Old 08-17-2012, 04:30 PM   #26
socalLGT
Member#: 89752
08 STI
Originally Posted by K1WRC View Post
Now if they could make one that will mate up to the factory twinscroll header, new uppipe portion and downpipe obviously, twinscroll EFR anyone?
My 8k rpm would be happy!
I'm willing to be a guinea pig
That's not going to happen unless someone wants to make a custom turbine housing casting. Given the intricacies of the EFR TS IWG turbine housing that is highly doubtful.
socalLGT is offline   Reply With Quote
Old 08-17-2012, 04:56 PM   #27
draco159
Member#: 204121
2005 WRX Wagon
So would this be a better option than going rotated with say a 3076 .82?
draco159 is offline   Reply With Quote
Old 08-17-2012, 05:50 PM   #28
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Stock exhaust manifolds?
Any chance FR would also make the up-pipe for 3-bolt headers?
Old 08-17-2012, 06:50 PM   #29
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
I figured, one can always hope.
Maybe I missed it but what is the AR on this turbo?
K1WRC is offline   Reply With Quote
Old 08-17-2012, 07:03 PM   #30
SubieLuvin
Member#: 248202
2013 WRX Sedan
This makes me not what to go rotated on my next car. With supporting mods and more boost this would make for a great street monster
SubieLuvin is offline   Reply With Quote
Old 08-17-2012, 07:46 PM   #31
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yes please. its the only way i would try this turbo.
Old 08-17-2012, 08:09 PM   #32
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
So how many lbs/min is this turbo? What is the biggest stock location that they are going to make?
Old 08-17-2012, 08:36 PM   #33
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Stock motor (60k miles), stock TMIC and stock exhaust manifold. Basically just enough mods to supply enough fuel, sample the incoming air and get it out the back of the car as quietly and cleanly as possible...so when Geoff from Full-Race told me about a new turbo that would spool like a turbo 10lbs/min smaller than it's rated flow, my interest was piqued, but my BS meter was similarly pegged...I have always wanted to have a Subaru that made 500wtq before 4000rpm and still made over 450whp..Damn near stock turbo spool with nearly 200whp more by redline... not too shaby
we're really happy to get this feedback paul - Ive been excited for a while now. I promised you this was the real deal!! It is particularly exciting considering your setup is doing this thru a cat, 2.5" exhaust and stock TMIC. California visual inspection could pass
That was sort of the idea - we've heard from a lot of people that wanted the performance and powerband of our twinscroll rotated kits but at a fraction of the cost and easier to install (no fabrication, install in a driveway). Doing a B1 EFR in stock location keeps everything clean/simple and based off the feedback we've had from people it could work well for many different setups
Also just for clarity sake, the EFR7163 I have on my car sits in basically stock location but it is NOT a bolt-on turbo (ie: bolts to OEM fitment uppipes and downpipes). The turbo has a T25 inlet flange and a 3" v-band discharge. The Full-Race uppipe and downpipe are what allows it to fit in stock location.
^^^thanks for adding that note
Originally Posted by Concillian View Post
- Is there a realistic estimate on availability?
- Does this frame match any existing (I use that term loosely) EFR turbos? Could we use the UP / DOWN setup with a 6758, for example, then move to a 7163 in a few years when it's available?
I really like the idea of an EFR setup that uses the TMIC.
-the EFR 6258 and EFR 6758 are both B1 turbos and will be available in less than a month. Once supply begins it will not drop off again
-YES, 6258 and 6758 is the identical footprint to 7163. once the 7163 is available it would be a drop-in.
-thanks, we also like the TMIC - its very easy to install and useful on a road coarse car because the airflow helps keep engine coolant temps in check
Originally Posted by CKxx View Post
Which size is this turbo? Which one is the 67mm?
the 6258 and 6758 are identical in outer dimensions and appearance to the photos in this thread. the 6758 will probably be the most popular imo, best combination of transient response, spool and low inertia
Full-Race is all set on their end with the uppipe/downpipe and ancillary bits. As for the BOV/BPV, all EFR turbos have one integrated in to the compressor cover, hence the block off plate on my stock TMIC. No boost control issues at all. I have the high pressure actuator and that combined with the hybrid Grimmspeed boost control allowed me to dial in the exact amount of boost I was looking for with rock steady boost control.
+1
Originally Posted by Black07STiGuy View Post
I believe that the efr turbos have the bpv built into the Turbo.
correct, the EFR bpv is on the compressor housing. People have the option of running dual BOV/bpv but in my opnoin efr only is cleaner (like paul is running)
They make bpv with interchangable springs for full race setups. I think on our cars, it would be dangerous not to purge the unused pressure somehow. I think diesel trucks are the only ones that have No bpv/bov period.
it is a very important to purge unused charge air from any spark ignition engine with a throttle body. Diesel trucks do not need a bpv/bov because there is no throttle body. Ive seen that crawford does not run a bov on some of their motors, but in my experience when doing that on GT30R turbos and drift cars was not good. One note - our EFR turbo kits there is only one spring for the EFR's bpv, not interchangable springs. much simpler than external BOV kits of the past
Full-Race Geoff is offline   Reply With Quote
Old 08-17-2012, 08:37 PM   #34
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the 7163 is the biggest stock location we will make. the compressor maps will be released once the turbo is ready for production, it is still undergoing development and changes. the 6258 and 6758 are what will be intro'd later this month
thats not going to happen
Old 08-17-2012, 08:51 PM   #35
Fierysun
Member#: 82745
2005 Subaru STI
Highly unlikely that BW will make a turbo that would only fit the TS Subaru flanges. The market for that is tiny and they will lose more money (development and manufacturing cost) than they would make.
Old 08-17-2012, 08:53 PM   #36
Fierysun
Member#: 82745
2005 Subaru STI
Fullrace, any plans to make a 3-bolt up-pipe as well to fit this turbo?
Old 08-17-2012, 11:09 PM   #37
STIdad
Member#: 195929
Geoff, will some of the newer tech, like the mixed flow turbine in the 7163 make it into any other models?
STIdad is offline   Reply With Quote
Old 08-18-2012, 12:31 AM   #38
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
Even though I'd have to change my entire turbo setup, this is still an intriguing combination that may prove more capable than any other "stock" location twinscroll turbo. I'm looking forward to seeing some retail prices in the future so I can figure out if it would be worth the dough to switch.
Old 08-18-2012, 05:29 AM   #39
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Why the ebc and mbc series setup? And also what would you need to be done to get this turbo to work a 2011 wrx with stošk tmic location?
freddy121389 is offline   Reply With Quote
Old 08-18-2012, 09:43 AM   #40
juanmedina
Member#: 133146
too bad too small for my taste.
Old 08-18-2012, 11:32 AM   #41
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
"Hybrid" boost control is in parallel, not in series. Best of both. There's a HUGE sticky thread on it in the tuning forum, but the basic gist is that you can get the full advantage of an MBC (easy tune & set fast spool, smooth sound with no solenoid "chuffing" oscillating noise at target boost) for your maximum boost tune, while maintaining factory safety boost cuts, economy / pump gas maps, tapering at high RPM or running lower boot at part throttle, etc... by tuning the solenoid.
With a blocking type solenoid either "leg" of the parallel plumbing can open the wastegate and the tuner chooses when one leg opens and the other doesn't.
Old 08-18-2012, 11:39 AM   #42
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
Honestly I think 375-450 whp is the sweet spot for reliability for a built Subaru THAT'S GONNA LAST! So The 6758,7163, and 7064 are the turbos most of ous should be using anyway. 500-600whp in a Subie is equivalent to a EVO with almost a 1000. Entirely tooooo much stuff jst breaks on our cars. 10 grand jst for a built block to handle 500whp + isn't worth tha trouble there's a reason the Japanese don't push the EJ series like we do in the states.smh
SUBARIFFIC is offline   Reply With Quote
Old 08-18-2012, 11:41 AM   #43
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
Old 08-18-2012, 11:49 AM   #44
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
If the 6758 is a 49lbs/min the 7163 has to be in the 50-52lbs/min range since the 7064 is a 56lbs/min
Old 08-18-2012, 11:24 PM   #45
fourmicah
Member#: 128760
2015 STI
Do you plan on building a kit like this for the 7670 EFR?
fourmicah is offline   Reply With Quote
Old 08-19-2012, 12:10 AM   #46
socalLGT
Member#: 89752
08 STI
Not to speak for FR, but I doubt it. The B1 frame turbos are the only ones that can physically fit in stock location and as it is, clearances are tight and require very precise tolerance holding to ensure consistent fitment. With that in mind, it is highly doubtful that any B2 frame turbos (like the 7064) can be made to fit in stock location.
Old 08-19-2012, 01:23 AM   #47
jutes85
Member#: 127232
E92 M3
98' Foz
Very promising turbo, as per the tests done by Perrin. http://blog.perrinperformance.com/bo...test-and-tune/
jutes85 is offline   Reply With Quote
Old 08-19-2012, 03:25 AM   #48
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Very comprehensive comparison's and there's such a huge difference!
Before this, most differences were always a result of a better match between wheels and A/R. It seems like the aero on the new EFR7163 turbine is from an entirely different planet and really makes a leap instead of the small improvements we've seen over the years.
Now lets hope the supply of this new EFR turbo improves as much as its performance has gained
Beetspeed is offline   Reply With Quote
Old 08-19-2012, 10:14 AM   #49
DarkKnightBaku
Member#: 199536
04 STi WRBlueDevil
looks good to me
DarkKnightBaku is offline   Reply With Quote
Old 08-19-2012, 12:29 PM   #50
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Paul, you don't have to speak for Full Race... Full Race already posted in this thread that the 7163 will be the largest stock location.
