Old 08-14-2012, 12:05 PM   #1
lgt2000
Member#: 140073
2005 LGT
Red
Default 2005 Legacy GT V8 Build (LS2/LQ4)
I have been working on a few V8 build recently and have decided not to rebuild my legacy back to the 2.5L Turbo but to swap it out for a 6.0L V8.
We are building everything ourselves and are working on a V8 Miata at the same time.
The engine is going to be an Iron LS2 or LQ4 which will have headwork and cam done to produce around 450 rwhp. The transmission will be a T56 6-Speed.
The car will be RWD due to space constraints and will fit what I need it to do. I am going to run the GM ECU and interface it to the Legacy cluster.
The front accessories are from a C6 LS3 Corvette to save space.
If you want to see quicker progress buy my stuff haha )
Here are the specs on what I have so far:
2003 LQ4 6.0L Short block with dished pistons
2006 GTO Front Sump Oil Pan and Pickup
2010 Corvette Water Pump and Harmonic Balancer
The head will most likely be 243/799 LS2 heads but I may go to LS3 head depending on what kind of deals i find. Once the heads are bought I can decide what direction to go in as far as a cam
The heads will be milled in any case and the goal is to run around 11:1 compression and stay on 93 octane
The T56 will most likely be the CTS-V unit since it has a shifter setup similar to the Legacy and is improved over the F-Body units
This will send power through an LS7 Corvette clutch
Here is a picture of the first quick mockup we did once the mockup engine arrived. We are going to modify and reinforce the subframe to move the engine back another 3 inches and we are also going to use outback pieces in order to drop the subframe an inch lower
lgt2000 is offline   Reply With Quote
Old 08-14-2012, 12:05 PM   #2
lgt2000
Member#: 140073
2005 LGT
Red
Here are few more pics we took when we were doing the initial quick mockup. This is without squaring off and center the engine and before the subframe modification and Outback subframe drop. Once all those modification are completed and the hood is swapped for a scoopless one we hope to be able to make everything clear under there.
That motor mount bracket in the middle of the firewall is now drilled out and the area patched as it was in the way
Old 08-14-2012, 12:06 PM   #3
lgt2000
Member#: 140073
2005 LGT
Red
Reservedb
Old 08-14-2012, 12:39 PM   #4
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Sweet raptor Jesus this looks like it'll be some fun
EvileyeZ88 is offline   Reply With Quote
Old 08-14-2012, 01:58 PM   #5
STi Addict
Member#: 328431
09 STi madness
woahhhhhhhh O.O
STi Addict is offline   Reply With Quote
Old 08-16-2012, 05:03 PM   #6
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
Was about to ask why you weren't moving the engine down and back. Then I read your post instead of looking at pictures lol. Interesting project!
DeleriousZ is offline   Reply With Quote
Old 08-20-2012, 03:18 AM   #7
climberd
Member#: 183019
05 LGT Stg3 Wgn
Subscribed, mostly interested in your wiring choices to get the LGT ECU to play nice and not freak out with cam sensor missing.
climberd is offline   Reply With Quote
Old 08-21-2012, 01:18 AM   #8
Skrane
Member#: 296352
Why iron block?
Skrane is offline   Reply With Quote
Old 08-21-2012, 01:40 AM   #9
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
And so it begins...
This is awesome, I will keep checking back for updates, and can't wait to see this thing up and running! Good luck with the build!!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-21-2012, 06:52 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by Skrane View Post
Why iron block?
I was wondering the same thing. I understand the iron block would be cheaper, but it shouldn't be that hard to find an aluminum engine, and the weight savings on the nose is more than worth it IMO. The aluminum 5.3L engines (LM4) can be had for $500-800 complete, for instance, and will make tons of power just like the other LS motors.
Old 08-21-2012, 11:33 AM   #11
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
If he plans to turbo it the iron block will hold more power, but is it really needed?
jake
KONKILR is offline   Reply With Quote
Old 08-21-2012, 11:53 AM   #12
Skrane
Member#: 296352
jake
Why would the iron block hold more power
Old 08-21-2012, 12:28 PM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
jake
^the turbo? yes, yes it is.
Can't wait to see this through its build process!
Less flexing in the sidewalls.
Old 08-21-2012, 12:38 PM   #14
Skrane
Member#: 296352
Not enough to justify having an iron block. Unless he got a great deal on it or something haha
Old 08-21-2012, 12:54 PM   #15
KONKILR
Member#: 3190
2004 Impreza TS and
The iron block LS engines are way stronger than the aluminum block. Plus you can safely overbore the iron block. And the iron block engines are ready to spin to the moon and boost like crazy with no issues.
jake
Old 08-21-2012, 01:00 PM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
At this point I really don't care if he does aluminum, iron or purple monkey dung. I just want to see it happen.
Old 08-21-2012, 01:20 PM   #17
GT35RHybrid
Member#: 223237
Holy smokes in for updates.
GT35RHybrid is offline   Reply With Quote
Old 08-21-2012, 05:38 PM   #18
kaos200
Member#: 2692
I dare not mention nor view this thread anywhere near my GT for she will feel inadequate
kaos200 is offline   Reply With Quote
Old 08-21-2012, 05:49 PM   #19
KONKILR
Member#: 3190
2004 Impreza TS and
Unfortunately I need my subaru to be AWD, otherwise my newly acquired LGT might get this treatment!
jake
Old 08-21-2012, 06:41 PM   #20
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not to pee in your coolaid but
"I am going to run the GM ECU and interface it to the CAN BUS Legacy cluster."
thats going to be tough
Old 08-21-2012, 09:59 PM   #21
RallyColtTurbo
Member#: 16819
I'm not so sure. The CANBUS interface is an industry standard, so the communication should 'just work' with a bit of research. After that you need the commands to do as intended.
A person with the right skill set can sniff the CANBUS of both to figure out what each command does for each brand. Then said skilled person can build a 'translator' that accepts the GM ECU commands and repeats out the Subaru translation for the cars systems.
It's far beyond my skillset, but the type of guys that can reverse engineer complete ECUs should have a head start. The question is....does the builder have the know-how or the connections?
RallyColtTurbo is offline   Reply With Quote
Old 08-21-2012, 10:09 PM   #22
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
^this
Psychoreo is online now   Reply With Quote
Old 08-22-2012, 12:24 AM   #23
RallySport Direct
Member#: 33174
We are Open Late!
LOL best quote I have seen in a long time. Thanks for that, I needed it tonight haha!
Rick
Old 08-22-2012, 07:55 AM   #24
GT35RHybrid
Member#: 223237
Is it just me or does it look like there is gonna be some fitment issues at the front?
Old 08-27-2012, 12:41 AM   #25
climberd
Member#: 183019
05 LGT Stg3 Wgn
There is plenty of room. The problem is going to be getting the GM ECU to talk to the Subaru ECU. It's possible, sure. Yet that solution posted above is by far the hardest thing I can think of to make for a Subaru, or for any modified car project. Back to reality, the only "good" solution I have found to this problem (and I have put very serious research into this) is to do the simple old cam trigger and crank trigger wheel/sensor faking. Feed the Subaru ECU just enough so it will a) crank the starter, and b) not throw a CEL code. The cam trigger is the key. You can clear away any other code, but you're not going anywhere without a cam signal unless you completely bypass every Subaru ECU function. Let's say you do that, no Subaru ECU outputs except CAN, no inputs except GM ECU's tach output (which has a different logic of trigger wheel shape)... you would have to find a way to get the cluster to come alive. Any way you cut it, short of hiring a software/hardware engineer, you may be best off just adding a crank trigger and cam trigger wheel in the Subaru format. If anyone has a plan that would work better, I would love to hear it.
