Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 08-06-2012, 06:48 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
so turns out my turbo id bad, i need a new one...
any one have a td05 16g.
i may get my current one rebuilt which cost 400
azn0boi04 is offline   Reply With Quote
Old 08-07-2012, 08:17 PM   #2
subywag
Member#: 239731
90s ejs
rainbow
I think I saw a td05 on craigslist in oly...
subywag is offline   Reply With Quote
Old 08-08-2012, 04:20 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Not there anymore.
Alamo turbo quoted me 400$ to do everything.
Anyone have a good condition td05
Old 08-08-2012, 04:25 PM   #4
Aphex28
Member#: 11506
2015 WRX
$400 isn't bad at all.
Most td05's for 20g's that I see sell for somewhere around 250-300. And those are 10+ years old and aren't freshly rebuilt.
Aphex28 is offline   Reply With Quote
Old 08-08-2012, 06:53 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah true, but to me its hard to justify putting $400 into a stock turbo, if i had a FP or gt35 type of turbo that wouldnt be bad,
but i see all these rebuild kits on the internet mostly ebay for td05s for about 50-80
sounds like the one of the main differences is they have balancing machine, and since its a smaller turbo it cant be too out of wack, unless i bent a fin. but i dont think so.
so the way i look at it is:
spend 400$ and get it done professionally, and balanced,
or
spend 50$ and get it done by myself and unbalanced, if it works than YEH for me, if not then ill get it done professionally, but its worth a shot.
right? input? or anyone know where to get a nice rebuild kit.
Old 08-08-2012, 07:49 PM   #6
RallyColtTurbo
Member#: 16819
I've rebuilt TD04s on older Mitubishis and Dodge Colts with the $50 kits. Assumung no damage, if you mark the wheel positions before you disassemble and then reassemble to the marks - your gonna be quite close on the balance.
RallyColtTurbo is offline   Reply With Quote
Old 08-08-2012, 08:23 PM   #7
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
I just order a "genuine"Mitsubishi rebuild kit for 100, hope it's good enough.
Old 08-09-2012, 12:35 PM   #8
s42k1
Member#: 95702
Do you know what is wrong with your turbo. Are you able to identify bad parts vs good ones? Are you able to precisely measure the center housing bore and hone and use oversize bearings if necessary? I have worked at a turbo shop for 8 years and I have seen many people try to rebuild their own turbos only to end up with more problems than they started with. Also balancing is EXTREMELY important! the slightlest imblance can easily destroy your turbo and throw parts of the compressor blades into your engine. Good luck!
s42k1 is offline   Reply With Quote
Old 08-09-2012, 02:01 PM   #9
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Cool, I work at an auto parts store and many people try to fix their own car and some fail as well, but most succeed..
Old 08-09-2012, 03:06 PM   #10
s42k1
Member#: 95702
Also, you can always rebuild the turbo then send the chra to a shop to have it balanced. It's normally around $50.00
Old 08-09-2012, 05:04 PM   #11
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
What exactly is bad about it? Bad bearings, bad seals, damaged fins,spooling issues, issue with coked oil.
Whats wrong with it. If your going to buy a rebuild kit it makes certain assumptions about the condition of your turbo. If you don't give more details about whats wrong no-one can really give you good advice about what to do.
TommyAtomic is offline   Reply With Quote
Old 08-10-2012, 09:23 PM   #12
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
i got one, but it has a 90 on turbo inlet.
Old 08-11-2012, 07:15 AM   #13
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I've also seen poorly rebuilt turbos go bad (once again) but never parts back in the engine. How do they get back in the engine? The downpipe?
GGSimpreza is offline   Reply With Quote
Old 08-11-2012, 11:44 AM   #14
RallyColtTurbo
Member#: 16819
If something on the compressor side fails, then the get sucked into the motor.
The compressor side also happens to be the side made from soft aluminum. That side also has a nut to bolt the wheel to the shaft. Far more to go wrong on the intake side of the unit.
Old 08-12-2012, 03:43 AM   #15
Sasksubie69
Member#: 328665
1995 Subaru sti
Just get it rebuilt professionally to eliminate any future problems
Sasksubie69 is offline   Reply With Quote
Old 09-02-2012, 03:51 PM   #16
maxouni
Member#: 231585
2004 Impreza WRX
Where did you bought "genuine"Mitsubishi rebuild kit ?
maxouni is offline   Reply With Quote
Old 09-25-2012, 10:09 AM   #17
kay95
Member#: 45494
95 impreza L awd
green
At one time you could get rebuild kits off ebay. The kit would include a balance all you have to do was send it in they would balance and mark it then send back. I bought one because I thought it would fit a knock off td05 which they dont. Well they kinda do but I didnt feel like machining everything needed to make it work.
kay95 is offline   Reply With Quote
