Old 08-09-2012, 03:50 PM   #476
CatfaceType-R
Member#: 81102
Sorry for the bad luck dude, cheers to a quick fix. Overheating stuff sucks, that's when you cause more issues...
Old 08-09-2012, 05:46 PM   #477
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
who said his car overheating? people just read last 2 posts of the thread and reply with really smart comments
Bariga is offline   Reply With Quote
Old 08-09-2012, 06:54 PM   #478
CatfaceType-R
Member#: 81102
I guess I just thought that because he was road racing and has possibly blown hg's. Usually, it's not hard to think that you will overheat when u are low on coolant and road racing...
Again, best of luck, Alcoolaid
Old 08-09-2012, 07:29 PM   #479
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I was 2 corners away from pit lane when I slipped on my own coolant and almost span out so I was able to get off the track quickly. Needed full lock to correct the oversteer. If it wasn't for the misfiring I would been going much faster and probably wouldn't have been able to save it.
The turn is nicknamed the million dollar corner because a million dollars worth of cars crash there every year.
Old 08-10-2012, 01:45 AM   #480
alcoolaid
Member#: 134949
'07 SWP STi
Old 08-10-2012, 01:53 AM   #481
J3SST3R
Member#: 298926
2007 USDM STI
Props to keeping it on course! Curious to hear the answers when you open her up. GL
J3SST3R is offline   Reply With Quote
Old 08-10-2012, 04:03 AM   #482
ffrawdbacon
Member#: 233506
It looks like u can even see the camera get a tad wet just as u start to loose control from the coolant.
Wish u good luck man and maybe its just a simple as a bad hg vs a sleeve dropping on u.
ffrawdbacon is offline   Reply With Quote
Old 08-11-2012, 02:15 AM   #483
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Nice save man, that could've ended bad.
Cusson is offline   Reply With Quote
Old 08-11-2012, 02:55 AM   #484
WhatTurboLag?
Member#: 243992
2006 WRX TR
Also, Idk if i mentioned this before. You and your car is what inspires me to keep building and enjoying my subaru insted of selling It for something else
WhatTurboLag? is offline   Reply With Quote
Old 08-11-2012, 05:17 PM   #485
jutes85
Member#: 127232
E92 M3
98' Foz
Really? For me it's the opposite. With all these issues I wouldn't even go as far as a built engine and just sell the car for a C6Z.
jutes85 is offline   Reply With Quote
Old 08-11-2012, 08:09 PM   #486
WhatTurboLag?
Member#: 243992
2006 WRX TR
when i broke 3rd gear i thought long and hard about selling it for a new 5.0 mustang or a MKIV supra, but i just couldnt do it. my GF loves my car as much as i do and i need somehting with 4 doors that is safe. and this is it in every way.
also 2 questions for you i might have missed. did the long rod motor, even though its a 2.5 still hurt spool like the 2.3's do?
and which short shifter do you have? the super expensive "competition" group n one or just the regular "sti" one?
Old 08-14-2012, 02:08 AM   #487
alcoolaid
Member#: 134949
'07 SWP STi
We had it on the dyno and it pretty much spooled identical to my old 2.5. Free rev'ing it, it seems to increase and decrease in revs a bit faster. I had it up to 8400rpm in 2nd yesterday and it felt awesome.
It's the group N shifter. I think it's the best shifter you could ever buy! Smooth in every gear, excellent engagement, very little play. Definitely super solid. Pair it with some group n engine mounts and group n transmission mount, even launching in 1st with your hand off the shifter it barely moves left and right.
Old 08-14-2012, 02:17 AM   #488
alcoolaid
Member#: 134949
'07 SWP STi
Update to the motor, found out the bottom rad hose was seeping a bit when I went high rpm. Changed out the stock spring clamp for a worm gear clamp and seems to have solved all my coolant loss problems...
However, I never had an issue before... must be having some higher coolant pressure during boost/high rpm? Possibly because I have a sleeved block? More restriction in flow? The cometic head gaskets did also seem to have smaller coolant passages if I remember correctly. I drove the car pretty hard (trying not to go to jail - 25psi in all gears, high rpm) up to an evening class (on top of a mountain) and I promptly popped the hood and looked at the overflow. It was near the top (aps overflow tank) but didn't overflow. It did bubble every now and then? No coolant loss as far as I can tell anymore.
I think I'm going to have to find somewhere to stress out the car more. Or what I'm thinking is installing a coolant pressure sensor. Kind of like what some pro level cars or wrc cars use. At least if I know coolant pressure spikes during some high boost/rpm pulls, I have a head gasket issue.
It's easy to install and the sensor is relatively cheap... also could come in handy? What do you guys think?
Where should I put it? Upper rad hose? Lower rad hose? Tap the upper coolant crossover pipe?
Old 08-14-2012, 01:48 PM   #489
vica153
Member#: 76586
2006 9-2x Aero
Tapping the coolant crossover pipe just makes it a pain to get at if you need to. I'd do the upper rad hose. It would be interesting to see if pressure goes up linearly with rpm and gets above 1bar at 8000rpm.
vica153 is offline   Reply With Quote
Old 08-14-2012, 07:28 PM   #490
WhatTurboLag?
Member#: 243992
2006 WRX TR
Perfect exactly What i wanted to hear, i forgrt are you running +2 or +4 rods?
So it is worth the 700 bucks ( part number RST-3501C correct*) comparrd to like the sti short throw and the tic holy shift set
Old 08-14-2012, 09:25 PM   #491
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Try Evans coolant. I know a few guys running it on sleeved blocks with great success. That's what i'm going to use in mine when she fires up...
waynoSTI is offline   Reply With Quote
Old 08-14-2012, 10:38 PM   #492
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
nice find!
Old 08-15-2012, 06:00 AM   #493
561wrx
Member#: 166427
03 wrx
Good work! Damn this makes me want make my build even better.
561wrx is offline   Reply With Quote
Old 08-15-2012, 12:02 PM   #494
Eww Evo
Member#: 299687
TT3
06' Wrx Project
You have an amazing car! Makes me want to start working on my track car more often!
Eww Evo is offline   Reply With Quote
Old 08-15-2012, 12:49 PM   #495
Eww Evo
Member#: 299687
TT3
06' Wrx Project
I have been focusing mainly on handling/suspension upgrades for my 06. Would you recommend working on cams and pistons engine wise or what would you recommend. I am about to buy a new radiator and a Motul oil cooler.
Old 08-15-2012, 07:24 PM   #496
alcoolaid
Member#: 134949
'07 SWP STi
Thanks guys!
Depends what plans you have for it. HP goal goals? Minimum I would do drop in pistons, head gasket, arp head studs while you're at it. Cams would be beneficial yes but also depends what turbo you have.
New radiator and I think you mean mocal oil cooler? Make sure to go with -10AN lines!
Old 08-16-2012, 03:01 AM   #497
scrmblr2
Member#: 24631
2005 STI
Default Wow
Anti Lag and equal length header sound awesome!!!!!
And I am nly on page 4!
scrmblr2 is offline   Reply With Quote
Old 08-16-2012, 08:28 PM   #498
smitty5788
Member#: 267886
2011 STI
Evans does not recommend using their waterless coolant on a water cooled turbo.
smitty5788 is offline   Reply With Quote
Old 08-16-2012, 08:48 PM   #499
alcoolaid
Member#: 134949
'07 SWP STi
Wasn't planning on using the stuff but bw sx turbos are only oil cooled.
Old 08-16-2012, 08:55 PM   #500
smitty5788
Member#: 267886
2011 STI
I haven't looked at what you were running but I guess it was more of a heads up statement since I contacted Evans about this before getting my sleeves done.
04 STi Weekend Warrior Blazin Brakes, Steering & Suspension 2 03-07-2008 02:10 PM
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! Neek Off-Topic 45 12-12-2006 09:30 AM
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors GotTurbo Tri-State Area Forum 15 08-11-2006 02:46 PM
Optimum weekend warrior suspension set up? EarlQHan Brakes, Steering & Suspension 15 11-03-2005 01:18 AM
What pads are folks using for daily driver/weekend warrior? Mephiska Brakes, Steering & Suspension 6 06-28-2002 02:08 PM
