-2013, 10:59 PM   #91
Type2
Member#: 200436
2004 Forester XT
More pics!!
Old 05-26-2013, 03:31 PM   #92
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
WOW, amazing build!!!
Have you done the 6-speed swap yet??
TurboLag23 is offline   Reply With Quote
Old 05-26-2013, 04:10 PM   #93
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's some damn impressive fab work on the center locking wheel adapters!
So the female end of the center bolt takes the place of the axle nut, and then you threaded the male end of the center bolt to use an axle nut?
Old 05-26-2013, 09:58 PM   #94
lodown1
Member#: 200596
98 Forester 3.0R
I am still saving money for the 6 speed swap, its the one thing that i have to actually pay for, otherwise all the custom machine work I do myself so it just takes my time, and sometimes alot of it... and Patrick you are correct in how the center bolt works.
Old 05-30-2013, 02:00 PM   #95
Type2
Member#: 200436
2004 Forester XT
Spotted!
That's my black Forester XT
I really wanted to look it over up close but people were watching me and I felt guilty just taking the picture lol
Old 06-29-2013, 07:27 PM   #96
lodown1
Member#: 200596
98 Forester 3.0R
All the titanium adapter bolts are finished! wheels are out getting stripped of their old paint, they should be done next week and then i can powdercoat them and nearly be ready to put them on...
Old 07-03-2013, 06:22 AM   #97
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Soooo... What's the advantage if the hub conversion? Using track setup single bolt style for coolness or something specific? Weight?
When I was looking at the early posts when you started it I was presuming some weird conversion like 4x4 locking hubs but that only works with solid axles to the best of my knowledge.
And yeah 6speeds can get pricey. It was one of the first things on my list when I took my car off the road. Got it out of the way in place of putting the money and having a running car until the whole car was done. Still love that you sorted a way to run factory ECU, even if it's not a US ECU.
Seraphinwolf is offline   Reply With Quote
Old 07-03-2013, 07:02 AM   #98
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'm interested to hear about matching your wiring to the rear section of your car. is the donor engine/harness a different year to the recipient?
the information i have is that if the years are the same, the rearmost sections are all the same too.
Old 07-03-2013, 08:03 AM   #99
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Most everything in the rear is just a matter of applying power. Only concern there I would see would be fuel pump assembly since the Legacy is different from the rest of us.
Old 07-03-2013, 01:46 PM   #100
D3F0
Member#: 265799
1988 Subaru RX TURBO
This work is beautiful I go to Wentworth in Boston for Mechanical Engineering Technology and I wanna ask what do you major in and what do you do for a living?
D3F0 is offline   Reply With Quote
Forester/STI suspension parts from SPT? JSR Brakes, Steering & Suspension 1 04-28-2006 09:08 AM
JDM Forester STi Suspension DanzBorin Forester Forum 9 08-09-2005 09:01 AM
JDM Forester STi Suspension DanzBorin Private 'For Sale' Classifieds 2 07-29-2005 11:04 AM
Forester STi suspension installed Peaty Forester Forum 6 06-06-2005 09:55 AM
03 RS to 98 Forester shifter linkage swap?? jonnysubby Transmission (AT/MT) & Driveline 2 04-17-2005 10:29 PM
