#26 |
Member#: 33174
RMIC
Vehicle:We are Open Late! 888-457-2559 Every day! |
If Prova comes out with a GD unit, we will stock it
#27 |
Member#: 33174
RMIC
Got word from Prova. THEY do have a GD wheel. We are trying to get some info on what model years it will fit. We will update as soon as we hear back from Japan.
#28 |
Member#: 154128
Vehicle:1999 Legacy GL 2.0 Red |
^^^FTW
#29 |
Member#: 31399
Vehicle:07 WRX Wagon Urban Gray Metallic |
I just installed this in my 07 WRX and the fit was perfect. As a side note you do not have to remove the airbag at all. Just rest it on top of the steering column as you unbolt and unscrew the wheel and install the new one. Now I do not know which method is safer but, if you are worried about unplugging the airbag you do not have to.
#30 |
Member#: 150034
SCIC
Vehicle:07 wrx satin white |
thats amazing i needa do that
#31 |
Member#: 250258
MAIC
Vehicle:2011 Legacy WRX STI Dark Grey Metallic |
Wow... I wish I could see the install direction on a steering wheel that has that damn bluetooth crap on it. If I get one of these, I want to remove the bluetooth crap. I already have a headset (or 5). Would that be easy to do on this steering wheel?
#32 | |
Member#: 33174
RMIC
#33 |
Member#: 268000
I have alcantara on the seats and they have pretty much retained their color for three years....how does the oils from the hand affect the look of the steering wheel after a few years?
#34 |
Member#: 33174
RMIC
It will get matted down if you have sweaty or oily hands.
But you can use the shoe stuff they sell to bring it back to life. |
#35 |
Member#: 254710
thanks for the write up. installed this on my GD last night
#36 |
Member#: 99591
RMIC
Vehicle:2003 18g w/38EWG PSM(siver) |
can you fit any on a 03 wrx
#37 |
Member#: 33174
RMIC
You should be able to.
First, you would need to install a 05 STi steering wheel and airbag(05 came with the single stage airbag, and the 06+ came with the dual stage). Once the 05 STi wheel is fully installed, you can then install the Prova wheel, using the 05 STi airbag. This would make for an awesome upgrade while still retaining the airbag for safety. ![]() Thanks, Rick |
#38 |
Member#: 292823
SCIC
Vehicle:2003 WRX EJ207 TEC 20G 8cm |
informative
#39 |
Member#: 302997
great write up
#40 |
Member#: 150487
Tri-State
Vehicle:2006 STi silver |
Gotta have on for my GD
#41 |
Member#: 290264
MAIC
Vehicle:2011 STI Sedan OBP |
Can anyone help me troubleshoot my install? I changed my to the prova d today in my 2011 sti and ever since. I have a blinking diff light and my hill assist and vdc light remain on.
I cannot seem to find the problem. ![]() ![]() ![]() Uploaded with ImageShack.us Last edited by DJ_RamBam; 05-12-2012 at 06:51 PM. |
#42 | |
Member#: 33174
RMIC
Couple guy have run into this issue, what you will want to do is make sure that the clock spring is dead center when the wheel is dead center. |
#43 |
Member#: 175060
SCIC
Vehicle:GR STi FYF Squad! |
Subscribed for when i buy mine...... Added it to my RSD wish list....
#44 |
Member#: 279421
I will be installing this once my 13 sti arrives.
one question: What is clock spring? Photo would really help! |
#45 | |
Member#: 33174
RMIC
On the left of the picture, its the black center section around the steering input shaft that the steering wheel splines slide over and has the wires coming out of. ![]() Kirill RallySportDirect.com |
#46 |
Member#: 279421
Thanks, I will check the services manual for details too.
So if I align the new steering wheel with two plastic pin, will it guarantee I put the new one exactly the same position as the one I took off? There're so many teeth on the shaft I'm a bit worry I'm off by one... |
#47 |
Member#: 33174
RMIC
The clock spring can spin free when the wheel is removed. so you need to make sure to park the car straight when you get ready to take the wheel off so its easier to re-align the pins if you on accident bump it out of place
#48 |
Member#: 178811
MAIC
Vehicle:2013 WRB BRZ :banana: |
Time frame on a BRZ wheel?
#49 |
Member#: 279421
Thanks! I think what I'm going to do is when the airbag is off, I will put some tape on the clock spring and it's surroundings so it won't spin around. Then I can just align the new one with those two pins on the clock spring and I know I set it into the correct teeth. Any advise?
#50 |
Member#: 33174
RMIC
| Thread Tools | |
| Display Modes | |
| How To: Change a power steering pump on WRX/STi | Gamble_WRX | Service & Maintenance | 23 | 04-06-2013 08:22 AM |
| How To: Prova Air Oil Separator | RallySport Direct | NASIOC Project Cars | 52 | 10-12-2010 10:26 AM |
| How To: 2008 WRX/STi Coilover Install | RallySport Direct | NASIOC Project Cars | 39 | 12-17-2009 07:29 PM |
| sparco steering wheel adapter wrx sti | bootman | Interior/Dressup/Audio & Security | 1 | 07-07-2009 03:10 AM |
| Spec C MY06 steering wheel on WRX/STI 02.. How? | alfo40 | Interior & Exterior Modification | 6 | 03-06-2006 10:14 AM |
