Old 02-09-2011, 10:20 PM   #1
turbo38sfi
Member#: 273512
Found a 40k mile 06 Impreza motor to go into an 05 Legacy for 1000 bux. Couldn't pass it up. There's a few sensors that are different that I'm not quite sure what they are. Wondering if I can just leave them unplugged. Everything else seems to look like it'll work. I AM swapping the intakes are they are completely different as well as the knock sensor and and a few emmission hose fittings. Can you take a look at the 2 pictures and let me know what they are and if my thinking of leaving them unplugged w/the original intake on the new motor will work. It looks like they can be unbolted from the block without any leakage?
There is one behind the drivers side timing sproket on the head. That looks like it may be a pain to take off.
There is another on the passenger side rear head also.
https://picasaweb.google.com/turbo38...92530247894930
https://picasaweb.google.com/turbo38...91479658128994
turbo38sfi is offline   Reply With Quote
Old 02-10-2011, 09:27 AM   #2
KONKILR
Member#: 3190
2000 Impreza RS and
the Suxass racing mobile!
Those components can not just be removed. This will cause massive oil leaks. That engine is not the same as your original. It will require modification to work. The main difference is the heads and pistons. The new engine has AVLS (active valve lift system). Your ecu isnt designed to use this. I am doing this kind of swap right now, it has some difficulties. I wouldn't reccomend it unless you are highly experienced as I am.
jake
KONKILR is offline   Reply With Quote
Old 02-10-2011, 09:37 AM   #3
turbo38sfi
Member#: 273512
jake
Well, that's kind of what I was afraid the answer was going to be.
Can you elaborate on what type of modifciations it would require, ECU swap I'm assuming?
That said, I should be able to swap over the heads and be OK?
Old 02-10-2011, 09:43 AM   #4
KONKILR
Member#: 3190
2000 Impreza RS and
The pistons are different and may cause issues. If you swapped this motor in you would need something to control the AVLS.
jake
Old 02-10-2011, 09:44 AM   #5
turbo38sfi
Member#: 273512
jake
What else would need to be swapped in with the motor as it sits?
Pistons different cause of compression or how so?
Old 02-10-2011, 10:13 AM   #6
KONKILR
Member#: 3190
2000 Impreza RS and
The pistons are a different shape to match the heads. They may contact your old heads as the combustion chamber is a different shape.
If you used your old intake manifold the engine would bolt in and work, but you would need something to control the AVLS system. The engine will be down on power without this system working correctly.
jake
Old 02-10-2011, 10:26 AM   #7
turbo38sfi
Member#: 273512
jake
How are you tackling this for your swap you're doing now?
Old 02-10-2011, 12:09 PM   #8
KONKILR
Member#: 3190
2000 Impreza RS and
I am going to use an rpm activated switch to turn on the AVLS, once I find out what rpm it is supposed to switch at. I will be using the 06 intake manifold, but this is a whole new challenge itself.
jake
Old 02-10-2011, 01:14 PM   #9
turbo38sfi
Member#: 273512
jake
I have read about that approach. I know of 2 others now that have done the mod without messing with the AVLS. Here is an interesting thread you may want to check out
http://www.subaruforester.org/vbulle...ter-64496-new/
Old 02-10-2011, 06:31 PM   #10
KONKILR
Member#: 3190
2000 Impreza RS and
I can tell you right now that by not using the AVLS you will be down on power. I know exactly how the system works. I am a tech at a dealership and have been working with subaru's for over 10 years. The AVLS only opens one intake valve fully and one partially until it is activated then it opens both intake valves fully. So essentially if you leave it disconnected you will not be using the full breathing potential of the heads. I am in the process of determining when the system activates and de-activates under all conditions so I can set mine up properly.
jake
Old 02-10-2011, 09:27 PM   #11
turbo38sfi
Member#: 273512
To hook it up, would it be as simple as getting an 06 ECU and plugging it in using the orig 05 intake, or is there a totally different harness to swap in too?
Old 02-11-2011, 06:05 AM   #12
KONKILR
Member#: 3190
2000 Impreza RS and
There would be way too many changes to make swapping ecu's worthwhile. You could way more easily wire up a vtec controller or rpm activated switch to your current setup.
jake
Old 02-11-2011, 08:56 AM   #13
turbo38sfi
Member#: 273512
jake
Seems that going that route would be problematic in that the ecu would not know the cam profile has changed or how to adjust the fueling tables when it is activated.
Old 02-11-2011, 09:45 AM   #14
KONKILR
Member#: 3190
2000 Impreza RS and
It needs to switch very early, so that shouldn't be a problem. The stock ecu can adjust for fueling. This is exactly how I'm gonna run mine.
jake
Old 08-03-2012, 03:43 PM   #15
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
Just for search purposes.... this is bs. An avls engine can run perfectly fine in a non avls ecu'd vehicle without the avls hooked up. Mine ran that way for 4 +years. However, hooking up a relay and making use of the avls is easy. You will possibly have to deal with idle issues and low speed launch problems.
http://forums.nasioc.com/forums/show...1753961&page=4
02darkRS is offline   Reply With Quote
Need help identifying WRX motor parts Carreragt2e Built Motor Discussion 5 05-07-2009 08:29 PM
Need help identifying belt tensioner part 94'325is Newbies & FAQs 1 05-13-2008 09:47 PM
Help with identifying a few parts lh0628 Normally Aspirated Powertrain 3 04-12-2008 02:38 AM
Rallied My 06 Impreza into a fence :( karzwell Off-Topic 28 10-12-2006 06:53 AM
Need help identifying a few things viru567 Factory 2.0L Turbo Powertrain 5 07-30-2004 09:45 AM
Message Board Statistics All times are GMT -4. The time now is 04:41 AM.
