#26 |
Member#: 171127
MAIC
Vehicle:62XX Rotated *Mo Displacement |
Appreciate the contribution, these are shoot out # correct? I am impressed with how early those shared setups make power. I need a better look as this blackberry is a piece of ****
#27 |
Member#: 188947
Yes, they're all ran in Shoot44 mode.
The first graph is one of my personal favourites, an all Cosworth motor with ported non AVCS heads and a Blouch Billet GT30R and a .63 housing, fuel is a 20% meth mix. Awesome road car with ballistic response and a decent area under the curve. |
#28 |
Member#: 172011
NWIC
http://i1072.photobucket.com/albums/...4-26_305-1.jpg
Opps I lied. Here is the numbers. 428whp 362trq @20.7 psi reached at about 5500 rpm. Sorry for the crappy pic. Little more info about the setup. I originally went with a stock location 35r in hopes of a little better spool. I wouldnt recomend it. Spool was barely any better than a regular 35r I was running 23 psi to only make 390whp. Never ran any race gas or meth with either turbo to see what it would do with more boost. Did a compression test one day and 3 were low. Mps pulled it apart and found the rings were worn (expected) and that the cylinders had begun to oval a little. Other than that it was in perfect condition. Personally if I were to do it again I would go with something 18g size. Off boost in this was hardly any different than my stock 2l vf34 setup. It is deffinetly a great choice for the 2l guys looking for a little more power. |
#29 |
Member#: 65140
NWIC
Vehicle:2007 STI Limited#213 05 STI (rip) 03 WRX (rip) |
I have a recent stroker
2.6 ltr Maxwell Power stroker kit 83mm billet crank Dom helped me pick my components for a real fast spooling broad torque setup. balanced blueprinted Ph spacers AMR inlet 20g XTr Pulleys Aem boost solenoid Cattless TXS turbo back Typhoon short ram ( my choice pre Dom ) ETS TMIC ID1000's Agency power coated header and up pipe ( we are getting these in next week ) TGV deletes Turbo coatings blankets and lots of DEI We felt on the first tune that the stock manifold/up pipe was really limiting torque, so we ordered the Agency power setup with upPipe. I am pretty sure that will complete the bolt ons. Right now it spools like a stage 2 and puts down 375wtq and 365whp on pump 92 oct. The thought is that we will break 400wtq with the new header and upPipe and probably end up with 380whp on the MPS dyno. The 2.6 is super responsive around town but it doesn't make much sense to rev it's nuts out. Shift like a stage 2... Having owned a FMIC 2005 STI with a FP 20g TDO6h 7cm and now this setup in a 2007STI. I can say that this is more powerful and more responsive. 350-360whp with good fast spool seems to be where I am happiest. I drive around under 5k 99% of the time so I like my power there. That being said I can't compete with the big turbo boys. Thats ok though, I can make em work for it... |
#30 |
Member#: 171127
MAIC
Thanks for the contribution
#31 |
Member#: 111692
Tri-State
Vehicle:04 wrx wagon |
Curious, if u do not abuse it (say, dd/weekend warrior) what is typical lifespan of a stroker motor?
#32 |
Member#: 107179
MWSOC
Vehicle:2003 WRX, S400SX FMW MBP |
The lifespan on the 83mm crank might be an issue as, if I understand it correctly, the piston gets to wiggle around a little bit at bottom dead center as the bottom of the pistons gets to travel a bit outside the sleeve. The 2.1s I doubt have any worse reliability overall than your average built 2.0 or built 2.5. If it is put together well, and pushed reasonably (my 30 psi on 93mm wiseco pistons and stock sleeves isn't an example of reasonably) I could see it having a pretty long life, perhaps even rivaling the stock engines.
#33 |
Member#: 68647
MAIC
Vehicle:07 STI Rotated 35R Jorge Tuned |
Where is Maxwell Power at? Would really like to see their input, especially on the destroked 2.3's.
Martynj thanks for the charts! Have you done any/many 2.3's?? |
#34 |
Member#: 145145
MWSOC
Vehicle:2006 wrx STi |
![]() 2.7L 83mm stroke, 102mm bore, 8.5:1 compression. Full race twinscroll kit running a BW 83-75 Journal bearing turbo with a .91AR T4 twinscroll hotside. This particular run was at the end of the tuning session, on q16 in a 93 deg dyno room. AEM was pulling 5 deg of timing from the coolant temp compensation table. |
#35 | |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
Maxwell, chime in plz |
#36 |
Member#: 200987
MAIC
A 30R on a destroked really isn't doing the shortblock any justice. I suggest to most to run a 35R at a minimum...and I also don't recommend it as a true street car unless you don't mind the trade off in low end torque.
I do however have on customer who very much so wants to put a GTX3076R onto one...could prove to be interesting. |
#37 | |
Member#: 188947
![]() GT3040 turbo on 2 different cam choices, the original in Red was good for drag, not so good on the road, the revised cam choice in Blue made a much better road car. I have 2 stroked EJ22 motors being built at the moment, both are equipped with Blouch 35R Billet turbos. I'll keep you updated on the results ! |
#38 |
Member#: 171127
MAIC
Thanks for the contribution to the thread
#39 |
Member#: 202204
MWSOC
Vehicle:02 WRX PSM |
i'm so glad this thread is here now. I've been wanting to do a 2.1 w/ v7 heads for a while now but i've had trouble finding other results.... Glad I was on the right path.
#40 |
Member#: 221099
MWSOC
Vehicle:2001 Impreza 2.5RS Blue Ridge Pearl |
well its not in my car yet, i am awaiting a merged wiring harness from iWire but i'll post up my setup
2.1 stroker setup Wiseco stoker pistons top and skirt coatings by LoCo Manley rods subaru nitrided 79mm crank 205 heads with gasket match port and mild polishing Supertech nitrided intake valves Supertech stainless exhaust valves Supertech dual valve springs Supertech titanium retainers Tomei Poncams w/AVCS plugged 11mm shimmed oil pump TGV deletes stock exhaust manifold catless up pipe and down pipe Tomei Arms 7760 turbo my plans after break in: ID1000 injectors Agency Power fuel rails Aeromotive FPR E85 Agency Power EL headers Okada Projects coil packs and i'll update when that all happens =P |
#41 |
Member#: 118815
Running a 2.35, up to 704bhp running 2.1bar on 99ron + 20% meth
EJ22T block EJ257 79mm nitrided crank Wiseco stroker pistons Crower stroker rods ACL main and big end bearings Cosworth 12mm high flow oil pump 14mm head stud conversion Zero sports 71c thermostat 2006 avcs heads ported and knife edge polished 1mm oversize Cosworth Inlet and Exhaust valves supertech titanium retainers supertech double valve springs supertech valve seats 272 inlet and exhaust cams Adjustable exhaust cam pulleys Kevlar timing belt cosworth billet timing belt guide Cosworth high flow inlet manifold bespoke top feed fuel rails Injector dynamics 2000cc Injectors |
#42 |
Member#: 171127
MAIC
Thank you for the contribution, care to post up a dyno sheet or two?
#43 |
Member#: 41561
MWSOC
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
Not bad for 17-18 psi. Still a little work to do with boost stabilization.
2.1 Stroker 16k-17k miles on this build so far. Rotated Garrett 3076r KSTech rotated 73mm intake. Wiseco Pistons Eagle Rods Mild porting (smoothing) 5 angle valve job TGV Deletes STI cams Greddy Evo 2 Borla UEL headers TXS FMIC ![]() Code:
Time (msec) Engine Load* (g/rev) Engine Speed (rpm) Feedback Knock Correction* (degrees) Fine Learning Knock Correction* (degrees) IAM* (raw ecu value) Ignition Total Timing (degrees) Intake Air Temperature (F) Manifold Relative Pressure (Direct)* (psi relative) Mass Airflow (g/s) Mass Airflow Sensor Voltage (V) Primary Wastegate Duty Cycle (%) Target Boost* (psi relative sea level) Throttle Opening Angle (%) Turbo Dynamics Burst* (absolute %) Turbo Dynamics Continuous* (absolute %) TXS UTEC AFR (AFR Gasoline) 0 0.39 2278 0 0 16 32 88 -2.61 14.74 2.16 0 -1.37 12.94 0 0.87 14.83 60 0.39 2280 0 0 16 32.5 88 -2.59 14.95 2.16 0 -1.35 12.94 0 0.87 14.83 120 0.39 2300 0 0 16 32.5 88 -2.65 14.9 2.16 0 -1.35 12.94 0 0.87 14.78 205 0.38 2289 0 0 16 32.5 88 -2.59 14.65 2.14 0 -1.35 12.94 0 0.87 14.78 267 0.38 2310 0 0 16 33 88 -2.57 14.64 2.16 0 -1.35 12.94 0 0.88 14.78 327 0.38 2310 0 0 16 33 88 -2.53 14.84 2.16 0 -1.33 20.78 0 0.88 14.83 395 0.44 2312 0 0 16 32.5 88 -0.7 16.49 2.32 0 0.73 29.02 0 1.96 14.83 475 0.49 2346 0 0 16 29 88 0.04 20.6 2.42 1.96 2.46 40.78 0 2 14.83 540 0.52 2329 0 0 16 26 88 0.66 21.04 2.44 3.92 5.07 67.45 0 2 14.78 601 0.52 2359 0 0 16 25 88 0.83 20.76 2.48 5.88 11 97.65 0 2 14.78 670 0.52 2337 0 0 16 24.5 88 0.95 20.7 2.46 7.84 16.92 100 0 2 14.78 748 0.54 2397 0 0 16 25 88 0.97 20.55 2.5 9.8 18.76 100 0 2 14.15 813 0.54 2360 0 0 16 24.5 88 1.08 22.23 2.46 11.76 19.18 100 0 2 14.15 879 0.55 2394 0 0 16 25 88 1.1 21.45 2.44 13.73 19.18 100 0 2 14.15 942 0.55 2382 0 0 16 25 88 1.2 22.76 2.52 15.69 19.18 100 0 2 13.78 1022 0.56 2436 0 0 16 25 88 1.22 22.47 2.5 17.65 19.18 100 0 2 13.78 1084 0.56 2433 0 0 16 25 88 1.33 23.55 2.5 20 19.18 100 0 2 13.78 1150 0.56 2475 0 0 16 25 88 1.31 22.15 2.5 21.96 19.18 100 0 2 13.31 1231 0.56 2448 0 0 16 26 86 1.43 23.13 2.5 23.92 19.18 100 0 2 13.31 1293 0.56 2481 0 0 16 25 86 1.47 23.08 2.54 25.88 19.18 100 0 2 12.83 1359 0.56 2489 0 0 16 25.5 86 1.53 23.48 2.54 27.84 19.18 100 0 2 12.83 1421 0.56 2515 0 0 16 26 86 1.59 23.27 2.56 29.8 19.18 100 0 2 12.83 1499 0.56 2508 0 0 16 26 86 1.62 23.3 2.54 33.73 19.18 100 0 2 12.78 1563 0.57 2532 0 0 16 26 86 1.68 23.62 2.58 35.69 19.18 100 0 2 12.78 1630 0.57 2552 0 0 16 26 86 1.72 24.07 2.56 37.65 19.18 100 0 2 12.78 1706 0.58 2566 0 0 16 26 86 1.8 24.73 2.58 39.61 19.18 100 0 2 12.68 1771 0.57 2591 0 0 16 26 86 1.86 24.13 2.5 41.96 19.18 100 0 2 12.68 1835 0.58 2582 0 0 16 26 86 1.9 25.09 2.62 43.92 19.18 100 0 2 12.68 1898 0.58 2605 0 0 16 26 86 1.93 25.09 2.6 45.88 19.18 100 0 2 12.64 1978 0.58 2607 0 0 16 26 86 1.99 25.5 2.54 47.84 19.18 100 0 2 12.64 2042 0.58 2637 0 0 16 26 86 2.03 25.43 2.62 49.8 19.18 100 0 2 12.64 2104 0.59 2656 0 0 16 26.5 86 2.09 25.95 2.64 51.76 19.18 100 0 2 12.56 2191 0.59 2667 0 0 16 26.5 86 2.11 26.08 2.64 53.73 19.18 100 0 2 12.56 2249 0.59 2685 0 0 16 27 86 2.15 26.34 2.6 55.69 19.18 100 0 2 12.56 2314 0.59 2696 0 0 16 26.5 86 2.19 26.2 2.56 57.65 19.18 100 0 2 12.52 2378 0.59 2718 0 0 16 27 86 2.22 26.72 2.62 59.61 19.18 100 0 2 12.52 2444 0.59 2739 0 0 16 26.5 86 2.24 26.66 2.66 61.96 19.18 100 0 2 12.52 2523 0.59 2736 0 0 16 27 86 2.32 27.11 2.68 63.92 19.18 100 0 2 12.52 2589 0.6 2760 0 0 16 27 86 2.34 27.18 2.7 65.88 19.18 100 0 2 12.52 2668 0.61 2767 0 0 16 27.5 86 2.38 28.3 2.72 67.84 19.18 100 0 2 12.52 2730 0.61 2815 0 0 16 27 86 2.42 28.25 2.66 69.8 19.18 100 0 2 12.56 2793 0.62 2814 0 0 16 27.5 86 2.48 28.88 2.66 71.76 19.18 100 0 2 12.56 2845 0.61 2842 0 0 16 27 86 2.55 29.04 2.68 73.73 19.18 100 0 2 12.56 2939 0.62 2850 0 0 16 27.5 86 2.57 29.74 2.76 77.65 19.18 100 0 2 12.67 3002 0.62 2871 0 0 16 27.5 86 2.63 30.04 2.78 79.61 19.18 100 0 2 12.67 3067 0.62 2867 0 0 16 27.5 84 2.69 29.93 2.68 81.57 19.18 100 0 2 12.67 3149 0.63 2890 0 0 16 27.5 84 2.77 30.54 2.72 83.92 19.18 100 0 2 12.74 3198 0.63 2900 0 0 16 27 84 2.84 30.74 2.76 85.88 19.18 100 0 2 12.74 3273 0.63 2942 0 0 16 27.5 84 2.88 30.93 2.72 87.84 19.18 100 0 2 12.74 3356 0.63 2944 0 0 16 28 84 2.98 30.74 2.72 89.8 19.18 100 0 2 12.74 3419 0.63 2955 0 0 16 28 84 3.06 30.58 2.82 91.76 19.18 100 0 2 12.74 3482 0.62 2968 0 0 16 28 84 3.13 31.37 2.74 93.73 19.18 100 0 2 12.74 3543 0.62 3004 0 0 16 28 84 3.19 31.01 2.84 95.69 19.18 100 0 2 12.78 3628 0.62 3018 0 0 16 28.5 84 3.23 30.94 2.74 96.47 19.18 100 0 2 12.78 3691 0.62 3024 0 0 16 28.5 84 3.33 31.48 2.8 96.47 19.18 100 0 2 12.93 3754 0.62 3032 0 0 16 28.5 84 3.38 31.33 2.8 96.47 19.18 100 0 2 12.93 3834 0.62 3075 0 0 16 28.5 84 3.46 31.74 2.78 96.47 19.18 100 0 2 12.93 3898 0.62 3071 0 0 16 28.5 84 3.56 32.24 2.82 96.47 19.18 100 0 2 13.12 3959 0.62 3118 0 0 16 28.5 84 3.62 32.29 2.88 96.47 19.18 100 0 2 13.12 4026 0.62 3129 0 0 16 28.5 84 3.67 32.25 2.78 96.47 19.18 100 0 2 13.12 4104 0.62 3150 0 0 16 28.5 84 3.73 32.84 2.8 96.47 19.18 100 0 2 13.23 4169 0.62 3162 0 0 16 29 84 3.83 32.09 2.82 96.47 19.18 100 0 2 13.23 4233 0.62 3196 0 0 16 28.5 84 3.85 32.31 2.8 96.47 19.18 100 0 2 13.23 4312 0.62 3200 0 0 16 29 84 3.94 32.73 2.86 96.47 19.18 100 0 2 13.33 4378 0.62 3230 0 0 16 29.5 84 3.98 33.12 2.84 96.47 19.18 100 0 2 13.33 4440 0.61 3227 0 0 16 29.5 84 4.04 32.87 2.84 96.47 19.18 100 0 2 13.33 4503 0.61 3265 0 0 16 29 84 4.08 33.05 2.84 96.47 19.18 100 0 2 13.47 4588 0.62 3268 0 0 16 29.5 84 4.16 33.42 2.86 96.47 19.18 100 0 2 13.47 4648 0.62 3295 0 0 16 29.5 82 4.22 33.9 2.86 96.47 19.18 100 0 2 13.47 4711 0.62 3311 0 0 16 29.5 82 4.27 34.65 2.92 96.47 19.18 100 0 2 13.65 4794 0.62 3318 0 0 16 29.5 82 4.35 34.43 2.94 96.47 19.18 100 0 2 13.65 4855 0.62 3344 0 0 16 29.5 82 4.43 34.54 2.92 96.47 19.18 100 0 2 13.65 4921 0.63 3350 0 0 16 29.5 82 4.47 35.01 2.92 96.47 19.18 100 0 2 13.78 4982 0.64 3369 0 0 16 29 82 4.54 35.94 2.98 96.47 19.18 100 0 2 13.78 5066 0.64 3395 0 0 16 28.5 82 4.6 35.9 2.94 96.47 19.18 100 0 2 13.78 5124 0.65 3423 0 0 16 28.5 82 4.66 36.36 2.98 96.47 19.18 100 0 2 13.92 5203 0.65 3412 0 0 16 28.5 82 4.74 37.73 2.94 96.47 19.18 100 0 2 13.92 5266 0.65 3458 0 0 16 28.5 82 4.81 37.53 2.98 96.47 19.18 100 0 2 13.92 5329 0.65 3466 0 0 16 28.5 82 4.87 37.88 2.96 96.47 19.18 100 0 2 13.87 5414 0.65 3488 0 0 16 28.5 82 4.97 37.57 3 96.47 19.18 100 0 2 13.87 5472 0.66 3521 0 0 16 28.5 82 5.03 38.9 2.96 96.47 19.18 100 0 2 13.87 5537 0.66 3531 0 0 16 28.5 82 5.1 38.43 3 96.47 19.18 100 0 2 13.59 5603 0.67 3556 0 0 16 28.5 82 5.22 39.35 3.02 96.47 19.18 100 0 2 13.59 5683 0.68 3588 0 0 16 28.5 82 5.28 40.77 3.02 96.47 19.18 100 0 2 13.59 5746 0.69 3604 0 0 16 28 82 5.39 41.63 3.06 96.47 19.18 100 0 2 13.45 5810 0.7 3628 0 0 16 28 82 5.49 41.6 3.08 96.47 19.18 100 0 2 13.45 5891 0.71 3640 0 0 16 27.5 82 5.61 43.4 3.1 96.47 19.18 100 0 2 13.45 5948 0.71 3673 0 0 16 27.5 82 5.72 43.27 3.1 96.47 19.18 100 0 2 13.33 6027 0.73 3685 0 0 16 27 82 5.84 45 3.1 96.47 19.18 100 0 2 13.33 6083 0.74 3716 0 0 16 27 81 5.96 44.87 3.14 96.47 19.18 100 0 2 13.17 6149 0.75 3729 0 0 16 27 81 6.11 46.02 3.14 96.47 19.18 100 0 2 13.17 6228 0.77 3738 0 0 16 26 81 6.25 47.88 3.16 96.47 19.18 100 0 2 13.17 6290 0.78 3746 0 0 16 26 81 6.36 48.96 3.18 96.47 19.18 100 0 2 12.92 6363 0.78 3776 0 0 16 26 81 6.56 49.9 3.22 96.47 19.18 100 0 2 12.92 6438 0.79 3786 0 0 16 25.5 81 6.73 50.83 3.22 96.47 19.18 100 0 2 12.92 6495 0.8 3838 0 0 16 25.5 81 6.9 50.7 3.2 96.47 19.18 100 0 2 12.49 6569 0.81 3852 0 0 16 25 81 7.08 51.5 3.26 96.47 19.18 100 0 2 12.49 6639 0.83 3878 0 0 16 25 81 7.21 52.83 3.26 96.47 19.18 100 0 2 12.49 6694 0.84 3874 0 0 16 24.5 81 7.41 53.88 3.28 96.47 19.18 100 0 2 12.05 6776 0.85 3904 0 0 16 24.5 81 7.6 55.44 3.3 96.47 19.18 100 0 2 12.05 6829 0.86 3935 0 0 16 24 81 7.81 56.71 3.32 96.47 19.18 100 0 2 12.05 6902 0.87 3954 0 0 16 23.5 81 7.99 56.71 3.32 96.47 19.18 100 0 2 11.77 6979 0.88 4015 0 0 16 23.5 81 8.24 57.85 3.36 96.47 19.18 100 0 2 11.77 7054 0.89 4006 0 0 16 23.5 81 8.41 58.47 3.36 96.47 19.18 100 0 2 11.77 7122 0.9 4065 0 0 16 23.5 81 8.64 60.54 3.42 96.47 19.18 100 0 2 11.58 7195 0.92 4054 0 0 16 23 81 8.88 61.33 3.44 96.47 19.18 100 0 2 11.58 7254 0.93 4092 0 0 16 22.5 81 9.09 62.36 3.48 96.47 19.18 100 0 2 11.58 7323 0.95 4118 0 0 16 22.5 81 9.4 64.94 3.5 96.47 19.18 100 0 2 11.52 7398 0.96 4144 0 0 16 22.5 81 9.57 66.55 3.52 96.47 19.18 100 0 2 11.52 7452 0.99 4173 0 0 16 22.5 81 9.9 69.02 3.56 96.47 19.18 100 0 2 11.52 7525 1.02 4216 0 0 16 21 81 10.17 71.49 3.62 96.47 19.18 100 0 2 11.53 7585 1.05 4211 0 0 16 21 81 10.5 74.32 3.64 96.47 19.18 100 0 2 11.53 7667 1.09 4266 0 0 16 20 81 10.87 77.85 3.72 96.47 19.18 100 0 2 11.53 7723 1.12 4268 0 0 16 19.5 79 11.25 80.11 3.76 96.47 19.18 100 0 2 11.61 7797 1.17 4315 0 0 16 19 79 11.7 84.05 3.84 96.47 19.18 100 0 2 11.61 7865 1.21 4340 0 0 16 18.5 79 12.1 87.59 3.9 96.47 19.18 100 0 2 11.61 7934 1.26 4391 0 0 16 17.5 79 12.65 91.73 3.96 96.47 19.18 100 0 2 11.49 8009 1.32 4406 0 0 16 17 79 13.19 97.56 4.04 96.47 19.18 100 0 2 11.49 8073 1.41 4456 0 0 16 16.5 79 14.81 103.43 4.12 96.47 19.18 100 0 2 11.49 8141 1.47 4499 0 0 16 15.5 79 18.8 109.04 4.16 96.47 19.18 100 0 1.77 11.28 8209 1.52 4568 0 0 16 15 79 20.07 116.61 4.22 96.47 19.18 100 0 0 11.28 8262 1.51 4604 0 0 16 14.5 79 21.89 118.86 4.24 94.51 19.18 100 -0.91 -0.91 11.28 8346 1.46 4618 0 0 16 15 79 21.27 113.51 4.18 92.55 19.18 100 0 -1.79 11.02 8417 1.43 4728 0 0 16 15.5 79 20.69 112.11 4.18 91.37 19.18 100 0 -1.46 11.02 8477 1.42 4702 0 0 16 15.5 79 21.52 114.35 4.18 90.59 19.18 100 0 -0.53 11.02 8549 1.43 4801 0 0 16 16 79 21.23 114.06 4.18 89.41 19.18 100 0 -1.16 10.93 8630 1.45 4792 0 0 16 15.5 79 21.31 116.32 4.22 88.24 19.18 100 0 -1.2 10.93 8689 1.46 4889 0 0 16 15.5 79 21.35 117.17 4.22 87.45 19.18 100 0 -0.93 11.23 8757 1.46 4883 0 0 16 15.5 79 21.35 119.71 4.24 86.27 19.18 100 0 -1.05 11.23 8823 1.46 4944 0 0 16 16 79 21.19 120.56 4.26 85.49 19.18 100 0 -0.82 11.23 8895 1.43 5000 0 0 16 16 79 19.8 116.89 4.22 84.71 19.18 100 0 -0.8 11.48 8969 1.43 5067 0 0 16 16.5 79 19.88 118.3 4.24 84.71 19.18 100 0 0 11.48 9025 1.42 5095 0 0 16 16.5 79 18.45 118.3 4.24 86.27 19.18 100 0.84 0.85 11.48 9102 1.42 5126 0 0 16 16.5 79 17.91 121.97 4.26 87.45 19.18 100 0.84 0.89 11.53 9167 1.44 5194 0 0 16 16.5 77 18.06 121.97 4.3 87.45 19.18 100 0 0.87 11.53 9238 1.47 5222 0 0 16 16.5 77 18.16 124.98 4.3 88.24 19.18 100 0 0.73 11.53 9311 1.52 5222 0 0 16 16.5 77 19.38 129.99 4.32 89.02 19.18 100 0 0 11.62 9371 1.53 5274 0 0 16 15.5 77 19.41 135.01 4.36 89.02 19.18 100 0 0 11.62 9445 1.54 5323 0 0 16 15.5 77 20.44 137 4.38 89.02 19.18 100 0 0 11.62 9509 1.54 5392 0 0 16 15.5 77 19.94 137.99 4.38 89.02 19.18 100 0 0 11.49 9580 1.54 5435 0 0 16 15.5 77 20.05 139.32 4.4 88.24 19.18 100 -0.34 -0.33 11.49 9647 1.53 5478 0 0 16 15.5 77 18.1 139.32 4.4 88.24 19.18 100 -0.34 0 11.49 9719 1.52 5478 0 0 16 15.5 77 17.89 139.32 4.42 88.24 19.18 100 0 0.68 11.33 9783 1.54 5519 0 0 16 16 77 17.96 139.97 4.42 89.41 19.18 100 0.68 0.68 11.33 9857 1.54 5605 0 0 16 15.5 77 17.93 146.48 4.42 90.59 19.18 100 0 1.09 11.33 9922 1.55 5664 0 0 16 15.5 77 17.5 146.48 4.42 90.59 19.18 100 0 1.14 11.43 9995 1.54 5664 0 0 16 16 77 17.17 146.78 4.44 91.76 19.18 100 0 1.27 11.43 10062 1.55 5738 0 0 16 16 77 17.02 145.56 4.44 92.94 19.18 100 0 1.27 11.43 10130 1.56 5756 0 0 16 16 77 18.66 149.69 4.48 94.12 19.18 100 0 1.22 11.45 10200 1.55 5756 0 0 16 15.5 77 17.13 149.69 4.48 94.12 19.18 100 0 0.91 11.45 10269 1.55 5836 0 0 16 16 77 17.04 151.15 4.48 95.29 19.18 100 0 0.91 11.45 10334 1.54 5882 0 0 16 16.5 77 17.29 152.61 4.5 96.47 19.18 100 0 1.44 11.37 10406 1.56 5882 0 0 16 16.5 77 18.08 152.61 4.5 96.47 19.18 100 0 1.52 11.37 10472 1.55 5928 0 0 16 16.5 77 17.89 155.53 4.52 96.47 19.18 100 0 1.52 11.37 10544 1.55 6010 0 0 16 16.5 77 18.37 155.23 4.52 96.47 19.18 100 0 1.4 11.37 10612 1.54 6010 0 0 16 16.5 77 19.24 155.23 4.52 96.47 19.18 100 0 0 11.37 10679 1.53 6078 0 0 16 16.5 77 17.23 155.53 4.52 96.47 19.18 100 0 0 11.37 10752 1.52 6178 0 0 16 17 77 17.79 156.11 4.54 96.47 19.18 100 0 1.2 11.37 10824 1.53 6178 0 0 16 17 77 17.09 156.11 4.54 96.47 19.18 100 0 1.65 11.37 10889 1.52 6208 0 0 16 17.5 77 16.98 157.9 4.56 96.47 19.18 100 0 1.65 11.42 10961 1.53 6255 0 0 16 17.5 77 16.98 161.79 4.58 96.47 19.18 100 0 1.65 11.42 11026 1.54 6255 0 0 16 17.5 75 17.93 161.79 4.58 96.47 19.18 100 0 1.65 11.42 11099 1.53 6308 0 0 16 17.5 75 16.76 162.99 4.58 96.47 19.18 100 0 1.65 11.45 11150 1.54 6308 0 0 16 17.5 75 17.5 162.99 4.58 96.47 19.18 100 0 1.63 11.45 11231 1.53 6399 0 0 16 17.5 75 16.98 165.68 4.6 96.47 19.18 100 0 1.63 11.45 11298 1.52 6488 0 0 16 17.5 75 16.82 165.68 4.58 96.47 19.18 100 0 1.65 11.43 11369 1.51 6488 0 0 16 17.5 75 16.69 163.28 4.58 96.47 19.18 100 0 1.65 11.43 11440 1.5 6544 0 0 16 18 75 17.73 163.28 4.58 96.47 19.18 100 0 1.44 11.43 11506 1.5 6544 0 0 16 18 75 16.69 163.28 4.58 96.47 19.18 100 0 1.94 11.43 11576 1.49 6550 0 0 16 18 75 16.71 164.48 4.58 96.47 19.18 100 0 0.94 11.43 11645 1.49 6550 0 0 16 18 75 16.53 164.48 4.58 96.47 19.18 100 0 2 11.43 11715 1.48 6660 0 0 16 18.5 75 16.92 165.38 4.6 96.47 19.18 100 0 2 11.45 11785 1.48 6660 0 0 16 18.5 75 17.31 165.38 4.6 96.47 19.18 100 0 2 11.45 11854 1.47 6744 0 0 16 19 75 16.38 165.08 4.58 96.47 19.18 100 0 2 11.45 11920 1.47 6744 0 0 16 19 75 16.42 165.08 4.58 96.47 19.18 100 0 2 11.45 11988 1.46 6781 0 0 16 19 75 16.38 165.38 4.62 96.47 19.18 100 0 2 11.45 12054 1.46 6781 0 0 16 19 75 16.86 165.38 4.62 96.47 19.18 100 0 2.98 11.45 12126 1.45 6874 0 0 16 19 75 16.44 166.69 4.62 96.47 19.18 100 0 1.98 11.49 12194 1.44 6874 0 0 16 19 75 17.21 166.69 4.62 96.47 19.18 100 0 1.98 11.49 12265 1.44 6951 0 0 16 20 75 16.53 166.69 4.6 96.47 19.18 100 0 2 11.49 12337 1.43 6951 0 0 16 20 75 16.38 166.69 4.6 96.47 19.18 100 0 2 11.49 12404 1.43 7016 0 0 16 20 75 16.18 166.69 4.62 96.47 19.18 100 0 1.83 11.49 12470 1.39 7016 0 0 16 20 75 15.6 166.49 4.62 96.47 19.18 52.16 0 1.83 11.49 12543 0.46 6637 0 0 16 20 75 -0.08 166.49 4.62 96.47 -9.8 0 0 -2 11.52 Last edited by NITROS; 08-30-2012 at 09:36 PM. |
#44 |
Member#: 65140
NWIC
So I have a question and I am going to try and ask it as nicely as possible.
If you aren't going to rev the holy piss out of your destroked 2.5 or your stroked 2.0 why would you not just build a 2.5? The funky thing is those peak power figures are pretty much the same as mine. (different dyno though) I also see 22lbs of boost by 3400 rpm so I am honestly confused why folks that aren't going to rev the piss out of these motors run anything other than a 2.5. Once you pull out a short lock and take it apart, the cost to put in a 2.1 vs a 2.5 is trivial. Please school me... Last edited by BlackEyeII; 08-30-2012 at 10:04 PM. |
#45 |
Member#: 171127
MAIC
Good question, my answer ; probably the cost of head work
#46 | |
Member#: 81102
MWSOC
#47 | |
Member#: 41561
MWSOC
I rev mine out to 8000 rpm. But due to my cams, I start losing power quickly after 7200.
I've had a 2.5 prior to this setup. Running 2.0 heads on a 2.5, I wouldn't say it is best solution. For the amount of money needed in head work alone you can get a fully built 2.1. Also it is a lot better on gas than the 2.5, i went from 200 miles a tank to 250-260. ![]() Quote:
#48 |
Member#: 152680
Vehicle:2002 ej22t 2.35 s363 surged aem ems 6spd wagon |
Starting to build a stroked ej22t (sti crank, probably carrillos, and ots wisecos.. compression will be just over 8:1). Hoping with a s363 t4 and my 280 cams I will be able to make good power to 7500+ without the power falling off, I need to rev to the upper 7's w/ my 07 6 speed in the 1/4
I'm usually against stroking engines.. I like things that rev out! And high torque numbers break things, need better clutches etc. But my 2.0 was making peak HP at around 7800-7900 and pulling flat to 8200+ I really that...but... I don't see any way to swing a larger turbo on a setup like that without revving to 8500+ and I'm not comfortable with the oiling system to do that. Not to mention even worse lag.. So more cubes it is. A little more off boost response wouldn't hurt either... a big turbo 2.0 at 6700ft elevation is pretty laggy and dead down low, so a bit more down there would be nice. Have the ej22t, hopefully I can tear it down this weekend and get the crank, pistons, bearings ordered so I can take it in and have the #5 thrust machined... Last edited by GeneralTJI; 08-31-2012 at 11:37 AM. |
#49 |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
Since you asked...
Event: virtual dyno Location: Southeast Ambient Temp: 75 degrees Elevation: 500ft Weather: Humid Car: 2002 usdm wrx Tuner: fastblueufo Dyno Info: virtul dyno 440 Peak HP at RPM: 387 tq at RPM Hp for stock car: Target AFR: Fuel: Straight e85 Engine/Power Modifications: ej22t stroked 79mm, ej205 heads, bc280 cams, manley crank and rods, pt5857 turbo, pte 1250cc injectors, duel walbro's, tgv deletes, ppg tranny This is just a preliminary tune on conservative timing and conservtive afr. The motor only has 600 miles on it atm. I was really surprized by this turbo. I really didn't think this turbo was 500 hp capable but it is. The hp figures are probably a little low because I couldn't compensate for the taller ppg ger ratio, and my car with two people prol weighs more than 3385 lbs with all the amps speakers and other misc stuff. But its dyno numbers so whatever. I know this thing hauls ass and that's what counts right. ![]() |
#50 | |
Member#: 212154
South East
