Old 12-04-2009, 09:59 AM   #26
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by tedsan126 View Post
I know that the compression ratio will be lowered but i have decided that im not going to do the swap, too many things are going to need to be changed. I am pretty sure that i am going to just do a complete swap. To do the head swap im going to need to change the ecu because it wont run the DOHC setup, i will have to change the intake manifold, I will have to get different pistons and a whole slew of other modifications. The EJ25D is a direct bolt on. but not plug in. the ecu will need to be changed but in the end i think it will be an easier swap. Plus the EJ25D has a stock 30 more horsepower.
You don't have to change the ECU or harness. Everything will just plug in and the car will run.
Old 12-04-2009, 10:53 AM   #27
tedsan126
Member#: 231079
98 Legacy
are you sure because i have been told both. Some say it will bolt right on but not wire right up and some say it will
tedsan126 is offline   Reply With Quote
Old 12-04-2009, 11:00 AM   #28
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes. I'm sure. I've done many engine swaps. I do the reverse of what you want to do all the time. I put the EJ22 in place of the EJ25 all the time. Same wiring.
Old 12-04-2009, 02:28 PM   #29
tedsan126
Member#: 231079
98 Legacy
Okay cool, now my problem with the 2.5 is that it goes through head gaskets like it is its job, in your experience have you seen this and what kind of power gains am i lookin at with the Ej25 swap plus intake,full cat back exhaust, headers, lightweight flywheel, lightweight crankpulley, MSD ingnition, iridium plugs, new wires etc...
Old 12-04-2009, 02:50 PM   #30
69subaru360
Member#: 159682
1995 WRX
2015 F150
Just about every 2.5 phase 1 has the head gaskets go at some point. The newest MLS gaskets from subaru don't go bad. The older gaskets either have a black coating on the outside or a brown core. Those are the ones that go bad. The new ones are all silver. You might gain 30 hp over the 2.2. It's not worth it IMO as far as gain per $ spent, but it will work.
Old 12-04-2009, 03:04 PM   #31
tedsan126
Member#: 231079
98 Legacy
ultimately what im looking to do is get significantly more power out of the engine and I want to be sure that the engine I choose to swap in can do this for me. With the 2.5 and all of those mods how much do you think i can gain over the stock 2.2. and if its not enough to warrant swapping the engines. what engine would you reccommend for a swap
Old 12-04-2009, 03:57 PM   #32
Storm
Member#: 5218
96L Most Over-
Developed Beater
In my opinion, ensure the block and head mating surfaces are flat, give them a good scrubbing with scotchbrite, and use Cometic headgaskets. EJ25 problems do not come back (for me anyway).
Jay
Old 12-05-2009, 02:47 PM   #33
tedsan126
Member#: 231079
98 Legacy
Yea I decided im gonna go with the EJ25d swap over just swapping the heads on to a ej22. too much work. When I get my EJ25d im looking to do some internal work to make it run faster and better. Cams, pistons, have the valves ported and polished etc... Any suggestions.
Old 12-05-2009, 04:01 PM   #34
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Originally Posted by Storm View Post
Whoever said that a SOHC ECU cannot run a DOHC motor has not tried.
Jay
+ 1
Did many conversions on Legacy I and II and they all ran/run great.
Marnix is offline   Reply With Quote
Old 12-05-2009, 05:22 PM   #35
tedsan126
Member#: 231079
98 Legacy
what about any internal work? ideas?
Old 12-10-2009, 12:24 AM   #36
tedsan126
Member#: 231079
98 Legacy
I decided to just swap the EJ22 out of my 95 legacy sedan for most likely an EJ25D. Im looking at engines now and I was wondering if I could get some feedback on some before i buy anything.
http://www.jdmenginedepot.com/jdm_en...Forester_EJ25D
http://www.jdmenginedepot.com/jdm_en...andrail_EJ20TT
Old 02-26-2011, 07:59 PM   #37
StevoParko
Member#: 275173
1990 Legacy Wagon
Silver/Grey
Default SOHC to DOHC
http://www.bestofjdm.com/JDM-ENGINE-...jdmsubaru3.htm has an ej22 dohc complete long block you can always think on that.
on another note, I have a 90 legacy wagon ej22 SOHC with a bad head gasket and 200k+ miles on it and I am thinking about just replacing the whole thing with a ej22 DOHC longblock from best of jdm. Will my ECU run the DOHC version of the ej22 or should I keep searching for the original SOHC that I already have in it. If it will work what issues might I run into.
Thanks for the input.
StevoParko is offline   Reply With Quote
Old 09-04-2011, 05:59 PM   #38
tdrrally
Member#: 91562
1995 impreza,awd
reddish
i have a 90 leggy that needs an engine so keep up the info
2.5 vs 2.2 ,sohc vs dohc?
tdrrally is offline   Reply With Quote
Old 08-13-2012, 02:51 AM   #39
Daniel Peralta
Member#: 328963
1995 Impreza
Green
Hey I have a ej22 with dual port head. I just bought a 02 wrx ecu,intake manifold with injector, heads and cams for $135. Now my question is what i have to do. To run them on my ej22 short- block
Daniel Peralta is offline   Reply With Quote
Old 08-13-2012, 12:37 PM   #40
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Rule #1: Start a new thread.
But to answer your question you will have to rewire your whole car...
SOHC to DOHC swap Homemade WRX Subaru Conversions 82 01-15-2010 05:43 PM
sohc and dohc heads midnight2.5rs-t Subaru Conversions 3 01-19-2008 04:26 PM
SOHC vs. DOHC heads Brain G Normally Aspirated Powertrain 15 06-07-2005 07:19 PM
EJ22 DOHC head swap Millencolin! Subaru Conversions 2 06-06-2005 04:27 PM
Subaru EJ25 SOHC & DOHC head components (valvetrain, cams etc) iON Performance Inc Vendor 'For Sale' Classifieds 21 03-09-2004 02:34 AM
