Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 08-02-2012, 01:16 PM   #1
NjSwagWag
Member#: 260095
02 Built WRX
Default cylinder 2 & 4 misfire. 05 RS
Changed plugs, wires and coil. Still misfiring on 2 and 4. Any ideas?
NjSwagWag is offline   Reply With Quote
Old 08-02-2012, 03:33 PM   #2
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
Burnt valves
STi Guy 69er is offline   Reply With Quote
Old 08-02-2012, 04:30 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Originally Posted by STi Guy 69er View Post
Burnt valves
^Yeah, let's jump to worst case scenario right off the bat...
Title says 2 and 4, posting says 1 and 4.... which is it?
If it's 2 and 4, your cam sensor is kaput.
If you're running a lightened flywheel or crank pulley, 1 and 4 are defaults for a false misfire when the engine doesn't really know what's going on. (I have a constant P0304 in my car)
If you're all stock, it could be as simple as needing a seafoam and an Italian tune up, or it could indeed be burnt valves; do the simple stuff first.
cal_look_zero is offline   Reply With Quote
Old 08-02-2012, 05:48 PM   #4
NjSwagWag
Member#: 260095
02 Built WRX
I'm sorry. It is 2 and 4. My buddy also said cam sensor. I'll also do a seafoam tomorrow
Thank you
Old 08-03-2012, 12:10 AM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
If it's 2 & 4, your cam sensor may not be to blame. Pull the timing cover and check that you didn't slip a tooth.
yarrgh is offline   Reply With Quote
