Old 08-16-2012, 02:38 AM   #1
socalLGT
Member#: 89752
08 STI
Default Next Gen is here: Full-Race/Borg-Warner EFR7163 in stock location. 440whp/443wtq
Car: 2008 Subaru Impreza WRX STi
Tuner: Me, Paul Leung of YimiSport Tuning
Dyno Info: Dynojet 424X
Ambient Temp: 95*F
Elevation: about 1300' ASL
Transmission: Stock 6MT
Gear: 4th
Peak HP at RPM: 440whp @ 5900rpm (E85). 350whp @ 5900rpm (CA 91 octane)
Peak Torque at RPM: 443ft/lbs @ 3600rpm (E85). 353ft/lbs @3600rpm (CA 91 octane)
Baseline hp/tq for a stock on same dyno: 230HP/255tq - 2008 STi
Target Boost: 25 PSI (E85), 22 PSI (91 Octane)
Target AFR: 12:1 (gasoline scale on E85), 10.9:1 on 91 octane
Fuel: E85 and CA 91 octane pump gas
Mods:
- Full-Race uppipe and catted downpipe to locate a Borg Warner EFR7163 (2013 release turbo, one of only a handful that have made their way out in to the world) in stock location. Ready to bolt up to all OEM or aftermarket parts that will fit the stock turbo (inlets, TMIC's, FMIC's etc...)
- Fujitsubo Legalis R catback (with the 2.5" taper intact)
- Custom YimiSport 73mm CAI
- Custom YimiSport FPR kit
- APS turbo inlet pipe
- Grimmspeed hybrid EBCS/MBC boost control
- Deatschwerks 1000cc injectors
- Synergy 300lph fuel pump
- Cobb AP
The narrative that no one cares about:
Stock motor (60k miles), stock TMIC and stock exhaust manifold. Basically just enough mods to supply enough fuel, sample the incoming air and get it out the back of the car as quietly and cleanly as possible
Every so often a turbo company introduces a product that "spools like small turbo X, but make power like BIG turbo Y". Physics being the b!tch that it is, has usually proven such claims to be more hype than reality So when Geoff from Full-Race told me about a new turbo that would spool like a turbo 10lbs/min smaller than it's rated flow, my interest was piqued, but my BS meter was similarly pegged. I'll let you guys be the judge, but I think even on my less than fully supported test platform, Borg Warner and Full-Race have come pretty close to their claim.
I have always wanted to have a Subaru that made 500wtq before 4000rpm and still made over 450whp. I'm not quite there yet, but with a couple more bolt-on mods I can easily see it happening even on the stock block. In the mean time, I've been enjoying one hell of a broad powerband and nearly instantaneous boost recover all in a damn near stock appearing package
Pics:
Dyno Graphs:
Pump and E85
Pump and E85 compared with a typical Stage 2 08+ STI
Damn near stock turbo spool with nearly 200whp more by redline... not too shaby
socalLGT is offline   Reply With Quote
Old 08-16-2012, 03:00 AM   #2
bjohnson_55
Member#: 216580
wow pretty amazing results. I think P&L has some competition with their new kit!
bjohnson_55 is offline   Reply With Quote
Old 08-16-2012, 03:51 AM   #3
rasheedn
Member#: 123333
2009 STi
DMG
wow this looks amazing
where can i get one ?
i see no bov bpv ?
any pictures of the up pipe and downpipe ?
any problems with boost like others had controlling boost?
rasheedn is offline   Reply With Quote
Old 08-16-2012, 04:15 AM   #4
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
I believe without a bpv it can hold boost better with high boost numbers, because the boost will start to open it. And i heard its easier to tune without it
SoCal_Scooby is offline   Reply With Quote
Old 08-16-2012, 04:24 AM   #5
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
Originally Posted by rasheedn
i see no bov bpv ?
I believe that the efr turbos have the bpv built into the Turbo. I would post a pic but I'm on my phone. Google search it or look in the other efr threads. I could be dead tired and completely wrong too.
Black07STiGuy is offline   Reply With Quote
Old 08-16-2012, 04:28 AM   #6
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
I think you might be wrong. I'm not positive though. They make bpv with interchangable springs for full race setups. I think on our cars, it would be dangerous not to purge the unused pressure somehow. I think diesel trucks are the only ones that have No bpv/bov period.
Old 08-16-2012, 04:39 AM   #7
rasheedn
Member#: 123333
2009 STi
DMG
and crawford cars as i remember
ur right efr do have an internal valve but this is a stock location unit so maybe its different ?
i donno just guessing
Old 08-16-2012, 07:50 AM   #8
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Awesome! I believe perrin (?) tested the EFR7064 to be later spooling then stock and the even smaller one (6458?) spooled faster, but now this 7163 spools as fast as stock AND gives wayyyy more flow/hp!
What made this happen all of a sudden as a 7163 looks like its the same-ish dimension as a 7064 and parts are as light-weight as possible already with the EFR line? More aggressive trim?
320 hp at 4000 rpm! Wow!
Beetspeed is offline   Reply With Quote
Old 08-16-2012, 09:17 AM   #9
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
^^^ I believe it IS essentially a 7064 but keep in mind that the 7064 does not come with the small turbine housing which is .64 A/R I believe.
It seems they have transplanted the 7064 CHRA into the 6758-type Turbine housing.
Jasper.
jkopinga is offline   Reply With Quote
Old 08-16-2012, 09:56 AM   #10
mekilljoydammit
Member#: 258151
Some articles I'm seeing on it are talking about what's actually a new turbine wheel shape to extract more energy from the exhaust gas at lower flow levels. I just think the whole thing's pretty sexy.
mekilljoydammit is offline   Reply With Quote
Old 08-16-2012, 10:10 AM   #11
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
That's a lot of torque for 3600 rpm.
And 300whp.
Wow.
I want it.
todeswalzer is offline   Reply With Quote
Old 08-16-2012, 04:05 PM   #12
socalLGT
Member#: 89752
08 STI
i see no bov bpv ?
Can't get one quite yet till Borg Warner officially releases the turbo, but I do know that Full-Race is all set on their end with the uppipe/downpipe and ancillary bits. As for the BOV/BPV, all EFR turbos have one integrated in to the compressor cover, hence the block off plate on my stock TMIC
No boost control issues at all. I have the high pressure actuator and that combined with the hybrid Grimmspeed boost control allowed me to dial in the exact amount of boost I was looking for with rock steady boost control.
Jasper.
Not exactly. The EFR7163 is indeed a B1 frame turbo (like the 6758) which is what allows it to be located in stock location. However the compressor and turbine wheels are all new. I believe the turbine wheel in particular uses mixed flow geometry. The exact physics are a bit beyond my full understanding so perhaps the folks at Full-Race will chime in on that. Suffice to say that the response of the turbo shows the value of the new wheels.
Also just for clarity sake, the EFR7163 I have on my car sits in basically stock location but it is NOT a bolt-on turbo (ie: bolts to OEM fitment uppipes and downpipes). The turbo has a T25 inlet flange and a 3" v-band discharge. The Full-Race uppipe and downpipe are what allows it to fit in stock location.
Here are a couple more pics of the turbo, uppipe and downpipe:
The last 2 pics of the DP show a few extra welds as I made some adjustments to the original prototype for better fitment and sent them back to Full-Race so they could adjust their fixtures. I have the revised DP and UP on my car now and they fit great.
Old 08-16-2012, 04:56 PM   #13
CatfaceType-R
Member#: 81102
Hey paul, post more!
Carmi
Old 08-16-2012, 06:07 PM   #14
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Great to see. Maybe I should have waited I wanted to do a stock location 6758 twin scroll. Do you know if there are any plans by BW to and TS to the smaller range and full race to offer a "stock location" ts option?
thefoos is offline   Reply With Quote
Old 08-17-2012, 12:56 AM   #15
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Wow! That setup spools up crazy fast!
Fierysun is offline   Reply With Quote
Old 08-17-2012, 02:56 AM   #16
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
super spool, thats nuts, super cool work
Kastley85891 is offline   Reply With Quote
Old 08-17-2012, 10:09 AM   #17
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Which size is this turbo? Which one is the 67mm?
CKxx is offline   Reply With Quote
Old 08-17-2012, 11:57 AM   #18
socalLGT
Member#: 89752
08 STI
The B1 frame turbos have always been available in IWG twinscroll configuration. I do not know for sure if the 7163 will be for sure, but I would expect so. As to whether or not Full-Race can or will do a stock location TS kit that is a question best left to them.
71mm compressor OD and 63 mm turbine OD. The EFR6758 has a 67mm compressor.
Old 08-17-2012, 12:22 PM   #19
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
This is pretty nice so I'm guessing this would do about 370-390 on 93 this is pretty awesome it pretty much makes it worthless to consider a GTX30 period. Easy installation and internal WG and stock spool this is very niiice
SUBARIFFIC is offline   Reply With Quote
Old 08-17-2012, 12:49 PM   #20
socalLGT
Member#: 89752
08 STI
I think if I had better intercooling and the car was catless I could have made 370+whp on 91 octane. My car has actually never been a particularly strong one and mod for mod was usually 5-10whp down compared to other similar cars I've tuned. So long story short, I think this turbo should be easily capable of hitting 380-400whp on 93 octane if all the moons align right.
As for the comparisons to the GT series turbos, the biggest difference is in the turbine wheels. The Garrett GTX compressor wheels are very nice but are still paired with some relatively old tech turbines. They work nicely as well but the newest EFR stuff really does seem at the very least a significant evolution of turbo technology.
Old 08-17-2012, 01:05 PM   #21
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
- Is there a realistic estimate on availability?
- Does this frame match any existing (I use that term loosely) EFR turbos? Could we use the UP / DOWN setup with a 6758, for example, then move to a 7163 in a few years when it's available?
I really like the idea of an EFR setup that uses the TMIC.
Old 08-17-2012, 01:06 PM   #22
Paidfor
Member#: 267815
Be in awe
dont hate .)
OMG!!!! I want i want i want
Paidfor is offline   Reply With Quote
Old 08-17-2012, 02:10 PM   #23
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
Now if they could make one that will mate up to the factory twinscroll header, new uppipe portion and downpipe obviously, twinscroll EFR anyone?
My 8k rpm would be happy!
I'm willing to be a guinea pig
K1WRC is offline   Reply With Quote
Old 08-17-2012, 02:28 PM   #24
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Looks good
Old 08-17-2012, 04:27 PM   #25
socalLGT
Member#: 89752
08 STI
I have no idea on availability of the EFR7163, but it is a B1 frame turbo just like the 6758 so I don't see any reason why you couldn't use one with the FR UP/DP now.
