Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 08-02-2012, 12:46 AM   #1
04Silverex
Member#: 77322
SSM
Default 275s
Anyone running 275/40-17s on a 2011-12 wrx? If so can I get your suspension setup thanks
04Silverex is online now   Reply With Quote
Old 08-02-2012, 02:05 AM   #2
OK Houston
we have an Uncle
too tall
no....WAY too tall
Old 08-02-2012, 06:25 AM   #3
04Silverex
Member#: 77322
SSM
Originally Posted by Uncle Scotty
too tall
no....WAY too tall
It's only 1/2 inch taller than the stock 235s
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/45-17 4.2in 12.7in 25.3in 79.6in 796 0.0%
275/40-17 4.3in 12.8in 25.7in 80.6in 786 1.3%
Old 08-02-2012, 09:11 AM   #4
sc00by4life
Member#: 97135
which is HUGE.
I hope you aren't planning on putting those on stock wheels.
search - there are more than a few people running 275's on 08+ sti's and 11+ wrx's.
Old 08-02-2012, 10:09 AM   #5
04Silverex
Member#: 77322
SSM
Nope 17x9 enkei rpf1s
Old 08-02-2012, 10:37 AM   #6
hakira
Member#: 74211
SSM WRX 4DR
never seen it on 8" tires for daily driving
but tons of people put 275-295 for autox driving stock suspension
hakira is offline   Reply With Quote
Old 08-02-2012, 05:26 PM   #7
colin1234567
Member#: 212639
WRX= 13/SWP/GR/TP
Stage 3, '90 NA Miata
Lol at only 1/2" too tall.
colin1234567 is offline   Reply With Quote
Old 08-02-2012, 05:28 PM   #8
04Silverex
Member#: 77322
SSM
I' m guessing you agree with me
Old 08-02-2012, 06:05 PM   #9
sc00by4life
Member#: 97135
No, he's not.
A half inch is HUGE.
There is no need for a tire that tall, especially when all ya gotta do is get a smaller profile.
Old 08-02-2012, 06:10 PM   #10
04Silverex
Member#: 77322
SSM
265/40 17 is the closest I can get
Same height
Old 08-02-2012, 06:31 PM   #11
sc00by4life
Member#: 97135
Same height
no, it isn't.
I thought the 1/2" was off too... So I ran calculations.
Diameter
205/55/16 (stock size) - 24.87
265/40/17 - 25.34
275/40/17 - 25.66
The 265 is better but still not ideal. Any particular reason you are set on those sizes?
Old 08-02-2012, 07:03 PM   #12
04Silverex
Member#: 77322
SSM
Originally Posted by sc00by4life View Post
no, it isn't.
Diameter
265/40/17 - 25.34
275/40/17 - 25.66
FYI I have a 2011 stock tire size is 235/45-17
Old 08-02-2012, 07:05 PM   #13
04Silverex
Member#: 77322
SSM
Height is 25.33
Old 08-02-2012, 10:04 PM   #14
OK Houston
we have an Uncle
height is gonna be different depending on the tire
the 'size' of the tire is not always the same as you think it is......until you measure it it isnt really known
and going that big is moving a LOT of mass farther away from the axis of rotation and it will make the car sluggish
thinking that ya need big, dumb, heavy wheels and tires is doin it wrong
Old 08-02-2012, 10:45 PM   #15
sc00by4life
Member#: 97135
^^ true. Not all tires are made the same.
The stock 2011+ wrx tire height is already a bit tall for the gearing.
Old 08-02-2012, 11:26 PM   #16
04Silverex
Member#: 77322
SSM
That's why I am trying to stay as close to the height of the 235/45 as I can. The 265 is about the same.
Old 08-02-2012, 11:28 PM   #17
04Silverex
Member#: 77322
SSM
I am going with one of the lightest wheels out there (rpf1) which I am sure is lighter then the stock 17x8 and just adding an inch to the width. the 265 should not be that mich heavier then the 235. So if anything it may be a bit lighter or right around the same weight
Old 08-03-2012, 01:09 AM   #18
OK Houston
we have an Uncle
i dont think you understand what is actually going on
and if you did your suspension properly, you wouldnt need such overlarge tires and you would gain lots of perfoemance by NOT going to a too big a tire
you are wanting to do it wrong...and for all the wrong reasons, im sure
a 255/40 is PLENTY of tire and a LOT lighter than a 275 will be
stop trying to look all race car and **** and edit that k00ness from your thought process and ya be better off
Old 08-03-2012, 09:18 AM   #19
hakira
Member#: 74211
SSM WRX 4DR
http://www.federaltire.com/en/images...1233035187.pdf
275 is only roughly 2.4# heavier than 255
and 5# heavier than 235/45 (stock)
235/40 from federal is actually heavier
Old 08-03-2012, 12:47 PM   #20
04Silverex
Member#: 77322
SSM
First of all, I am not trying to be all race car and ****, I am not trying to go for way bigger look, I am trying to get a tire that is the same height as the stock 235, and that fits correctly on a 9 inch wheel (I ain't trying to go the stretched look) and being I am going to purchase a higher end tire (not no federal or nexen pos) I am sure the weight will be fine.
Old 08-03-2012, 01:04 PM   #21
sc00by4life
Member#: 97135
This post really shows how little you know. 255's that scotty suggested aint stretched on a 9" tire, and if you get a wider fitting tire (such as a federal or star spec) itll give you the width you want while keeping sidewall height where you want it. As i mentioned, the stock 2011 tires are already too tall for the gearing.
Federals are fiving awesome tires, an it has nothing to do with cost. In fact, I don't know of any other tire manufacturer whose CEO holds a current F1 lisence.....
Old 08-03-2012, 04:14 PM   #22
hakira
Member#: 74211
SSM WRX 4DR
Lol I was just giving you some examples of weight difference. Get off your high horse, bud.
and federal is probably just as good as what you are thinking is "higher end"
Old 08-03-2012, 04:19 PM   #23
04Silverex
Member#: 77322
SSM
No I high horse here. I have had bad experiences with federal tires
Old 08-03-2012, 05:02 PM   #24
sc00by4life
Member#: 97135
Such as? I'd be curious to know - I've heard some people have had experiences of them chunking during track use but nothing other than that.
Old 08-03-2012, 05:08 PM   #25
04Silverex
Member#: 77322
SSM
Severe cracking on two different sets, luckily my buddy owned the shop I bought them from so went to a better set of tires
