Old 07-30-2012, 02:28 AM   #626
12ImprezaSL
Member#: 322198
2012 Impreza SL
Originally Posted by BrysImpreza View Post
Anyone do some 2010-2012 WRX Suspension take offs on the new age Impreza yet? The set ups look nearly identical (minus STi).
In particular a 5 door.
I was planning on doing this soon. I was gonna compare my friend's stock WRX to mine(for struts). Just waiting for springs to come out. Since the Imprezas are lighter, the WRX springs will not give it a proper drop. I contacted H&R, they said the middle to late Aug is their expected date for springs.
If you're looking for coilovers, Cusco is coming out soon also.
12ImprezaSL is offline   Reply With Quote
Old 07-30-2012, 02:34 AM   #627
12ImprezaSL
Member#: 322198
2012 Impreza SL
Originally Posted by pkL View Post
I personally would just get a 2011 STi 19mm rear sway bar for close to fifty bucks than a Perrin that is 3mm bigger but costs like $300 more.
The Perrin RSB 3mm difference might not seem much, but it is actually a lot. Plus it's adjustable. So it acts more like 22-24mm.
But, I am happy with my 19mm for now.
Old 07-30-2012, 04:09 AM   #628
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by italia490 View Post
I replaced both foglight and drl bulbs with leds. I don't believe the output on the foglights to be that substantial to begin with so switching over to leds was more for looks. Swapping out the foglights does in fact require some minor trimming of the housing to fit properly. The drls were swapped out for a pair of high powered 9005 leds. From what I have been able to tell, the light output is comparable to the stock bulbs....maybe even a bit brighter. These are plug n play. You can check out my thread "project baby sti " for pics and more details.
Now that I have retrofitted my lights, I would like to swap out the turn signals and that light arc above the turn signals with some LEDs or something, there should be 3 bulbs to replace (I'm open to suggestions). The HIDs makes the halogens look really yellow.
Old 07-30-2012, 10:07 AM   #629
Dill-Ag13
Member#: 316535
2007 WRX (Sold 2.0i)
Those lights look awesome
Dill-Ag13 is offline   Reply With Quote
Old 07-30-2012, 10:11 AM   #630
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Nice job! Looks very clean as if it came from the factory like that. Do you have a picture of the cutoff?
italia490 is offline   Reply With Quote
Old 07-30-2012, 10:13 AM   #631
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Please share the parts you had to buy, the prices, and the installation process, if you have the time.
Old 07-30-2012, 10:15 AM   #632
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Anyone buy Supertones yet?
Old 07-30-2012, 10:18 AM   #633
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I have a pair with blue grill installed.
Old 07-30-2012, 10:32 AM   #634
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
What are Supertones?
http://www.ocsupertones.com/
Old 07-30-2012, 10:43 AM   #635
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Search for Hella Supertones. They are aftermarket horns.
Old 07-30-2012, 10:48 AM   #636
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Ah, thanks.
Easy to install, I assume?
Old 07-30-2012, 11:40 AM   #637
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i looked through your thread, saw them listed, but not any pics.
Did you make your own bracket and harness? Did you have to remove the grill to install them?
Old 07-30-2012, 12:55 PM   #638
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
In the first post of the thread, there is a link to my photobucket album. There are pictures there. I thought I had more pictures...probably still on my camera. I'll have to take a look when I get home. I used existing bolts and holes to mount them. I used the supplied relay and ran my own wires. I removed the bumper for ease of installation. Here is a shot of them behind the bumper:
Relay
Old 07-30-2012, 01:03 PM   #639
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
thanks. I'm going to be ordering done since i got cut off yesterday by 4 different people
Old 07-31-2012, 02:19 AM   #640
pkL
Member#: 313093
2012 Impreza 2.0i
I actually don't have one on hand, I'll try to take a couple next time. It's not perfect though , I tried adjusting the projectors as best as I could. The right projector is actually maxed out as far as adjustments go (it doesn't help that the adjustment bolt is in a horrible hard to reach location even with a flexisnake).
Old 07-31-2012, 02:29 AM   #641
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Is it more a matter of installing the projector housing inside the headlight to get the cutoff as close as possible? Is there a way to shim the projector to get more adjustment?
Old 07-31-2012, 03:04 AM   #642
pkL
Member#: 313093
2012 Impreza 2.0i
I ordered everything from the retrofit source, I got the Bi-xenon Morimoto Mini Stage III Kit (D2S) with Matsu****a Gen V Ballasts (it was a special request, the gen v bolts directly to the housings for a perfect OEM fitment). The whole process took a week (on and off though) a buddy had helped me with the whole process, including the painting/blacking out of lights. We had just followed the pdf guide on the retrofit source. Hope that helps answer your question, if not I can go into more detail if you have any more questions.
Old 07-31-2012, 03:12 AM   #643
pkL
Member#: 313093
2012 Impreza 2.0i
There really is no way of knowing where to position the projectors inside the headlight beforehand unless you get one of the Morimoto Retro-Quik System kits, as there are mounting brackets and hardware to ensure the projectors are installed flush on (except they don't have this for our cars). I adjusted them one at a time and marked the hotspot for one of the projectors and then I tried to get the other projector's hotspot to lineup properly and overlap. I think it would be a lot better if I did adjustments for both at the same time, except the bolt is in a really hard to reach position by the chassis and air box on the right side and the chassis and battery on the left.
I guess the only way to get more adjustment would be to have it lined up more beforehand or adjust them both at once.
Old 07-31-2012, 04:36 PM   #644
imcausinmadrukis
Member#: 318978
Can you post the link to the "project baby sti" I tried to search it but came up with no results.
imcausinmadrukis is offline   Reply With Quote
Old 07-31-2012, 05:23 PM   #645
FlyerHazen
Member#: 320610
2012 2.0L
http://forums.nasioc.com/forums/show....php?t=2341230
What he's doing is really interesting. Definitely worth a look.
FlyerHazen is offline   Reply With Quote
Old 07-31-2012, 05:38 PM   #646
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
You beat me to it... Thanks!
Old 07-31-2012, 08:35 PM   #647
FlyerHazen
Member#: 320610
2012 2.0L
You're welcome. I like what you're doing. Any real performance gains other than throttle response with the new intake piping? I have the same sort of path in mind for my Impreza. My mod list includes RA mudflaps (red), Perrin RSB and front tower strut, axle-back exhaust, and Perrin light-weight crank pulley. I've already installed '11 STI rims/tires and have 20% tint all around.
Old 07-31-2012, 08:56 PM   #648
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Nice...'11 Sti rims...I'd like to see a pic of them on your car! In terms of performance the ECM flash made the biggest difference. Throttle response is a bit crisper with the intake tube. I plan on getting the RA mudflaps as well, 22mm front and rear sway bars with Kartboy endlinks. I'm going to far up my own axleback exhaust, did the muffler delete, it sounds good but it's lacking something. Supposedly if our ECM's are made by Denso, we might be able to tune the car via opensource and a tactrix cable. Ecutek wanted me to take a picture of the ECM to confirm.
Old 07-31-2012, 09:14 PM   #649
FlyerHazen
Member#: 320610
2012 2.0L
Nice. So far I haven't been able to take pictures of my car. I like the muffler delete but with the pre cut section in the bumper, I too would think something was missing. This is my first car and first modification opportunity. So, I don't fully understand the ecu flash and all that goes along with it. Would you mind explaining it? Is it a diy job or more difficult? Thank you much.
Old 07-31-2012, 09:15 PM   #650
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Please describe the performance gain from the ECM flash. Low end torque? Or would that require a turbo? And what was the price?
