Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 08-21-2012, 09:53 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default 99 Forester Head Gasket Replacement - Could use some advice, chime in
Bought this guy about 3 weeks ago:
Barely got it home as it ate all the coolant in the radiator on the 40 mile drive home. Hooray Craigslist.
So pulled the engine and found the right head was leaking coolant into the combustion chamber and the left head was leaking oil.
So the heads have been disassembled for getting decked.
and here is what the block looks like:
the plan from here is:
get heads decked
clean up block
replace oil pan gasket
clean up valves using brass wire wheel
lap valves
clean everything like hell
reassemble
So here are some things I'm not sure about:
how do you clean the block for a new HG?
should I get a new timing parts?
can I reuse the head bolts
how is the fel-pro gasket set?
anything else I should do while everything is out?
Thanks,
-BN
Bad Noodle is offline   Reply With Quote
Old 08-21-2012, 10:23 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You can use scotch brite for cleaning the block. I use a razor and take my sweet time making not to nick the aluminum. You can reuse the tensioner. If the idler pulleys are making noise, replace them. Some people replace them just to make sure, some also replace the water pump since it a slight pain to get back in there should it fail, but few do fail.
Head bolts are reusable in my experience. Check the rear main seal and the funky shaped access cover for leaking, re-seal as necessary. You could open up the exhaust ports and match up to the headers while it's all out. You can chase all the threads to make sure they're all clean for reassembly.
yarrgh is offline   Reply With Quote
Old 08-21-2012, 11:23 PM   #3
GrundleJuice
Member#: 165749
If the heads were that bad, the crank case probably needs to be trued flat, too.
Old 08-22-2012, 12:32 AM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Napa sells a green nylon brush for your drill that is made specifically for cleaning off aluminum. It works awesome on heads/block and is super easy with a drill. I can't find it online but they will know what you are talking about if you go in. It leaves a polished/smooth surface!
geronimo81 is offline   Reply With Quote
Old 08-22-2012, 07:38 AM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
By making noise, you mean free spin them in my fingers and see if the bearings rattle?
And will check rear seals. Good idea.
Do you know if I need a new rear cam hole plug for the heads. Will be using new seals for the front of the cams, but for the back, can I put some gray stuff on the plug and tap it in?
Is there any easy way to check if the bolts are Ok? Every place I was going to buy a head gasket set says you need new bolts? Snake oil?
Sounds awesome. Do you just shove rags into the coolant and oil passages to keep them clean?
It sounds like the only thing I need is a head gasket set and a timing belt. The belt I took off looked fine, but the car has got 111k on it so it's probably a good idea to replace.
I was gonna go all out and get new stuff, but since I don't know if the block is warped or how this whole thing will pan out, might as well only pick up the necessities.
Old 08-22-2012, 09:01 AM   #6
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Use a sanding block and some 220 grit sand paper and gently run that across the deck. This will help ensure a nice flat surface for the heads to match up to and will help remove some of the crud that may have built up. For the cylinders I use a rag and solvent.
The head bolts are reusable as long as the threads are not mashed or warped. Just remember that the there are 4 specific bolts for the corners and the 2 in the middle...the 2 middle ones are painted black i believe. Also, look up the torque pattern for the head bolts. If they are not torqued properly you likely have problems in the future.
treksofar is offline   Reply With Quote
Old 08-22-2012, 09:35 AM   #7
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Tighten cylinder head bolts.
(1) Apply a coat of engine oil to washers and
bolt threads.
(2) Tighten all bolts to 29 N'm (3.0 kg-m, 22
ft-Ib) in alphabetical sequence.
Then tighten all bolts to 69 N"m (7 .0 kg-m, 51
(3) Back off all bolts by 180" fi rst; back them off
by 180" again .
(4) Tighten bolts (a) and (b) to 34 N'm (3.5
kg-m, 25 ft-Ib).
(5) Tighten bolts (e), (d), (e) and (f) to 15 N'm
(1.5 kg-m, 11 ft- Ib).
(6) Tighten all bolts by 80 to 90" in alphabetical
sequence.
Old 08-22-2012, 03:34 PM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks for the info. This is awesome, gonna be much less expensive than i thought
Old 08-22-2012, 03:56 PM   #9
upDUHcreek
Member#: 329871
99 forester
red
I'm a new guy, but I too have a 99 fozzy. I'm not trying to be a jerk here, but I've been told they put 2 different engines in the 99 foresters. I'm just trying to make shure you didn't get info for the wrong engine. Of course, I'm NOT an expert, and you experts might be able to identify which engine he's got from the pic's. Do you have the SOHC, or the DOHC engine?
Ok, while I've got your attention I'd like to ask everyone a quick question that might help him out. We all know about the problems these have with head gaskets. I've seen a few threads where people reccomend you use a gasket for a turbo engine in a non-turbo car. It's supposed to be much less likely to leak again like a stock gasket. I noticed no one here reccomended this solution, so I thought I'd ask if the info I read earlier is correct, since it could also help out Bad Noodle with this project.
upDUHcreek is offline   Reply With Quote
Old 08-22-2012, 04:29 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
It's the sohc. i don't think you can use the turbo gasket as it's probably a different thickness. You can get a mls gasket from felpro, which is the same type but made specifically for the car. I read good things, but haven't heard much from the community here.
Old 08-22-2012, 05:17 PM   #11
Mstolz
Member#: 317237
I am building an engine for mine (04 rs) and I am using the turbo gaskets. I put them right on top I non turbo ones and the are perfect fits. And I figured the 2.5 sohc would benefit from the compression bump. And really the differences in thickness will barely change the ratio anyway. I would say go with the factory 04-05 sti gaskets. That's what I'm using. Hope this helps.
Mstolz is offline   Reply With Quote
Old 08-22-2012, 05:25 PM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
That's cool.i saw it mentioned elsewhere. it would make sense that the sti gaskets will work. Anything wrong with the felpro? Their gasket set seems complete for the job and it's pretty cheap
Old 08-22-2012, 06:59 PM   #13
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
For the head bolts, you can inspect them for stretching. One method is to simply mesh ones threads with another (heads facing opposite) and give it a thorough look. There have been many arguments about reusing head bolts, there's a long thread on rs25.com about it. Since they seem to be torqued in the stretchy zone of the stress/strain curve, that points to re-use them to me. Others will have different opinions. The factory service manual says to use new, and the only downside to that is cost.
As for the pulleys, yes just spin them by hand and listen/feel. If they spin for a long time and are pretty quiet, that's good enough for me. You may be different in your criteria for replacement.
Old 08-22-2012, 09:36 PM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Awesome, thanks for all the advice.
yarrgh, good point about the rear cover. It was leaking quite badly. I thought it was the oil pan gasket, but it turns out it's that cover. +1 on getting a new one.
I'm not sure about the pullys.
the one with teeth spins freely but is loud like a skateboard wheel
The other ones are quieter but seem slightly off axis,
The tensioner seems ok. Doesn't spin for a long time
Water pump seems a little jerky when you spin it
but the good news is that the block mating surfaces are flat.
the bolts all mesh really well, no problems there. the only defect I found on them are:
I think they should be ok to be reused. It looks like a manufacturing defect rather than threads getting warped.
So how's this for a shopping list?
- fel-pro gasket set
- rear crank case cover
- pully set (no tensioner)
- timing belt
Old 08-22-2012, 09:41 PM   #15
Mstolz
Member#: 317237
Looks good. I think you can reuse the cover by just re-sealing it. I think lol
Old 08-22-2012, 09:51 PM   #16
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
can you? I was going to buy one and it's out of stock everywhere. So I can just take it off, clean it, throw some gray stuff on it, and put it back on? It's the crappy plastic one...
Are the cam plugs for the back of the heads reusable? Do you put any type of sealant on them?
Old 08-23-2012, 12:25 AM   #17
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Originally Posted by Bad Noodle
Are the cam plugs for the read of the heads reusable? Do you put any type of sealant on them?
Yea you can reuse those. Seal them with the hardening "grey stuff" you use on the valve covers
J.Gibbs is offline   Reply With Quote
Old 08-23-2012, 12:57 AM   #18
tibug
Member#: 273906
2003 brokeback
wagon
You use liquid gasket on valve covers? That's interesting.
You could reseal the plastic cover but it will leak again. You should probably buy a new stamped steel/aluminum one. I have a nice aluminum one off mine that you can have. Only catch is that there's no mounting screws for it, and it uses tapered head screws (can be found at hardware store). It was not leaking - I only replaced it because I ruined the screws getting it off and I had a new steel plate laying around to use. The aluminum plates, by my research, are the best. Just offering...I don't want any money for it.
As for the pulleys, they do seem to wear at different rates and it's interesting to see which one is the worst. I used the same criteria for diagnosing pulleys as Allwheeldriveauto.com uses. That is, if it spins quietly and not for very long, it's got life left. If it spins loudly and/or spins for a long time (meaning its grease is now mostly absent), it's nearing it's end. It only makes sense to do the water pump.
Finally, I reused my head bolts but ended up wishing I didn't. They weren't in good shape. It doesn't seem to have bit me yet, but I can only blame myself if it ends up that way. I'm not saying you should replace yours...just saying that if you have any doubts that the bolts are good enough....you know...do watcha think is best.
tibug is online now   Reply With Quote
Old 08-23-2012, 03:00 AM   #19
jonthesloth
Member#: 184390
2005 CGM WRX
1999 Forester GREEN
Originally Posted by upDUHcreek View Post
... I've been told they put 2 different engines in the 99 foresters...
Hey wait a second....
this guy has an oil cooler....
I don't have an oil cooler on my fozzy
is yours an auto tranny?
jonthesloth is offline   Reply With Quote
Old 08-23-2012, 07:37 AM   #20
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
You are correct sir.
and in terms of the water pump, is that supposed to spin freely or feel a little notchy?
Old 08-23-2012, 09:58 AM   #21
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Book calls for "tri-bond" on the front cam mounts, the plastic filler piece for the cam slot in it the back of the head, and a small amount on the valve cover gaskets. Tri-bond is basically the same thing as the grey hardening permatex fyi
Old 08-23-2012, 02:31 PM   #22
Mstolz
Member#: 317237
I wanna say you can. Aslong as its not cracked or defective. If your sealing surface is flat I think you should be one. I just bought can seals and they were pretty cheap I would just replace them.
Old 08-23-2012, 08:08 PM   #23
tibug
Member#: 273906
2003 brokeback
wagon
Ah yes, I knew about the cam cap but I had no idea about the valve cover gaskets. I guess I don't follow the FSM all that close, lol.
Old 08-23-2012, 10:01 PM   #24
akfmx
Member#: 226059
Icy Silver
Legacy
Yes, you can use EJ257 headgaskets if you have an EJ251. I just did a headgasket/seal/timing component overhaul on my 2000 Forester and that is what I did after researching a lot. They are multi-layer steel gaskets and like someone mentioned, are supposed to hold up really well. They are also the same shape and have the same passages as the EJ251 gaskets. They are slightly thinner I believe, which raises the compression a hair, but nothing noticeable (that is what I have read).
I didn't want to take a chance with non-OEM gaskets and figured the STI gaskets were the best ones. Don't get the OEM gaskets Subaru lists for that car, as even the "Updated" gaskets are single layer steel.
akfmx is offline   Reply With Quote
Old 08-23-2012, 10:12 PM   #25
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
How do you guys feel about cleaning off the valves with a brass wire wheel? It should take the carbon off and make things nice. But could there be any side effects I'm not aware of?
lapping them a good idea?
