#1 |
Member#: 171127
Vehicle:62XX Rotated *Mo Displacement |
Can we post proven power stroker output here in sum? I for one would love to see a variety of proven power stroker out put whether it be 2.1, 2.34, or 2.6 or 2.7 in one thread. Those fools in exterior can manage to post up and keep a thread alive, it would be great if this could follow suit.
It would be most helpful to see a variety of examples and setups in one place and especially if anyone has 2.1l with head work and big turbos, and cams. No Hybrids............all about strokers I know motion lab, wicked innovations, and maxwell power have examples........can you please post them here.Thanks
#2 |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
im getting stroked right now
#3 |
Member#: 107179
Vehicle:2003 WRX, S400SX FMW MBP |
I'm game - this was my old setup.
2.1 Stroker, revving to 8k daily ej205 case Wiseco Pistons K1 rods ACL bearings Non nitrided STi crank JDM v7 heads with working AVCS Tomei 256/264 cams id1000s FMIC 8cm ewg HTA Green 07 6 speed Never got it dyno'd in finished trim on 100 octane but did 11.01@129.6, sliding around on 225/45/17 RE070s. |
#4 | |
Member#: 171127
Wow, sounds like dream setup.......when did you see full boost and how much boost where you running? |
#5 |
Member#: 197920
Vehicle:2005 Legacy GT ABP |
I think he was running 27-28# when the motor took a permanent vacation.
A very similar motor will be put in my brothers car. RexFTW's setup was ridiculous |
#6 | |
Member#: 107179
In 3rd gear, 20 psi was at ~4100 rpm, 30 psi at about 4700 rpm based on this old log I am looking at. In 4th gear I have logs of 20 psi at 3600-3700 rpm, 30 psi by 4100. This was my old 4th gear airboy. Note I swapped out a lot of parts and did weight reduction so I didn't know exact weight so I estimated what I thought was high and low weight for the car which is the two lines. Actual power would be somewhere in between. ![]() Edit: In looking back at the log I made that picture from that wasn't even the finished tune. It is about 3.5-4* of timing off. Last edited by RexFTW; 08-01-2012 at 11:42 AM. |
#7 | |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
Excited to see the 205 variants stack up in here as the 2.5 based ones aren't of interest to me AT ALL. |
#8 |
Member#: 171127
#9 | |
Member#: 171127
What took out the motor and could you give a guestimate on the torque increase from 2.0l to 2.1 soley based upon a bare bones 205 (stock with good compression)......increase of 40lb/feet? |
#10 | |
Member#: 107179
. So I nearly ran out of gas on the way home and put 93 in it. I put a gimp map on it but that wasn't fast enough and I decided I needed a fun 93 map as well. I tuned it on 93 octane pretty aggressively at about 25 psi and it went several weeks later after that. I always considered that motor a science experiment and treated it as such, as I had not seen any 2.1s pushed that hard at the time. In hindsight, I wish I was nicer to it as it worked awesomely.I am not sure which failure came first but I have found 3. One of the pistons had a ringland failure, all four pistons had cracks like this on both sides of the skirt on the intake side of the piston, and two of the sleeves had cracks forming. I don't know what of the failures caused other failures (cracked pistons from too much power causing too much friction on the sleeves cracking them, causing heat spots making easy detonation to kill a ringland?) or if they were each from different things. ![]() I just pushed it too hard for too long on cheapy budget parts, but the thing was amazing for what it was. ![]() Edit: If I had to guess on the torque difference between a 2.0 and a 2.1 I would say the butt dyno registers it at about 1/2 the difference between a 2.0 and a 2.5 but I had AVCS to help as well so not quite half but definitely significant. It is hard to quantify it exactly as a lot of things impact torque output and I changed a LOT all at once going from stock ej205 to stroker with v7 heads. |
#11 |
Member#: 171127
Can we get some more 2.1l in here
#12 |
Member#: 172011
Maxwell Power Services 2.1
EJ205 bored 20 over 8.8:1 JE pistons Mps +2mm rods Stock 257 crank Acl bearings S20 heads Kelford 199-j cams (264's) .5 over valves Springs and retainers GT35r .82 housing TXS fmic Hydra Made 430whp at 20 psi on pump gas. Lasted between 55000-60000 miles |
#13 |
Member#: 197920
Hot damn, that sounds awesome.
#14 | |
Member#: 166005
#15 | |
Member#: 172011
#16 |
Member#: 255146
International
Vehicle:2001 2002 WRX Wagon WR BLUE |
We are running 2.1
EJ205 block with JDM WRX AVCS heads EJ257 crankshaft Cosworth pistons Manley rods 12mm ARP headstuds ACL race bearings Cosworth 1.1mm headgasket set 10mm Oil pump Cosworth baffled plate Turbo:MDX321T 840cc Modified WRX injectors with parallel fuel rails and Fuelab billet fuel filter,Fuelab FPR 340LPH fuel pump and Fuel Swirl pot with braided lines Sytec fuel filter and 044 fuel pump FMIC RCM big cone filter Syvecs S6PnP We are made 490bhp(US 420whp),full boost 1.7bar around 3500RPM on the road Jura |
#17 |
Member#: 166005
#18 | |
Member#: 171127
#19 |
Member#: 171127
#20 |
Member#: 197920
#21 |
Member#: 171127
#22 | |
Member#: 172011
#23 | |
Member#: 172011
#24 |
Member#: 188947
Built and mapped 2.1 strokers aplenty, here's just a sample of some of them.
All kinds of turbos and head/cam combinations. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#25 |
Member#: 188947
A couple more.
