Old 08-13-2012, 09:34 PM   #1
superpopsss
Member#: 329038
Default VVT 2009 ej25 on a ts 2001 ?
So I am planning to swap a 2009 ej25 in my 2001 GC with the 2.2 engine.
I know that the 2009 uses vvt but the 2001 doesn't.
I will run on a stock ecu from the 2001 non vvt engine.
Now my question is : If I use your my stock drivers side cam gear, stock intake mani, & throttle body, stock coolant x over pipe, with my stock ecu I should be good no ?
Anybody else did this swap ?
superpopsss is offline   Reply With Quote
Old 08-14-2012, 09:45 AM   #2
superpopsss
Member#: 329038
No one did this swap ?
Old 08-22-2012, 09:42 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I do not think this will work without significantly more work than you have listed. Electrical connectors are different on the heads, but it might work.
speedyHAM is offline   Reply With Quote
