Old 05-16-2012, 09:58 PM   #1
Freeze Plug
Member#: 234613
Default WRX sedan to 2.5TS wagon wiring harness swap
I couldnt find much while searching.
I am swapping a 2002 WRX sedan harness into a 2002 2.5TS wagon shell
the front dash and engine harness is fine, however the back half is the problem.
the sedan and wagon have much different tail light wiring etc for the rear, as well as fuel pump controller wiring.
Can I easily merge the existing wagon rear harness to the WRX sedan front harness? The 3 plugs are identical on the passenger side lower B pillar with the exeption of the largest plug having the different wiring.
thanks!
Freeze Plug is offline   Reply With Quote
Old 05-18-2012, 05:11 PM   #2
Freeze Plug
Member#: 234613
anyone? i think i will just splice the taillight connectors
Old 05-18-2012, 06:36 PM   #3
R & H Garage
Member#: 139767
We did a 06' WRX sedan swap into a 2002 TS wagon. You have to use the fuel pump controller from the wrx and splice in additional wiring for the difference in the accessories of the rear of the vehicle (rear hatch door lock actuator, rear wiper, etc etc).
R & H Garage is offline   Reply With Quote
Old 05-18-2012, 06:58 PM   #4
Freeze Plug
Member#: 234613
Ok thanks. Do you know off hand what each of the 3 large plugs that separate the front and rear harness are specifically? They are located at the bottom of the passenger side B pillar
Old 05-30-2012, 08:44 PM   #5
Freeze Plug
Member#: 234613
does anyone have the pinouts for the hatch plugs (2 of them) so I can splice?
Old 08-10-2012, 11:09 AM   #6
nickohlassss
Member#: 326051
how was it swapping the engine and dash harness? Im actually swapping my motor from my totaled ts wagon into a wrx wagon shell.. so I'm thinking ill be swapping both harnesses as well.
nickohlassss is offline   Reply With Quote
Old 04-15-2013, 01:07 PM   #7
Freeze Plug
Member#: 234613
it was fine, just took my time and labeled everything. finally getting to correcting the hatch wiring now
2004 Wrx throwing different codes after a wire harness swap l0rax Service & Maintenance 0 05-03-2012 05:50 PM
Impreza 2.5TS Wagon vs. 2.5RS Wagon specificcivic General Community 6 02-24-2006 10:19 PM
Stock WRX Exhaust on '04 2.5TS Wagon? robertg Normally Aspirated Powertrain 9 06-07-2004 02:38 PM
04 WRX and 02 2.5TS WAGON = same bolt pattern? rp2000r Tire & Wheel 3 11-13-2003 02:50 PM
WRX wagon vs. 2.5TS wagon suspension ? canadiannorton Brakes, Steering & Suspension 2 06-22-2001 03:40 AM
