Old 08-06-2012, 08:56 PM   #1
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Default 06 WRX logcfg.txt for standalone logging
Trying to get a full list of parameters that actually log correctly for my car.
post #4 has the most up to date working set.
EDIT: FINISHED
ProfessWRX is offline   Reply With Quote
Old 08-06-2012, 08:57 PM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I can't even get throttle% or load to work correctly!
Old 08-10-2012, 09:12 PM   #3
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
next post
Old 08-10-2012, 11:41 PM   #4
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Completed. Don't know if I'll need anymore to log past this.
type=ssmk
;-----------------------------GENERAL---------------------
paramname = TPS
paramid = 0xFF6B62
databits = 16
scalingrpn = x,0.0022706535,*
paramname = MPH
paramid = 0x000010
databits = 8
scalingrpn = x,0.621371192,*
paramname = RPM
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
;paramname = LOAD%
;paramid = 0x07
;scalingrpn = x,0.3921569,*
paramname = LOAD g/rev
paramid = 0xFF6B44
databits = 16
scalingrpn = x,.00006103516,*
;paramname = IAT
;paramid = 0x000012
;databits = 8
;scalingrpn = 32,9,x,40,-,*,5,/,+
paramname = ECT
paramid = 0x000008
databits = 8
;------------------------------KNOCK------------------------
paramname = Timing
paramid = 0x000011
databits = 8
scalingrpn = x,128,-,2,/
;paramname = IAM16
;paramid = 0xF9
;scalingrpn = x,0.0625,*
paramname = IAM
paramid = 0xFF6B71
databits = 8
scalingrpn = x,.0625,*
;paramname = EGT
;paramid = 0x000106
;scalingrpn = x,40,+,9,*,32,+
paramname = Knock Count
paramid = 0xFF77D4
scalingrpn = x,1,*
paramname = Feedback_Knock
paramid = 0xFF6B6C
scalingrpn = x,0.3515625,*,45,-
paramname = Fine_Learning_Knock
paramid = 0xFF6B6F
;-----------------------------BOOST---------------------------
paramname = PSI
paramid = 0x24
scalingrpn = x,128,-,0.145098,*
paramname = TargetPSI
paramid = 0xFF6B58
databits = 16
scalingrpn = x,760,-,0.01933677,*
paramname = WGDC
paramid = 0x30
paramname = TurboDyn_Integral
paramid = 0xFF6B32
databits = 16
scalingrpn = x,0.00390625,*,50,-
paramname = TurboDyn_Proportional
paramid = 0xFF6B34
databits = 16
;--------------------------------A/F------------------------------
paramname = MAF volts
paramid = 0x00001D
databits = 8
scalingrpn = x,50,/
paramname = MAF g/s
paramid = 0x13
databits = 16
scalingrpn = x,0.01,*
paramname = O2
paramid = 0xFF6B5A
databits = 16
scalingrpn = x,.0001220703,*,14.7,*
paramname = A/F_Correction
paramid = 0x000009
databits = 8
scalingrpn = x,128,-,100,*,128,/
paramname = A/F_Learning
paramid = 0xFF6B3C
databits = 16
scalingrpn = x,.04882812,*,50,-
paramname = CL/OL
paramid = 0xFF9299
databits = 8
scalingrpn = x,6,+
;----------------------------triggers--------------------------
paramname = defogger_sw
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
conditionrpn = defogger_sw,1,==
action = start
conditionrpn = defogger_sw,0,==
action = stop
;Change xxx and yyyy to your desired
;RPM settings
;conditionrpn = Engine_Speed,xxx,>
;action = start
;conditionrpn = Engine_Speed,yyyy,==
;action = stop
;-----------------------WIDEBAND------------------------
;type=inno
;paramname = inno.afr
;paramname = inno.lambda
Old 08-11-2012, 10:20 AM   #5
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
It's 100x easier to use logcfg utility to create the config file rather than to manually maintain the list of parameters. The utility will read the ECU defs from RR and create the file accordingly. Download one from here:
http://forums.openecu.org/viewtopic.php?f=57&t=4396
Ziggyrama is offline   Reply With Quote
Old 08-11-2012, 06:18 PM   #6
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I had tried that link before and the file didn't link properly. I've pretty much gotten everything that I need to work correctly. But not all of the supposed available parameters work. It seemed like most of the 2bytes worked for me where the others didn't at all.
Old 08-11-2012, 09:12 PM   #7
Ziggyrama
Member#: 53665
Focal Active Setup
Try this one: link
Old 08-12-2012, 02:28 AM   #8
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Try this one: link
Thanks, I think I have it pretty much dialed in, but I'll definitely give it a try to see if it can make sense of the other parameters.
