Old 06-30-2012, 11:38 PM   #51
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Originally Posted by Dadowhip
Im having the saving issue trying to work it out using bustedfinger cable and windows 7
English please... From the top.
Old 07-27-2012, 05:32 PM   #52
bjohnson_55
Member#: 216580
bump.
Does RC8 work the best with it?
Anyone post up pics/schematics of how they hooked up the logging cable?
bjohnson_55 is offline   Reply With Quote
Old 08-09-2012, 10:52 AM   #53
Dadowhip
Member#: 212195
2007 WRX STI
Im having issues with the Aem Uego and Romraider I had a bustedfinger cable and found out that it isn't any good but they willn't replace it even tho its been my issue since the start. So now I have a different cable that is working But my issue is that it will show up in hyperterimal and read right every time 14.7 14.8 all the way down at idle and so on. So then I have went into romraider picked the Aem Uego 9600 and in com port on the side doesn't show any com and it should be using com 5 I have the newest romraider and its up to date not sure what mite be the issue. Just wish I could get this fix so I could start tuning
Matt
Dadowhip is offline   Reply With Quote
Old 08-09-2012, 11:56 AM   #54
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Make sure the cable is plugged in before you start romraider.
Old 08-09-2012, 12:23 PM   #55
Dadowhip
Member#: 212195
2007 WRX STI
Yes have done that as well maybe re download the program?
Old 08-09-2012, 06:22 PM   #56
Dadowhip
Member#: 212195
2007 WRX STI
Also if I plug just the cable in the computer and it reads in the devices then I open romraider should it be in the com port to pick from? Or will only see it when it is hooked up to the wideband? If anyone could test that, that would be great
Old 08-09-2012, 06:51 PM   #57
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
oh my god man, learn proper english!
Plug the cable into the computer(with the o2 connected)
Windows should find it.
right click the "My Computer" icon on your desktop.
go into "device manager"
find your com device in the list (remember its com port)
open romraider logger
click on "plugins" on the toolbar
select "AEM UEGOAFR[9600 baud]"
set your com port that you found in the device manager.
When you are viewing RR-logger and you see "com port" in the top left, that is for your OBD2 data cable connection... not your AFR cable.
Last edited by Black94Snake; 08-09-2012 at 08:06 PM. Reason: directionally challenged
Old 08-09-2012, 08:02 PM   #58
Dadowhip
Member#: 212195
2007 WRX STI
When you are viewing RR-logger and you see "com port" in the top right, that is for your OBD2 data cable connection... not your AFR cable.
Learn your right from your left then. That is what I have done but in Romraider Logger I can not choose a com port after selecting the Aem Uego under plugins. Which makes no sense on why Romraider doesn't pick it up
Old 08-09-2012, 08:22 PM   #59
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
maybe its a defective operator
Old 08-09-2012, 08:27 PM   #60
quazimoto
Member#: 70395
quazimoto is online now   Reply With Quote
Old 08-09-2012, 08:29 PM   #61
quazimoto
Member#: 70395
If you have not installed the drivers for the UGO's cable correctly then obviously Romraider is not going to find it.
Old 08-09-2012, 08:34 PM   #62
Dadowhip
Member#: 212195
2007 WRX STI
Is it possible I have the wrong driver for the cable and it work in hypertermial and not in Romraider? Is that what your saying?
Old 08-09-2012, 08:35 PM   #63
Dadowhip
Member#: 212195
2007 WRX STI
Well yes that is the issue here since I have not figured it out yet.
Old 08-10-2012, 07:53 AM   #64
quazimoto
Member#: 70395
Romraider doesn't give a shat about the driver,it's Windows that does. I would try a different com port. What version of RR are you using? Have read the FAQ's on Romraider? If you are running Vista/7 everything needs to be installed as admin.
Old 08-10-2012, 09:29 AM   #65
Dadowhip
Member#: 212195
2007 WRX STI
Yes I have been threw FAQ its the newest version on Windows 7 I will try a different com port uninstall everything and try again and go from there could of missed something. The drivers are on this link http://bustedfingermotorsports.com/f...php?f=32&t=124 ? If so should I do it manually on windows 7 by updating the driver or use the self install? Last time I did self install and mite be the issue? Thank you for your input
Old 08-10-2012, 10:42 AM   #66
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
What version of Windows 7 are you running.
Old 08-10-2012, 10:47 AM   #67
quazimoto
Member#: 70395
Definitely do not let Windows self install the drivers. Also I would contact Busted Finger Motorsports about the issue.
Old 08-10-2012, 11:00 AM   #68
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I'd like to know why the BFM cables never work. I made my own and haven't had a single problem.
Old 08-10-2012, 12:08 PM   #69
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Busted Finger Motorsports had a run of bad cables. Get a replacement or make your own.
abrumlev is offline   Reply With Quote
Old 08-13-2012, 01:04 PM   #70
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Anyone have directions to make one?
cowboy_Rob is offline   Reply With Quote
Old 08-16-2012, 10:05 AM   #71
Dadowhip
Member#: 212195
2007 WRX STI
Busted Finger Motorsports is sending me the new cable and I ended up running windows xp in parallel on my mac. Installed all software and drivers and the program worked right when I plugged everything in. When on windows 7 where the com port in romraider would never show anything. Thanks for everyones input
Old 08-30-2015, 03:27 PM   #72
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
Originally Posted by fenix-silver View Post
You can log the WB alone using this utility from AEM http://forum.aempower.com/forum/index.php?topic=26370.0
Aem moved their software to their new website, i'm trying to find this software so I can log the wideband separately without having to use romraider, does anyone remember the name of this aem logger? I need to tune my brothers miata with a standalone ecu but i am unable to log it using romraider or see any output by plugging it into the standalone ecu. The gauge works fine though.
alexmartynyuk is offline   Reply With Quote
Old 01-06-2016, 08:34 PM   #73
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Reviving an old thread here for some help....
I'm running Windows 8, have RomRaider version 0.5.9 RC2 build #738. Regular datalogging via my Tactrix 2.0 cable is working flawlessly. I'm trying to add my AEM UEGO model 30-4100 to the datalog. I purchased a Cable Matters USB 2.0 to serial adapter and I have installed the drivers. I used a DB9 cable to connect to the gauge via the correct pins/wires. I connected the wires as instructed in the AEM manual to the blue wire and a ground. I setup RomRaider as per the instructions re external sensors and selecting a Com port.
I'm still showing 0.00 on my RomRaider dashboard. Does anyone have any magical tricks to get this to work?
Soarer is offline   Reply With Quote
Old 01-07-2016, 09:00 AM   #74
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Update... I have an old laptop running Windows XP that I figured I'd try to get HyperTerminal working with. I loaded the drivers via the CD that the serial to USB cable came with, connected it to the laptop, got the found new hardware wizard, got the "your hardware is ready to use" message, started HyperTerminal, created a new connection, verified the settings of the com port and 9600 baud rate and others as per AEM manual but still no input registering.
I then put a meter on the wires coming from the AEM gauge. With the motor off and the key on so that the gauge is powered, I am getting about 2.06 volts across the blue wire to my ground. I think this is telling me that the gauge is sending a signal but for some reason it's not translating through the serial to USB converter. So frustrating!!
Old 01-07-2016, 11:48 AM   #75
Sikk
Member#: 241662
2006 WRX VF48
i have a AEM uego and run on windows 7 that I never update and rarely use except for tuning. No issues. sometimes I have to restart romraider to get it to connect and that's about it.
XP is quite dated and should not be used. Windows 8/10 while officially supported may have issues as they are much newer. I would use windows 10 over 8 though if i had to pick.
Sikk is offline   Reply With Quote
AEM UEGO and AEM Analog Wideband gauges 199.80 w/Free Overnight Shipping maperformance Gauges & Electronics 93 06-15-2010 11:02 AM
AEM UEGO and AEM Analog Wideband gauges 218.11 w/Free Overnight Shipping maperformance Gauges & Electronics 106 02-04-2010 12:09 PM
AEM Uego and AEM Analog Wideband gauges now just 207.21 w/Free Overnight!!!! maperformance Gauges & Electronics 13 09-01-2009 10:39 AM
AEM Uego install/ RomRaider lagodcm Interior & Exterior Modification 1 02-10-2009 04:21 AM
