Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-13-2012, 11:36 PM   #551
black thunder
Member#: 210047
im a scooby guru
really
Originally Posted by thrasher View Post
Question for Black thunder or others with 02-04s...did you have trouble wrapping the piece that surrounds the radio? I've tried twice now, and both have been epic fails. The upper recessed corners are very tough, and the little openings for the hvac stuff are difficult too. Does anyone have good tips on this piece, particularly the hvac cutouts and the upper corners? This is the last piece I plan to do, and all the others came out nice. This one is really frustrating.
Thanks.
J
the two top corners on the radio are coming up (have always been like that to be honest but less noticeable). some of the smaller holes like the ac button and similar are also coming up. to be honest a lot of the corners are coming up. i used heat too to apply. i think the the radio part, the best way is to work from the inside out. i originally laid out the 3m flat on top and pressed down into the corners but i think maybe working inside out from the corners may be better...
the only wrapped peices that are perfect are the ac circular vents. im just going to buy a OEM cf kit from subaru one of these days.
black thunder is offline   Reply With Quote
Old 06-13-2012, 11:39 PM   #552
easterbran
Member#: 307359
'05 STi Stage II
What is a good amount of 1080 to buy from eBay if I want to do the radio bezel and a few other trim pieces near the shifter?
Old 06-14-2012, 06:53 AM   #553
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
It's kind of funny you say that because I removed the Subaru fake cf trim kit to do this, and even though I like the look of the 3m stuff better, I'm probably going to go back to the trim kit if it's going to start lifting off over time.
thrasher is offline   Reply With Quote
Old 06-14-2012, 06:54 AM   #554
thrasher
Member#: 40579
2002 WRX Stage 2+
Probably a 12" x 60" piece. Should be around 20 bucks.
Old 06-14-2012, 06:56 AM   #555
thrasher
Member#: 40579
2002 WRX Stage 2+
Originally Posted by Proper282 View Post
Thrasher, are you using any heat to soften it while you apply it? I just got my roll of 1080 last week and noticed that it's pretty stiff right off the paper, but with only my wife's blowdryer it becomes insanely easy to form around even pretty complex shapes. Not sure if di-noc is as complient.
I've been using a heat gun, which might actually be too much heat. I think ill try the hair dryer before I give up hope completely.
Old 06-14-2012, 01:48 PM   #556
TRooper
Member#: 62422
2006 Lotus Elise-
1.8L of Fury!!
I wrapped my Lenovo T510. It came out pretty cool. I don't like how the factory Lenovo rubberized coating wears and starts to age. The DINOC is very durable and still looks great after 2.5 years.
TRooper is offline   Reply With Quote
Old 06-14-2012, 01:50 PM   #557
easterbran
Member#: 307359
'05 STi Stage II
Old 06-14-2012, 03:29 PM   #558
Jmhm17
Member#: 224097
2012 WRX Hatch - DGM
Stage 1 - Tuned by Bren
are you guys applying this stuff wet or dry? cant see how you can form it once its stuck with a hairdryer.
Jmhm17 is offline   Reply With Quote
Old 06-14-2012, 03:34 PM   #559
Andrew025
Member#: 303408
04 STi
Dry.
The heat makes it bend/conform to different shapes. You don't just slap it on and then heat it. You heat it as you're applying it.
Andrew025 is offline   Reply With Quote
Old 06-14-2012, 04:00 PM   #560
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Try youtube. Thousands of vids showing you how
dirtslayer is offline   Reply With Quote
Old 06-14-2012, 04:07 PM   #561
Jmhm17
Member#: 224097
Originally Posted by Andrew025 View Post
Dry.
ok thats what i figured
Old 06-14-2012, 07:14 PM   #562
O HELLA JDM
Member#: 292267
2002 Impreza WRX
im re-doing mine since i always get frustrated with that part. I would suggest getting 3m 94 primer apply it there to help the adhesion. I should have some pictures soon once i get to working on it
O HELLA JDM is offline   Reply With Quote
Old 07-15-2012, 03:29 AM   #563
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
any problem having this wrapped in 1080?
radiator shroud, so i dunno if that sort of environment would be trouble. looking at the specs on the 3m site, it doesn't seem like it.
builthatch is offline   Reply With Quote
Old 07-16-2012, 01:22 PM   #564
chet24
Member#: 315018
01 2.5RS & 04 FXT
STM/AW
Use the primer and I don't think you should have a problem.
chet24 is offline   Reply With Quote
Old 07-16-2012, 04:44 PM   #565
Jmhm17
Member#: 224097
Make sure you wrap the edges or it will peel up from the heat. 1080 is very soft and formable
Old 07-16-2012, 09:39 PM   #566
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
ok thanks!
Old 07-18-2012, 12:18 AM   #567
BluewaterAWD
Member#: 262210
Originally Posted by f575gtc View Post
Coming from someone who has used this material a ton, I can tell you the back of your seats would be a cake walk to do, this material stretches a good 3 inches before it deforms or starts to rip, you just need to apply slow heat and take your take, those curves on the seats the material would easily conform to.
and to all who may call it rice, you are definitely entitled to your opinion, but I have ton a few pieces on my car that are easily visible from the out side
In person I get completely different results, I have had strangers tell me I had a nice car, some guys in older American muscle cars who I figured would come bash the 4 cylinder turbo complimented me on the car, and at a few subaru meets, I have had people swarming the roof of the car, badges, and interior, asking me to do it for them, so this stuff in person, though not real carbon fiber, still makes the car pop, and unique.
Those are awesome. I want a set of those but I'm not nearly that good to trace out the sti. Wild man!
BluewaterAWD is offline   Reply With Quote
Old 08-10-2012, 05:29 PM   #568
halokilller
Member#: 278870
2005 Stage 2 WRX
Obsidian Black Pearl
Carbon fiber on gd steering wheel, comments?
sorry for bad pics
close up
halokilller is offline   Reply With Quote
Old 08-10-2012, 06:13 PM   #569
ImprezaJake
Member#: 257921
2006 Wrx
SGM
Can someone pm me where I can buy a big sheet of the 1080 3m.. I had bought some off of eBay and it was decent but when I applied alot of heat and stretched it over corners, arm rest etc.. It would bounce back and look all ****ty..
ImprezaJake is offline   Reply With Quote
Old 08-11-2012, 07:21 AM   #570
thrasher
Member#: 40579
2002 WRX Stage 2+
sorry for bad pics
close up
That looks great!!!! Nice work.
Old 08-12-2012, 11:36 AM   #571
halokilller
Member#: 278870
2005 Stage 2 WRX
thanks!
Old 08-12-2012, 04:24 PM   #572
kh15
Member#: 132400
2006 WRX
wow, perfect man!
kh15 is offline   Reply With Quote
Old 08-12-2012, 04:25 PM   #573
halokilller
Member#: 278870
2005 Stage 2 WRX
Originally Posted by kh15 View Post
wow, perfect man!
thanks!
Old 11-17-2012, 09:27 AM   #574
BoostinChick
Member#: 218971
2007 WRX
Went a little different route with the trim pieces. I thought having them all done was a bit TOO much carbon look -
BoostinChick is offline   Reply With Quote
Old 11-17-2012, 01:26 PM   #575
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Whats up with the diff seats?
NutWagon is offline   Reply With Quote
3m carbon fiber wrap xxscaxx Interior & Exterior Modification 13 05-17-2010 12:03 AM
3M Carbon Fiber-look self-adhesive wrap! Mach V Dan Interior/Dressup/Audio & Security 14 04-16-2010 09:11 AM
3M Carbon Fiber Overlay The Database Interior & Exterior Modification 17 04-01-2010 09:59 PM
3M Carbon fiber wrap upperguy General Community 2 07-22-2009 09:48 PM
The Official Carbon Fiber Thread thxmygoodman Member's Car Gallery 4 02-19-2008 10:04 PM
