Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 07-31-2012, 09:44 PM   #651
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by sgoldste01 View Post
Please describe the performance gain from the ECM flash. Low end torque? Or would that require a turbo? And what was the price?
Originally Posted by FlyerHazen View Post
Nice. So far I haven't been able to take pictures of my car. I like the muffler delete but with the pre cut section in the bumper, I too would think something was missing. This is my first car and first modification opportunity. So, I don't fully understand the ecu flash and all that goes along with it. Would you mind explaining it? Is it a diy job or more difficult? Thank you much.
The ECM flash was performed by the dealer. I have the 5 speed and this is what I was experiencing:
The closest comparison I can think of would be like having a super heavy flywheel. If you let out the clutch and give it gas, it takes second or two to build momentum and then it seems fine, although I did notice a bit of hesitation between shifts which is now gone after the new update. Prior to the update, when I was stopped at a light for example, I would have to increase the revs to about 2k for the car to accelerate properly. If not, and this happened on a number of occasions, all the lights on the dash would come on as if the car was going to stall.
The car feels stronger and pulls harder off the line. If we could tune our cars, low to mid torque could be improved but of course, there isn't a whole lot of support for our non turbo cars.
italia490 is offline   Reply With Quote
Old 07-31-2012, 11:01 PM   #652
Dill-Ag13
Member#: 316535
2007 WRX (Sold 2.0i)
Anybody have a link to where I can order some yellow fog lights for a 2012 Impreza? Couldn't figure out how to search this thread.
Dill-Ag13 is offline   Reply With Quote
Old 07-31-2012, 11:05 PM   #653
Dill-Ag13
Member#: 316535
Originally Posted by italia490 View Post
Someone else can correct me if I am wrong but I believe the yellow film you are referring to goes on the outside of the lens. I don't think it's feasible to apply the film from the inside.
If you are looking for yellow light output you might try this instead:
Amazon.com: Nokya Hyper Yellow H16 9009 5202 Foglight Bulbs: Automotive
Before I attempt a fog light housing retrofit, I plan on trying a bulb style similar to the one in the link. I suspect it should offer a much better light output then the factory bulb and LED bulb.
Will those amazon ones work?
Old 07-31-2012, 11:27 PM   #654
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yellow bulbs, lenses, or overlays?
I have overlays from headlight armor
flyboy1100 is online now   Reply With Quote
Old 07-31-2012, 11:28 PM   #655
Dill-Ag13
Member#: 316535
Bulbs, I've looked into overlays but want to cover the bulbs, and lenses I guess also.
Old 07-31-2012, 11:36 PM   #656
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i haven't seen any bulbs yet that are functional. I have seen yellow leds, but i doubt they are functional.
Old 07-31-2012, 11:38 PM   #657
Dill-Ag13
Member#: 316535
Right, I want the look but won't sacrifice functionality. I'll probably just go the film route, just wanted to make sure I wasn't missing something.
Old 07-31-2012, 11:42 PM   #658
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I put the link in your tint thread you started a few days ago. That eBay item is closed but click on "more from this seller" to find another listing. You can also go to Lamin-X site & order Forester ones if the 2012 still isn't on there. The Forester ones you just cut down to size.
Originally Posted by SleepNMnky
put the fog overlays on. bought them on ebay pre-cut, $7.99 free shipping from US seller. came with 3 in case you make a mistake on one.
http://www.ebay.com/itm/150681701687...84.m1497.l2649
my first time working with the vinyl & up close they're not perfect, but i think i did alright. i will say, you may want to go with the option to buy a sheet & cut them yourself. with the pre-cut, there's not much wiggle room & if they shift even slightly during application you may have an exposed edge, so if you can cut them just a hair too big you'll have a small lip to apply around the edge if you need to.
SleepNMnky is offline   Reply With Quote
Old 07-31-2012, 11:47 PM   #659
Dill-Ag13
Member#: 316535
Ah, that was you? Couldn't remember the name. Actually have the link open on another page and have had it open for several days now I just wanted to make sure I was checking all the bases, thanks again!
Old 08-01-2012, 12:39 AM   #660
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
I wouldn't expect an ECU flash to make a ton of difference in this econobox. I'm sure you can tune it to make a little bit more power, but I wouldn't expect a whole lot. Just my .02
ST Eye is offline   Reply With Quote
Old 08-01-2012, 12:55 AM   #661
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
So can I just go in and ask for the ECU flash without getting an oil change or any other work done?
pkL is online now   Reply With Quote
Old 08-01-2012, 01:49 AM   #662
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I don't see why not. A TSB was issued for the CVT so there should be one for the manual.
Old 08-01-2012, 05:20 AM   #663
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I used Lamin-X on my fogs too. But instead of ordering the Forester product, I ordered one 4x8 inch sheet, cut it in half, applied the film, and then trimmed it to size.
Make sure you apply this stuff when it's warm outside. On my VW, I applied it in the winter, and couldn't get all the creases out because it was too stiff.
Old 08-01-2012, 05:23 AM   #664
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Has anyone installed the Perrin lightweight crankshaft pulley? Any issues or error codes after installation?
uspopo is offline   Reply With Quote
Old 08-01-2012, 09:14 AM   #665
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
I posted in italia490's thread about this. I had my first oil change done and told them about the issue I am having. They said there was no ECM re-flash for the manuals. When I told him a guy on NASIOC has one that had the same problem, got an ECM reflash and it fixed the problem, they couldn't give me a straight answer.
Now, I am going to bring it back with the thread pulled up on my phone, and show them the part of the service invoice from italia490's thread, and see if they can just do what they did to his car.
Some people think an ECM reflash is all about getting more horsepower when it is sometimes just about getting better throttle response. If we found a tuning company to look into our ECMs maybe they can find a couple horses, but more importantly smooth out the throttle response.
monkeyracer is offline   Reply With Quote
Old 08-02-2012, 12:16 AM   #666
pkL
Member#: 313093
2012 Impreza 2.0i
They make a crank pulley for our cars? I thought it was only for the BRZ/FR-S.
Old 08-02-2012, 12:22 AM   #667
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
At least to my understanding.
apexracer is offline   Reply With Quote
Old 08-02-2012, 12:53 AM   #668
ST Eye
Member#: 73068
I don't think the TSBs would apply to the manual versions since it has to do with shifting, for lack of a better word.
You can always use a hair dryer to heat up the material. I like the thinner film as it is a bit easier to work with.
Old 08-02-2012, 01:29 AM   #669
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Since you have no idea what you are talking about, maybe you should keep your $0.02 to yourself. The issue has nothing to do with shifting. If that was the case, why would there be an ECM re-flash for the manual. Has a TSB been released for the manual....I can't say for certain but what i can say from my own experience is that there is clearly an issue with driveability on the earlier '12 imprezas and that there is a noticeable improvement after the re-flash.
Old 08-02-2012, 02:19 AM   #670
FlyerHazen
Member#: 320610
2012 2.0L
I contacted Perrin, and they said the CP for the BRZ/FR-S applies to '12 Impreza.
FlyerHazen is offline   Reply With Quote
Old 08-02-2012, 05:21 AM   #671
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
The yellow Lamin-X product is plenty easy to work with, if it's warm outside. Yes, I've heard of the hair dryer trick too, but that would be more tedious.
I like that the Lamin-X product is thick because it provides more protection against rock damage. And it wears well over time.
Old 08-02-2012, 07:13 AM   #672
uspopo
Member#: 317014
ISM
Contacted Perrin about the CP to see if there are any issues such as a check engine light coming on but no response yet. My Co-worker put a light weight crank pulley on his Nissan Juke and that cause the the check engine light to come on.
Old 08-02-2012, 08:39 PM   #673
FlyerHazen
Member#: 320610
2012 2.0L
Perrin is not the most responsive company...I've spent a month sending them messages and emails and only have gotten one answer.
I know from reading through the forums that a cat-back exhaust would void warranty. So, I don't want to do that or the muffler delete because of the cut out in the bumper.
Any suggestions on aftermarket mufflers? I want less restriction and a better sound.
Old 08-03-2012, 01:42 AM   #674
12ImprezaSL
Member#: 322198
2012 Impreza SL
Anything axle back won't void the warranty.
A few pages ago, I posted a video of mine with a magnaflow muffler. Welded on.
Here is the vid again
12ImprezaSL is offline   Reply With Quote
Old 08-03-2012, 01:58 AM   #675
FlyerHazen
Member#: 320610
2012 2.0L
2012 Subaru Impreza HB with Magnaflow 11236 muffler - YouTube
Yeah, I knew an axle back wouldn't. It sounds good. Does it drone out the boxer rumble a lot? Why'd you weld it, instead of just doing bolt on?
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
