![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 95189
BAIC
Vehicle:2002 WRX Wagon PSM |
Hi all, I'm looking to purchase some new tires for my car, and wanted some input and advice about selection.
I've got 18x8.5 Rota Grids on a 2002 WRX Wagon thats lowered on Epic Engineering Wagon Springs, currently running a 235/40ZR 18 Direzza, but I get light rub on the rear fenders in hard cornering and large bumps at speed. I've heavily rolled the rear fenders, so thats not going to get any better. I'm thinking about going to BFG G-Force KDW's but i'm unsure wether to go with the current 235/40, or try going to a 225/40. Any clue how much more clearance I might gain by going with this? Is it worth the tradeoff of a smaller contact patch/slightly stretched tires performance wise? I do drive this car hard, and would like to get into some AutoCross and Trackdays soon.
#2 |
Member#: 97135
NWIC
I highly doubt you are rubbing the fenders with those wheels, if you are you don't have correct camber.
Are you rubbing at full lock under cornering? Front or rear? |
#3 |
Vehicle:OK Houston we have an Uncle |
you dont want those bfg's...they get LOUD...so loud you wanna stab your eardrums out with a thermonuclear bomb....
![]() ****can the 18's get some 17x8 or 17x9's and put a 235/40 federal 595rs-r on and be or try the 225/40-18 on your wheels 595RS-R and be ![]() the rs-r's run WIDE for their size |
#4 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
Somehow I am not surprized that Uncle suggests Federals.
Go to manufacturer web site, find your current tires and write down their dimensions. It seems that you are looking for tires that are a little smaller than what you currently have. Nominal sizes are just indication of load and size; tires assigned the same size can vary significantly in real dimensions. Then go and check Federal and you will find that Uncle's suggestion is probably spot on. How much money do you have? The best tires will be Michelin Pilot Super Sport (all around) and Yokohama Advan Neova AD08 (dry). A few notches below will be Dunlop Star Spec. Probably also here will be Federal RSR (if you can find them). One of the best wet tires is Goodyear F1 Asymmetric 2 but not as good as others in dry. And if you are on budget and want comfortable dd tire (summer grand touring like) nothing beats Hankook Evo V12 K110 (except that it wears quite fast). Krzys PS Check tirerack and car and driver, both recently tested summer tires and posted the results. I base my opinions on these tests (and a few more European ones). |
#5 |
Member#: 298119
Vehicle:2005 Impreza WRX PSM |
krzyss, Nice post. Interesting story, I have both the Hankook evo 12's and the Sumitomo HTRZIII's, in the same size (two different sets of tyres of course) - the ZIII's are much wider.
The Evo12's have decent grip, but they really have a "squishy"/soft feel to them. The ZIII"s have much better feedback w/o being as harsh as StarSpecs/Neovas, similar traction "feel" to the Evo 12, but feel slightly sportier overall. I'd faster recommend the ZIII as a budget alternative than the Evo 12 K110's (well, aside from the 595 RS-R)....cuz they are priced about the same IIRC, and give more value for money IMHO |
#6 |
Member#: 295724
MWSOC
Vehicle:2011 WRX 5DR DGM |
Are there any options for a 235 or 245 in a 35 sidewall measurement? Going with a slightly shorter tire might help on the fender clearance issues at least.
That being said, Scotty is at least correct in that you would have more options in a 17x8 or 17x9. |
#7 | |
Member#: 95189
BAIC
Its not under cornering or full lock, its under hard compressions, and only in the rear where they rub the inside edge of the fender. The fronts never contact. |
#8 | |
Member#: 97135
NWIC
#9 | |
them v12 hankooks are just a touring tire....they are NOT a performance tire __________________________________________________ __ and after using 'performance' tires since the early 1980's..... the federal 595RS-R is the best UHP/MAX performance street/dd tire there is right now....nothing even comes close cheap SILENT ![]() ![]() good ride great performance wet and dry decent life work on the track just fine if ya wanna do that they just do NOTHING wrong....quite amazing, really about the only downside is a bit limited size selection |
#10 | |
Member#: 95189
BAIC
for a little over 500 bucks to my door, thats not effin bad. |
#11 | |
they run REALLY wide....the 225 is EASILY as wide as a 235 of any other brand and it will help the gearing a bit too being shorter just make sure...i mean REALLY sure that your toe is ZERO....and nothing else!!! these tires are silent UNLESS they get a bit if a feather edge on them from toe being off.....then they get LOUD enough that ya wanna stab your ears out with electric eels and things...... ![]() |
#12 |
Member#: 306757
NWIC
Vehicle:02 wrx blue midnight pearl |
I highly recommend the Michelin pilot sport a/s plus, primacy mxm4, or a pilot super sport. Three of the worlds greatest tires ever made. As far as the size, uncle scotty said it all.
#13 |
#14 | |
Member#: 306757
NWIC
#15 |
Member#: 306757
NWIC
Get a y rated hankook to last 50k haha. Hankook..... what a joke.
#16 |
Member#: 306757
NWIC
Attn: tire knowledge is based on how many posts on this fourm you have.
#17 | |
Member#: 97135
NWIC
#18 | |
how much UHP and MAX performance tire experience do YOU have??? yeah.... |
#19 |
Member#: 306757
NWIC
I do agree that scotty knows his ****. But obviously he isn't the only person that knows a thing or two about this subject. Tires are my profession. Its what I do all day everyday. You guys talk **** to everyone that says anything on here. Congrats. You've been in the game a while. So have I. Sweetie.
#20 |
Member#: 306757
NWIC
Ps traction t/a is a garbage tire.
#21 |
Member#: 270651
MAIC
Vehicle:2005 vf39'd WRX Aspen White |
Yes i hated my kdw's because of the noise! But they do have cool tread
#22 | |
ok...fine bang for the buck they suck....if ya balla.....holla Michelin ![]() ![]() i usta think buying hi dollar automotive products like tires was a great thing....until i realized that most of the hi dolla automotive things were just hype and advertising which inflated both their image and price meh |
#23 |
#24 | |
Member#: 97135
NWIC
#25 | |
Member#: 306757
NWIC
