#476 |
Member#: 81102
MWSOC
Sorry for the bad luck dude, cheers to a quick fix. Overheating stuff sucks, that's when you cause more issues...
#477 |
Member#: 179846
NWIC
Vehicle:07 STi MPS Build EFR 7670 TS |
who said his car overheating? people just read last 2 posts of the thread and reply with really smart comments
#478 | |
Member#: 81102
MWSOC
Again, best of luck, Alcoolaid |
#479 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
I was 2 corners away from pit lane when I slipped on my own coolant and almost span out so I was able to get off the track quickly. Needed full lock to correct the oversteer. If it wasn't for the misfiring I would been going much faster and probably wouldn't have been able to save it.
The turn is nicknamed the million dollar corner because a million dollars worth of cars crash there every year. |
#480 |
Member#: 134949
VIC
#481 |
Member#: 298926
W. Canada
Vehicle:2007 USDM STI Satin White Pearl |
Props to keeping it on course! Curious to hear the answers when you open her up. GL
#482 |
Member#: 233506
It looks like u can even see the camera get a tad wet just as u start to loose control from the coolant.
Wish u good luck man and maybe its just a simple as a bad hg vs a sleeve dropping on u. |
#483 |
Member#: 95695
SCIC
Vehicle:2003 WRX Sedan A Class |
Nice save man, that could've ended bad.
#484 |
Member#: 243992
MWSOC
Vehicle:2006 WRX TR WRB |
Also, Idk if i mentioned this before. You and your car is what inspires me to keep building and enjoying my subaru insted of selling It for something else
#485 | |
Member#: 127232
W. Canada
Vehicle:Do You Even Subaru |
#486 |
Member#: 243992
MWSOC
when i broke 3rd gear i thought long and hard about selling it for a new 5.0 mustang or a MKIV supra, but i just couldnt do it. my GF loves my car as much as i do and i need somehting with 4 doors that is safe. and this is it in every way.
also 2 questions for you i might have missed. did the long rod motor, even though its a 2.5 still hurt spool like the 2.3's do? and which short shifter do you have? the super expensive "competition" group n one or just the regular "sti" one? Last edited by WhatTurboLag?; 08-11-2012 at 08:19 PM. |
#487 | |
Member#: 134949
VIC
It's the group N shifter. I think it's the best shifter you could ever buy! Smooth in every gear, excellent engagement, very little play. Definitely super solid. Pair it with some group n engine mounts and group n transmission mount, even launching in 1st with your hand off the shifter it barely moves left and right. |
#488 |
Member#: 134949
VIC
Update to the motor, found out the bottom rad hose was seeping a bit when I went high rpm. Changed out the stock spring clamp for a worm gear clamp and seems to have solved all my coolant loss problems...
However, I never had an issue before... must be having some higher coolant pressure during boost/high rpm? Possibly because I have a sleeved block? More restriction in flow? The cometic head gaskets did also seem to have smaller coolant passages if I remember correctly. I drove the car pretty hard (trying not to go to jail - 25psi in all gears, high rpm) up to an evening class (on top of a mountain) and I promptly popped the hood and looked at the overflow. It was near the top (aps overflow tank) but didn't overflow. It did bubble every now and then? No coolant loss as far as I can tell anymore. I think I'm going to have to find somewhere to stress out the car more. Or what I'm thinking is installing a coolant pressure sensor. Kind of like what some pro level cars or wrc cars use. At least if I know coolant pressure spikes during some high boost/rpm pulls, I have a head gasket issue. It's easy to install and the sensor is relatively cheap... also could come in handy? What do you guys think? Where should I put it? Upper rad hose? Lower rad hose? Tap the upper coolant crossover pipe? |
#489 |
Member#: 76586
NWIC
Vehicle:1994 GF6 |
Tapping the coolant crossover pipe just makes it a pain to get at if you need to. I'd do the upper rad hose. It would be interesting to see if pressure goes up linearly with rpm and gets above 1bar at 8000rpm.
#490 | |
Member#: 243992
MWSOC
So it is worth the 700 bucks ( part number RST-3501C correct*) comparrd to like the sti short throw and the tic holy shift set |
#491 |
Member#: 162151
E. Canada
Vehicle:2.6L BLUE THUNDER LOW&WIDE&SHAVED |
Try Evans coolant. I know a few guys running it on sleeved blocks with great success. That's what i'm going to use in mine when she fires up...
#492 |
Member#: 179846
NWIC
#493 |
Member#: 166427
South East
Vehicle:03 wrx |
Good work! Damn this makes me want make my build even better.
#494 |
Member#: 299687
RMIC
Vehicle:06 Impreza Wrx Track car in the making. |
You have an amazing car! Makes me want to start working on my track car more often!
#495 |
Member#: 299687
RMIC
I have been focusing mainly on handling/suspension upgrades for my 06. Would you recommend working on cams and pistons engine wise or what would you recommend. I am about to buy a new radiator and a Motul oil cooler.
#496 | ||
Member#: 134949
VIC
New radiator and I think you mean mocal oil cooler? Make sure to go with -10AN lines! |
#497 |
Member#: 24631
MWSOC
Vehicle:2005 STI OBP |
Anti Lag and equal length header sound awesome!!!!!
And I am nly on page 4! |
#498 |
Member#: 267886
MWSOC
Vehicle:2011 STI DGM |
#499 |
Member#: 134949
VIC
Wasn't planning on using the stuff but bw sx turbos are only oil cooled.
#500 |
Member#: 267886
MWSOC
I haven't looked at what you were running but I guess it was more of a heads up statement since I contacted Evans about this before getting my sleeves done.
| Thread Tools | |
| Display Modes | |
| 04 STi Weekend Warrior | Blazin | Brakes, Steering & Suspension | 2 | 03-07-2008 02:10 PM |
| So I just found out I need hand surgery tomorrow...Weekend warriors be careful! | Neek | Off-Topic | 45 | 12-12-2006 09:30 AM |
| Attention Car Enthusiast’s, Car clubs, & Weekend Warriors | GotTurbo | Tri-State Area Forum | 15 | 08-11-2006 02:46 PM |
| Optimum weekend warrior suspension set up? | EarlQHan | Brakes, Steering & Suspension | 15 | 11-03-2005 01:18 AM |
| What pads are folks using for daily driver/weekend warrior? | Mephiska | Brakes, Steering & Suspension | 6 | 06-28-2002 02:08 PM |
