Old 05-30-2012, 03:15 AM   #176
subaru505
Member#: 321645
03 03 rsti
black
still a little confused i am going to do an sti trans swap on my 03 sedan(all i want is the tranny is getting new axles and brakes necesary
subaru505 is offline   Reply With Quote
Old 06-18-2012, 09:01 AM   #177
redmatter
Member#: 323470
Default help with only 5 speed 02-2010 swap
Can someone please explain if there's anything different between the sti/wrx swap problems. I have a 02 wrx with a full 2010 wrx 5 speed swap not the sti 6 speed. How do I fix the hub problem . Is it done the same way so I can use the r180 diff. Or please explain my best route! It's also a wagon if that makes any difference. But no one explains the full 5 speed swap 02 to 2010. What will fix my hub issues? Also I keep reading that the speedometer won't work properly after switching the rear diff. Is that true?
redmatter is offline   Reply With Quote
Old 07-19-2012, 06:22 PM   #178
exxtreme13
Member#: 326636
this is great info. can i follow a similar procedure and list for a 2.2L impreza manual swap?
exxtreme13 is offline   Reply With Quote
Old 07-20-2012, 10:44 AM   #179
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
Originally Posted by Jimmy P View Post
So much reading! I just read all seven pages, and still not 100% sure what I need. Can someone help me out?
I have a 2006 WRX, with STI springs and strut0 installed. I want to do the 6MT swap, while keeping the 5x100 pattern.
Parts I have. All came of 2005 STi
FRONT AXLES
STI clutch
COMPLETE 6-SPEED TRANSMISSION WITH SHIFT LINKAGE
CENTER DRIVESHAFT
STI STARTER
TRANSMISSION CROSS-MEMBER
HELICAL LSD
What else would I need? I swear I read through every post in this thread, but it seems very few of you guys did the swap in a 06-07 WRX so there isn't as much discussion about those years.
Check out the 6spd FAQ, might clear some things up. You may, and should, use as many original parts on your 06.
I kept the 5x100 lug pattern on my bugeye w/ an 07 6spd by using 04 STi hubs and brembos... but every swap is different and the FAQ is very informative, imo.
evo2rex is offline   Reply With Quote
Old 08-08-2012, 08:12 AM   #180
Haywood
Member#: 323890
STI 6 speed - $3000
STI 6 speed clutch fork - included with tranny
STI drive shaft - $35
STI tranny mount - included with tranny
STI axles - $200
STI rear diff - $200
STI clutch, flywheel, and pressure plate - included with tranny
STI 6mt shift linkage - $100 for a brand new short linkage
STI 6mt shift knob - $25
STI 6mt shift lever - $80 for Kartboy SS
STI 6mt shifter bushings - $40 for Kartboy front and rear
So this is just a guess, but would this be all I need for a swap from an 04 STi into an 02 wrx? I already have a stop tech big brake kit. and i want to stay on the 5x100 hubs.
Haywood is offline   Reply With Quote
Old 08-08-2012, 08:28 AM   #181
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Originally Posted by Haywood View Post
...STI axles - $200
Guessing aside. Look into the rear diff and axles you listed with regards to retaining the 5x100 lug pattern. There are a few ways to do what you want but STI rear axles and an R180 will not work with your *WRX* rear hubs. Your existing rear *WRX* axles and an R180 will also not work. Good luck.
*I was making the assumption for your list that you are looking to retain your WRX front and rear knuckle/hub assemblies. If you plan to mix in some 2004 STI knuckles, well that is a different story.
Last edited by JarHarms; 08-08-2012 at 11:00 PM. Reason: I should have been more specific
JarHarms is offline   Reply With Quote
Old 08-08-2012, 12:32 PM   #182
Haywood
Member#: 323890
Originally Posted by JarHarms
Guessing aside. Look into the rear diff and axles you listed with regards to retaining the 5x100 lug pattern. There are a few ways to do what you want but STI rear axles and an R180 will not work with your rear hubs. Your existing rear axles and an R180 will also not work. Good luck.
Thanks! I'll keep looking into it.
Old 08-08-2012, 01:47 PM   #183
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
'04 STi rear diff and axles? Is this what he will need?
prochucker is offline   Reply With Quote
Old 08-08-2012, 08:46 PM   #184
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
Yes, or at least the 04 hubs front and rear
Old 08-09-2012, 09:18 AM   #185
Haywood
Member#: 323890
I went to junkyarddog.com and they found me a 2004 sti tranny with 90,000 for $1,260 shipped.
Old 08-10-2012, 01:02 PM   #186
Subaruben2.5
Member#: 290629
'11 Sti
Hey I put a parts request on the junk yard dog web site and literally 5 minutes later some Pakistani guy calls me repeating everything I said on the request and it did not seem legit what so ever. I asked him some questions and he was hesitant answering all of them especially when I asked where his warehouse was located in Canada, and he also said he could not send me pictures for security reasons. I told him I'd call him back, I won't be.
Subaruben2.5 is offline   Reply With Quote
Old 08-10-2012, 08:38 PM   #187
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
Considering a brand new STI 6spd from subaru is $7,500 (MY07), anything that seems to good to be true probably is.
Old 08-15-2012, 05:42 PM   #188
DreamEvil
Member#: 186435
2005 STI
This is a some what off topic question but I am about to be swapping a sti transmission into my car and I was wondering if these statements are true...
1. Gas mileage will go down? From what I have read the 06 sti trans has a shorter 6th then the wrx does 5th, If this is so how significant of a MPG decrease will I be seeing?
2. Second question is, and I know and agree that any loss is worth the room to grow by doing this swap, How negatively will this swap effect my cars performance? I have heard the sti trans eats up more power so I would actually be losing whp by doing this swap. Additionally in the wrx 5spd I know you can hit 60+mph in second gear where as in the sti's I have heard you need to shift to third I imagine this would effect my 0-60 times as well as 1/4 times? If so how much power would I be losing on estimation and how badly would this effect my 0-60 and 1/4 times? if at all?
I am full aware any light you guys can shed on this would be pure speculation but I would like to see what kind of draw backs I would be facing after doing this swap.
I am not huge on the track but I ran the car once and it ran a 12.6 with the wrx 5 speed to give you a idea of where I am at now. The car also put down 330whp/310wtq, and I currently average a bout 20mpg city, 27mpg high way.
I don't want my questions to make me come off as being immature and only looking at short term things, but this swap is going to be a hard hit on my wallet and I know there wont be any power adder mods going on for a while after doing this. So I would like to see where my car may be at for a few months.
Thanks for any help you guys can provide on these questions!
DreamEvil is offline   Reply With Quote
Old 08-16-2012, 10:51 AM   #189
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
The gearing in the WRX 5TH & the STI 6TH is very close. About 75 MPH @ 3K RPM. I've driven regularly an '02 & '03 WRX, '05 STi, & an '08 WRX. If there's a difference it's not very noticeable
Yes, you will have to shift before 60MPH, but that said, most people still get better 0-60 times in an STi. Lower gear ratio = faster acceleration. I am unsure about the power loss in the 2 drive trains, but again, I wouldn't imagine it would be a great amount. With the better gear ratios, most people will have a better 1/4 mile time, you are still going to wind up at the end in 4th gear.
Below is are the stock gear ratios, I scavenged from somewhere else on NASIOC. Somewhere there is a chart that actually gave you the speeds each 1K RPM in each gear, but I couldn't find it. If people are loosing gas mileage with the swap, I would say it is more likely that their driving & acceleration methods changed when they swapped. The very similar top gear ratios, make it unlikely that there is where they are loosing the MPG.
Factory Gear Ratios for Reference
All-Wheel-Drive 5-speed Transmissions
USDM
3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 3.900FD - '02-'05 USDM WRX
3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 3.700FD - '06-'07 USDM WRX
3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 3.900FD - '08-current USDM WRX
3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 4.444FD - '04-'08 Forester 2.5XT
3.454 / 2.062 / 1.448 / 1.088 / 0.780 / 4.111FD - '04-current Forester non-turbo
3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.111FD - '05-'06 USDM Legacy 2.5GT
3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 3.900FD - '07-'09 USDM Legacy 2.5GT
3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.444FD - '05-'09 USDM Outback 2.5XT
3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 4.111FD - '98-'01 USDM Impreza 2.5RS
3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 3.900FD - '96-'01 USDM Impreza L/OBS
3.545 / 2.111 / 1.448 / 1.088 / 0.780 / 4.111FD - '96-'99 USDM Legacy 2.5GT
3.545 / 2.111 / 1.448 / 1.088 / 0.871 / 4.111FD - '96-'99 USDM Legacy Outback
3.454 / 2.062 / 1.448 / 1.088 / 0.871 / 4.111FD - '00-'07 USDM Outback
3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '08-current USDM Outback
3.454 / 2.062 / 1.448 / 1.088 / 0.780 / 4.111FD - '02-'04 USDM Impreza 2.5RS/'05 Impreza 2.5RS Sport
3.545 / 1.947 / 1.366 / 0.972 / 0.780 / 4.111FD - '93-'94 USDM Impreza 1.8L
3.545 / 2.111 / 1.448 / 1.088 / 0.825 / 3.900FD - '95 USDM Impreza 1.8L
JDM
3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '93-'96 JDM Impreza WRX/STi
3.454 / 2.333 / 1.750 / 1.354 / 0.972 / 3.900FD - '93 JDM Impreza WRX RA
3.454 / 2.333 / 1.750 / 1.354 / 0.972 / 4.111FD - '94-'95 JDM Impreza WRX RA/STi RA
3.454 / 2.062 / 1.448 / 1.088 / 0.825 / 4.111FD - '93-'00 JDM Impreza WRX Wagon
3.083 / 2.062 / 1.545 / 1.151 / 0.825 / 4.444FD - '97-'00 JDM Impreza WRX RA/Type R/STi RA/22B STi
3.166 / 1.882 / 1.296 / 0.972 / 0.738 / 4.444FD - '97-'00 JDM Impreza WRX/STi
All-Wheel-Drive 6-speed Transmissions
3.636 / 2.375 / 1.761 / 1.346 / 1.062 / 0.842 / 3.900FD
- JDM Impreza WRX Spec C/STi/STi Spec C RA/V-Limted/S202/S203/S204/Spec C RA-R
- AUS Impreza WRX STi
3.636 / 2.235 / 1.521 / 1.137 / 0.971 / 0.756 / 3.900FD
- USDM 2007-current Impreza WRX STi
3.636 / 2.375 / 1.761 / 1.346 / 0.971 / 0.756 / 3.900FD
- USDM 2004-2006 Impreza WRX STi
- UK/Europe/NZ Impreza WRX STi
- JDM Legacy 3.0R Spec B
3.636 / 2.235 / 1.521 / 1.137 / 0.891 / 0.707 / 3.900FD
- USDM 2007-2009 Legacy 2.5GT Spec B
- JDM Forester STi
Calculators for Speed and RPM
http://www.car-videos.net/tools/speedrpm.asp
http://www.teammfactory.com/gearcalculator.php
[i]
http://spda-online.ca/modules/tinyco...ite/tc_28.html
http://www.ausubaru.com/wiki/index.p...e=TRANSMISSION
http://www.rexnet.com.au/forum/index...howtopic=29168
http://www.cars101.com/[/i
Old 08-16-2012, 04:26 PM   #190
DreamEvil
Member#: 186435
2005 STI
Thanks a lot def helpful, I was pretty shocked the 6 speeds are shorter haha...This whole time I was wanting that extra gear for less drone lolol...I remember on my Camaro 6th gear at like 60 mph was like 1k rpms hahah it was crazy
Does anyone know how much the sti transmission weighs? I gotta load this thing into my dads little truck and some people have said it is like 300-400lbs others say it is no more then like 150-160 it just feels heavy due to the awkward shape of it?
Old 08-24-2012, 11:56 AM   #191
614evilwrx
Member#: 255607
Exclamation Tired Of Breaking Trannys
I Have A O3 Wrx With A Built 2.5 Swap My Question Is I Want To Go To A Sti Trans . When Looking On Ebay There Are Tons To Pick From I Know Im Going To Have To Swap Alot And Deff Want The Rear Diff From A Sti The Only Thing Im Hung Up On Is I Dont Know What Year This Block Is I Know Its A Ej25 With That Being Said What Trans Packages Will Bolt Up To This Motor , Any Help Thanks
Austin
614evilwrx is offline   Reply With Quote
Old 10-16-2012, 03:04 PM   #192
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
I am also a little overwhelmed. Say I have a 2004 WRX and I was looking to put a EJ20 Version 7 engine, transmission, and rear diff out of a 2001 STi in to my 2004 WRX. Will the axle from from the 2001 drive line work in my 2004 5x100 hubs?
hcsi99 is offline   Reply With Quote
Old 10-16-2012, 04:57 PM   #193
cuztomimportz
Member#: 97904
Austin
I believe there is no difference in what year the block is. 2.5L and 2.0L can all bolt to wrx or sti trans. You just have to change the clutch and flywheel for whatever you are planning to run. As far as i know.
cuztomimportz is offline   Reply With Quote
Old 11-10-2012, 07:52 AM   #194
Bov_Rider
Member#: 142667
2006 STI 07
WRBlue
too many info! 10x.
Bov_Rider is offline   Reply With Quote
Old 12-03-2012, 10:36 AM   #195
atf8611
Member#: 270147
I am interested in doing a transmission swap on my 05 2.5RS, and I can't find the info that I need. Does anyone know how I can configure it so that I don't need to change out my brakes/wheels? I see tons of info for the WRX and the older RS, but nothing for my generation of RS. Thanks for any help.
atf8611 is offline   Reply With Quote
Old 12-05-2012, 04:34 PM   #196
corvallisbattery
Member#: 333030
'05 WRX
Ok so after months of reading and research I'm about to pull the trigger on my swap. Just a couple clarification questions.
2005 wrx 5mt
Looking to swap 06-07 STi trans with all mounts, clutch fork and slave cylinder
Keep wrx rear end
Auto drive shaft
Shift linkage, boot and knob
All I need to complete swap is some circlips and oil seals correct for front axles correct?
Can I reuse my 05 wrx flywheel and clutch?
I plan on buying a dccd controller in the future.
Thanks for the input!
corvallisbattery is offline   Reply With Quote
Old 01-08-2013, 02:14 AM   #197
Cruz5350
Member#: 260061
2005 WRX STi
You can reuse the clutch and flywheel.
Cruz5350 is offline   Reply With Quote
Old 01-18-2013, 12:59 PM   #198
TexasScooby06
Member#: 280980
Been reading through this and still have some questions. I have an 06 WRX TR and just bought an 06 STI 6 speed swap. The swap came with everything I "thought" I needed.
6 speed transmission
Clutch/flywheel
Axels
Hubs (5X114)
knuckles
rear diff
shifter assembly
rotors
driveshaft
DCCD
I was wondering if I had to switch out my current calipers for the brembos? I've heard I only need to buy the rear brembos, but that my front brakes will work on the sti rotors. I have the red painted calipers that came on the model right below the STi (I think they are slighly larger than the base WRX) I have coil overs on there right now, and was wondering if I would have to change those knuckles and if so is it cheap and easy to just buy the bottom part of the strut to hook it up?
Lots of this is speculation from what I've heard. Just trying to get it cleared up. Insight would be greatly appreciated!
TexasScooby06 is offline   Reply With Quote
Old 01-19-2013, 11:07 AM   #199
DCCDPro
Member#: 227549
Just a note that for the DCCD Controller, we don't go with the name spiider any more and
now it is called DCCDPro "Universal Controller". Just to reduce confusion for those who don't know the history.
-Jeff
DCCDPro is offline   Reply With Quote
Old 02-06-2013, 12:22 PM   #200
nimrod8560
Member#: 274267
2004 FXT
Built, FPgreen, & STi 6MT
02-03 JDM v7 6mt tranny, R180, 6mt driveshaft into a 04 FXT 5mt.
Keep/reuse:
- Front axles/hubs
- clutch/flywheel
- slave
- tranny cross member w/spacers
- Group-N tranny 5mt mount
Need:
- r180 axles and hubs
Questions:
02-03 were non-DCCD so I wont need a DCCD controller?
Reuse the FXT 5mt harness?
Reuse the speed censor from the FXT or plug in the JDM?
Reuse the neutral csafety switch on the FXT by rerouting the shorter cable to the 6mt? Will it work on the JDM 6mt?
nimrod8560 is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 07:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 04:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
