Old 07-31-2012, 10:22 PM   #1
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Default Sick of headlights hazing up!
Has anyone ever applied clear coat over 04/05 wrx headlights?
CobbWRX is offline   Reply With Quote
Old 07-31-2012, 10:54 PM   #2
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
Use a restore kit then apply clear bra material over them and your done. I had my headlamps covered with clear bra material 6 years ago and they still look great.
MD04WRX is offline   Reply With Quote
Old 07-31-2012, 11:01 PM   #3
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
I just replazed mine about 5 months ago and their hazy already....high temp makes em look like ****.
nightcrawler60 is offline   Reply With Quote
Old 07-31-2012, 11:32 PM   #4
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Try some Meguiars headlight protectant. I got a small bottle with my headlight restoration kit and it worked great, but I ran out and you can't buy that product alone in Canada.
brett192 is offline   Reply With Quote
Old 08-01-2012, 12:01 AM   #5
6Star_McCoy
Member#: 190675
so bored...car
so durty...broken...wow
6Star_McCoy is offline   Reply With Quote
Old 08-01-2012, 12:20 AM   #6
dhump4free
Member#: 314200
02 WRX Wagon
I used the Meguiar's "Heavy Duty Restoration Kit" and it worked great. I think it comes with plastic protectant too...
dhump4free is offline   Reply With Quote
Old 08-01-2012, 03:11 AM   #7
Thomistopheles
Member#: 320513
1997 Outback
4T6, red/gray
Here's what I recently started doing to restore headlights. I got this from a detailing forum, the results last a long time.
http://www.autogeekonline.net/forum/...lant-idea.html
Wetsand 400-2000 grit
Polish w/ Meguiars M105
Polish w/ Meguiars M205
IPA wipe
Coat with a 50/50 mix of Helmsman Spar Urethane and mineral spirits
Let it dry and you're done.
Thomistopheles is offline   Reply With Quote
Old 08-01-2012, 03:17 AM   #8
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Yes.
I did.
I used a standard automotive spray can clear after wet sanding and polishing the lenses. They've stayed clear since I've done it. (about 6 months ago.)
Old 08-01-2012, 11:55 AM   #9
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Ebay FTW, just picked up a bottle for about $14 shipped.
NH8991 is offline   Reply With Quote
Old 08-01-2012, 12:00 PM   #10
08blk
Member#: 327850
08 WRX
You probably dont need headlight protectant, just wax ur headlight when you wax the rest of your car.
08blk is offline   Reply With Quote
Old 08-01-2012, 01:27 PM   #11
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
My headlights still haze up after being out in the direct sunlight for a few days, the Meguiars headlight protectant prevented this until the next time I buffed my lenses about 8 months later, but I ran out of protectant.
All the other UV protectant I can find locally says specifically not to use it on clear plastic lenses. I will try eBay like NH8991 suggested. I don't want to buy another restoration kit for $30 if I can buy the protectant individually.
Old 08-01-2012, 01:51 PM   #12
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
Actually, you do. Polish + wax won't cut it many times. Lots of lights have uv protectant on the outer surface from the factory, that wears off/gets removed by wet sanding. Also, when you polish n wax, it's still filling some if the myriad of little scratches, that will reappear once the compound you used wears off. Several things contribut to what people see when they take the typical polish/wax approach, and end up fighting the haze/fading issue constantly.
Easy solutions are what's already been mentioned: using a kit that includes a new "sealant"/ coating, or sanding n cleaning them well and then clearbra'ing them after (my preferred approach, since it offers additional protection to the lenses).
neko is offline   Reply With Quote
Old 08-01-2012, 01:55 PM   #13
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Clearcoat them with automotive grade clear with UV protection and you will never have another problem with hazing. Nothing available at Autozone, etc will give you the same results.
I highly suggest removing the headlights prior to clearing. The risk of overspray is too great otherwise.
5lipstream is offline   Reply With Quote
Old 08-01-2012, 02:12 PM   #14
02 wrx roar
Member#: 199600
Default headlights
sand down the lights with 1000 gritt till the coating is off them then clear them with automotive clear coat
02 wrx roar is offline   Reply With Quote
Old 08-01-2012, 02:31 PM   #15
Performance Race Solutions
Member#: 248291
2005 Your Dream Car
Clear coat is the only solution that will last a decent amount of time. The sealants need to be reapplied
Performance Race Solutions is offline   Reply With Quote
Old 08-01-2012, 02:57 PM   #16
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Nothing is permanent, it will just be a prolonged protection depending on the method you use. The factory coating is supposed to be "permanent" but if so, we wouldn't have these threads.
pho_shizzle is offline   Reply With Quote
Old 08-01-2012, 05:14 PM   #17
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
I use Blue Magic Headlight Sealer after each time I wash my car (about weekly)... I put it on my fiance's Elantra after using the BLue Magic headlight restorer and its kept them clear for 4 months so far.
MtnXfreeride is offline   Reply With Quote
Old 08-01-2012, 05:25 PM   #18
anon_az
Member#: 160782
2004 Impreza WRX STi
I hear a lot of people providing feedback immediately after the headlights are done, but how many of you have restored headlights 1+ years ago and can vouch for the results of the restoration?
anon_az is offline   Reply With Quote
Old 08-01-2012, 05:28 PM   #19
Psychoreo
Member#: 79643
2015 WRX STI
I just looked at my build thread. Mine are going on 8 months after wet sanding/polishing/spray clearing and look just as good as day one.
Old 08-01-2012, 09:19 PM   #20
dhump4free
Member#: 314200
02 WRX Wagon
I wet sanded the headlights when I bought the car about a year ago and they still look good. I do apply the "protectant" every couple of months though. I haven't used a bra or clear coat but I'd imagine that doing a better job at protecting than the meguiars stuff.
Old 08-01-2012, 11:49 PM   #21
ceasar
Member#: 296843
02 wrx JDM
MBP
Originally Posted by Psychoreo
Yes.
I did.
I did the same with hight temp clear coat. Spray it , let it dry for 2 or 3 days, then wet sand it and polish it and yuo are done. After that, wax them every month so u keep oxidation away from them.
ceasar is offline   Reply With Quote
Old 08-03-2012, 11:48 AM   #22
Kaleb06
Member#: 252617
2006 WRX
Dead on!
Kaleb06 is offline   Reply With Quote
Old 08-03-2012, 05:41 PM   #23
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Hey another thread on this. How many does that make now?
Old 08-11-2012, 04:53 AM   #24
WhozNext
Member#: 265369
07 STI
3,294
WhozNext is offline   Reply With Quote
Old 08-13-2012, 03:28 PM   #25
Kyle616
Member#: 325878
2004 Impreza TS
Pacifica Blue Pearl
I used a Maguier's kit. The cheaper one for like $25. It came with a buffing wheel, polish, and a cloth. It got rid of the haze but didnt smooth out the light like a sanding kit would have.
Kyle616 is offline   Reply With Quote
