#1 |
Member#: 242700
Tri-State
Vehicle:2011 Impreza Wrx Sti White |
TPG Tuning Built/Tuned 2011 Subaru Sti Sedan
*INFORMATION* Vehicle: 2011 Subaru Sti Sedan Where: TPG Tuning (Blairsville, Pa) Date: May 4, 2013 Dyno: Mustang 500AWD Tuner: Nate @ TPG Tuning ECU: COBB AccessPort (Speed/Density) Fuel: Pump E90 Psi: 31 WHP: 613 WTQ: 614 *Baseline: Stock Sti 210-215whp* Vigilant Motorsports Track Series Short Block(Refreshed by TPG Tuning): 2.5 Liter STi semi-closed deck case Modified forged EJ257 crankshaft High Performance Main & Rod Bearings Pauter 4340 Chrome-Moly Forged Rods CP Forged Pistons w/ Moly Coated Skirts Fully Balanced & Blueprinted 8,500 Rev Limit Recommended TPG Tuning "Race" head package: STi Dual-AVCS Cylinder Heads Custom Hand Porting Work Ferrea 1mm+ Valves Valves Lapped Into Head Ferrea Drag Racing Springs Ferrea Titanium Retainers Ferrea Retainers & Lockers Kelford 220-D camshafts Flow Bench Tested ARP Case Bolts ARP L-19 Head Studs Full Subaru OEM Gasket Kit Subaru OEM Head Gaskets Cosworth High Pressure Oil Pump Gates Ultimate Timing Kit Tomei Timing Belt Guide Crawford eccentrics pulleys Killer B Oil Pick-up Tube Killer B Windage Tray AMS Performance 900X Turbo Kit: AMS Spec Precision Ball-Bearing Turbocharger V-Band Turbine(Ceramic coated @ Justin's Powdercoating) w/ .82 ar AMS Cast Stainless Steel Up-Pipe w/ 44mm EWG Flange(Ceramic coated @ Justin's Powdercoating) AMS 3" Catless Stainless Steel Downpipe w/ Flex Section Tial 44mm V-Band Wastegate TPG Tuning 4" Intake Sytem w/ K&N Cone Filter Curt Brown Port/Polished Intake Manifold AMS Performance Front-Mount Intercooler w/ 3" Charge-Pipe Full Race "Pro-Stock" 2-Bolt Turbo Manifold Invidia N1 "race" catback exhaust Grimmspeed TGV Deletes Grimmspeed TGV Spacers Perrin Performance Top-Feed Fuel Rails Fuel Injector Clinic 2150cc Injectors Radium Engineering 2x Bosch 044 pumps w/ horizontal surge tank Russell "Pro Classic" -8 & -6 Fuel Lines Fuelab Fuel Pressure Regulator DeatschWerks 65C In-Tank Fuel Pump Hallman RX Boost Controller *DriveTrain* Stock 6-Speed Transmission ACT 6-Puck Clutch Disc ACT XTreme Duty Pressure Plate ACT Street-Lite Flywheel Thanks To The Following: Nate @ TPG Tuning Jason @ TPG Tuning Sean @ Vigilant Motorsports Josh @ Import Image Racing Lance @ Cobb Tuning ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 242700
Tri-State
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by baseballdbk1; 05-06-2013 at 08:28 PM. |
#3 |
Member#: 167338
Tri-State
Vehicle:2000 Aspen rs Rotated mass |
This is such a nice setup! congrats!
#4 |
Member#: 245964
South East
Vehicle:2004 540 AWHP Aspen White |
Looks great.
#5 |
Member#: 37146
MWSOC
Vehicle:2005 Legacy GT Stage tree fitty |
Nice. How's the speed density working out? Any plans to rotate the intake manifold?
#6 | |
Member#: 242700
Tri-State
No need to worry about having a huge MAF housing and it makes drivability amazing! We were originally going to flip the manifold but decided to just go this route for the time being, at least until winter |
#7 |
Member#: 242700
Tri-State
#8 |
Member#: 284835
Vehicle:2010 450+whp DGM STI DOM2.5/e85/Phatron tuned |
Nice build! Looks super clean.
#9 |
Member#: 242700
Tri-State
Last edited by baseballdbk1; 08-07-2012 at 10:20 AM. Reason: added street tuning video! |
#10 |
Member#: 166264
Vehicle:1974 VW 2.2 BW8475 396 WHP @ 25psi |
Beautifull parts, car and build, no question about it, but I am not very impressed by the powerband tbh: only 120 hp at 4K rpm?!
And a powerband of only 1000 rpm (5250-6250) ? Somehow the combination of cams and turbo seems off to me compared to lots of other builds here in PPB. |
#11 | |
Member#: 242700
Tri-State
#12 |
Member#: 242700
Tri-State
Here is the new fuel system we are installing:
#13 |
Member#: 183634
RMIC
Vehicle:02 wrx/ 92 ss Booze fueled :) |
I love seeing threads in which I feel just so poor in comparison! Good work, thing is a beast!
#14 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
That is goood power from pte the 6266
#15 |
Member#: 170602
Vehicle:06 Wrx 6Spd TSBorg Warner S400-Aem-2200s |
^^^ I'd expect it to crack 600 or more once Fuel system is done and you put the kill tune on it. These turbos are impressive.
#16 | |
Member#: 81102
MWSOC
I kind of agree with an earlier poster, maybe a fixed leak or a tuning strategy change could alleviate the small'ish powerband. I hate to be a douche, but it's not looking very good as powerband goes. This graph reminds me of a certain bro tuner, trying to hit xxx whp. Nice setup op, I just wish you got a larger powerband, as u should have. I aplogize if i've offended you, please pm me and I will gladly edit my post. |
#17 |
Member#: 170602
I think there's maybe a boost leak or the tune is just what it is.
This turbo has time and time again made well over 600 whp with high boost. Granted its ^making great power at low boost, just small power band. Maybe the turbo and setup is not in it's efficiency range yet. That or the tune needs brush up. |
#18 |
Member#: 170602
Leak would be visible to the tuner very easily though. I'd imagine he checked the boost plot.
I honestly didn't even look at his power band but easily by 4500 it should be making power and at 25 psi (full boost so far ). |
#19 | |
Member#: 242700
Tri-State
Again, we ran out of fuel and Nate never even messed with the timing map before he lowered the boost down to 21psi(which I am driving the car on right now). For comparison, since I go to Wyotech, I have easy access to an AWD DynoJet so here are some numbers and graphs to compare my low boost maps(21psi): Mustang Dyno: 451whp/409wtq ![]() DynoJet: 484whp/458wtq ![]() I know you guys love comparing dyno numbers :-) |
#20 |
Member#: 170602
Well actually that makes more sense. The timing map comment. Depending on how the map looked he could really wake up for you once some timing down low is added. Definitely good peak power for sure. And that's a great habit on boost leak testing. I should check mine more often.
#21 | |
Member#: 242700
Tri-State
1) We built the car trying to hit the the high 500- low 600whp mark so we knew that we were going to be using a larger size turbo which is why the heads were built to rev 8500rpm 2) During the dyno tuning, Nate knew the car was only using a single in-tank DW300 fuel pump which was going to get maxed out, which happen to be @ 521whp (reason we only ran it out to 6500rpm.) Because of this, Nate never made any changes to the timing map because it would be pointless... 3) After the 521 dyno run, Nate lowered the boost to maintain safe AFR levels @ WOT until the fuel system gets upgraded (being taken care of this week!) 4) Nate tuned the car to 21psi, which made 451whp/409wtq and the car feels absolutely incredible! I trust him 100% with my car because he always tunes for reliable power, not one or the other Last edited by baseballdbk1; 08-08-2012 at 03:55 PM. |
#22 |
Member#: 242700
Tri-State
I finally found a way to download the video from the track last thursday that my friend posted on "facespace"!
My launch was terrible bcz the car was still on winter tires(Put on new my summer tires this past saturday), this was the first time I have driven the car at the track since it was at the Stage 2 setup and the change in power is insane! :-( Low boost(21psi) 12.02 @ 125mph! FOOD FOR THOUGHT!: I had Nate drive the sti last summer with the custom twin-scroll setup using an EVO IX FP "Red" turbo which made 420whp @ 27psi on VP110 and it went 11.36 @ 119mph ;-) |
#23 |
Member#: 133146
Very nice! With 520whp it should trap 130-131mph
#24 |
Member#: 242700
Tri-State
thanks! The ultimate goal is to hit 10.5 with full interior on 28-30psi, which should make high 500whp, so we will see what happens... ;-)
Summit is delivering my new fuel lines and fitting today, so hopefully i will have it back at the track next thursday if we get everything installed and tuned in time! |
#25 |
Member#: 232458
SWIC
Vehicle:2008 STi (OBP) CAMTuned |
Great job!!! It's fast! Lets see what it does when you turn it up!!
