#1 |
Member#: 320993
Vehicle:2005 Sti Aspen White |
i have a 05 sti and i been datalogging and wont hit peak boost it peaks at 10psi with stage 2 HWG. any questions or ideas would be appreciated. thanks in advance.
MODS -Cobb sf intake w/ samco after maf -Samco turbo inlet -Turbo Xs fmic/ricr bov -SPT CBE -No name DP link to datalog: https://docs.google.com/spreadsheet/...lczVWZnVGxkd1E
#2 |
Member#: 73884
International
Vehicle:2005 STi 2006 Evolution MR |
link does not work.
~9-10# is WG spring pressure. You either have something wrong with your boost control system or you have a leak. Check for leaks and proper setup of components in the boost control system. Cobb has an article on their website that explains how the boost control system works. When did you notice the problem? Just after the install of the FMIC? |
#3 | |
Member#: 320993
There's no leaks and it happend after I flashed it to stage 2 and removed the mbc |
#4 | |
NASIOC Manufacturer
Member#: 4803
http://www.cobbtuning.com/Technical-...es-s/70674.htm Bill |
#5 | |
Member#: 320993
#6 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#7 |
Member#: 320993
Bad BCS problem fix. please Delete
