Old 08-19-2012, 10:31 PM   #126
Jackulous
Member#: 312637
2008 WRX hatch
Just ordered some Phillips off of amazon myself. $22 after shipping. think they were $7.33 a bulb. good deal for anyone on a budget!! looking forward to the difference!
are they whiter? or are they just a more lumen'd out yellowish tint? haha
Jackulous is offline   Reply With Quote
Old 08-19-2012, 10:38 PM   #127
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
Much whiter. I'd say they are not yellow at all.
WRXinpa is offline   Reply With Quote
Old 08-20-2012, 01:18 PM   #128
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i'm assuming the stock H11 bulb in the 2012 WRX is a 60 watt bulb?
the manual says H11 - 55 watts. i just want to double check before i order.
-just my own curiousity. i know the DRL's / High beams are 60 watts... i haven't checked the fogs yet either.
ChesterWRX is offline   Reply With Quote
Old 08-21-2012, 07:26 PM   #129
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
Stock bulbs are 55W. H9's are 65W
Old 08-22-2012, 02:49 PM   #130
lj8915
Member#: 329252
2012 Subaru WRX
Have any of you had issues putting the h9 back in the actual projector? It won't twist all the way back to "click" in.
lj8915 is offline   Reply With Quote
Old 08-22-2012, 05:50 PM   #131
Ebranch
Member#: 328457
2012 Impreza WRX
Dark Gray Metallic
No issues- did the install this morning. The socket should be at 12 o'clock iirc.
Ebranch is offline   Reply With Quote
Old 08-22-2012, 07:27 PM   #132
lj8915
Member#: 329252
2012 Subaru WRX
The passenger one went in fine but the drivers side didn't seem to want to turn all the way (to 12 o'clock).
Old 08-22-2012, 09:23 PM   #133
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
Shouldn't be a problem if its oriented correctly
Old 08-22-2012, 10:17 PM   #134
veener79
Member#: 204304
2008 WRX 4D Stage 2
OK wanted to give an update. After about 40K on the car my headlights went out today. Lasted almost 2 years. Bought new bulbs. Got the dremel out and had new ones in in about 10min.
For people having a hard time getting them into the socket make sure they are fully flush. My drivers side was a little off and would not turn all the way. Readjusted and I was fine.
veener79 is offline   Reply With Quote
Old 08-22-2012, 10:39 PM   #135
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Cool, thanks for the heads up. Guess i'll keep a 2nd pair handy.
Btw, i ordered mine from headlightbulbs.com
Odered the hyper whites that give off a hint of blue.. Along with yellows for my DRL's and fogs. Can't wait til i get them.
Old 08-22-2012, 11:31 PM   #136
lj8915
Member#: 329252
2012 Subaru WRX
Wow, what a difference with these H9's. I thought the stock lights were pretty good, but wow...H9's amazingly bright.
Old 08-22-2012, 11:33 PM   #137
lj8915
Member#: 329252
2012 Subaru WRX
I'm not sure how some of you are getting "white" light though. These are still yellow, just brighter.
For those with white light, what bulbs are you using? I'm using basic sylvania.
Old 08-28-2012, 08:41 PM   #138
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
just did these tonight, its a nice cheap upgrade, filing down that damn tab in each bulb was a PITA though..wish i had a dremel!
Old 08-28-2012, 08:43 PM   #139
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
I have the Phillips H9's, 65w
I used a small wood file cause its what I had laying around. Then used a "precision" flat head to carve out the rest of the plastic. Took about 3 minutes per bulb
Old 08-28-2012, 09:12 PM   #140
Dova
Member#: 315989
2012 WRX hatchback
Just ordered a set of platinum white H9 and yellow 9006 for the fogs from headlightbulbs.com and a set of 9006 heavy duty ceramic adapters on eBay to prevent melting the factory wiring. I'll post a review so keep an eye on this thread.
Dova is offline   Reply With Quote
Old 08-31-2012, 09:02 AM   #141
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i put mine in this morning, along with yellow fogs and DRL's / high-beams. i like them.
the pics don't really do it justice right now in the day time. but you can see on one of the pics that the driver's side low beam is significantly brighter than the passenger side.
-it reminds me of the factory lights on the 2012 Legacy / Outbacks... for some reason, those halogen bulbs shine nice and bright.
Old 09-01-2012, 07:55 PM   #142
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
better pics - night time w / different camera.
http://forums.nasioc.com/forums/show...&postcount=136
-hope it helps.
Old 09-02-2012, 09:32 AM   #143
slimfit
Member#: 90597
2011 WRX Premium
Looks good. What yellow bulbs did you go with?
slimfit is offline   Reply With Quote
Old 09-02-2012, 01:21 PM   #144
yes4idol
Member#: 316621
2012 WRX Hatch Stg 1
Cobb SF Intake, SPT CBE
Just did mine. Also tried putting some cheap yellow bulbs in my DRL and ended up blowing the fuse. =( Oh well, you live and learn. Will probably pick up Nokya instead.
yes4idol is offline   Reply With Quote
Old 09-02-2012, 01:38 PM   #145
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
thanks, i really like the look. i my 9005's and 9006's from headlightbulbs.com. but i suppose any yellow bulbs (55 - 65 watts) will do.
what wattage were the bulbs? i tripple checked and a good majority of those bulbs on Amazon / eBay aren't the correct wattage...
ETA: i stay away from the cheap Chinese stuff on eBay.
Old 09-03-2012, 12:33 PM   #146
topdawgx99
Member#: 164173
I concur. Stay away from the cheap stuff on eBay, it melted my housing and I had to buy a new headlamp assembly because of it.
topdawgx99 is offline   Reply With Quote
Old 09-03-2012, 01:43 PM   #147
Dova
Member#: 315989
2012 WRX hatchback
My shipment from headlightbulbs.com should be here tomorrow
Old 09-04-2012, 11:42 PM   #148
RudeBoi0427
Member#: 323934
2012 WRX Premium
What's the bulbs everyone agrees on is really good to use for brightness?
RudeBoi0427 is offline   Reply With Quote
Old 09-05-2012, 05:04 PM   #149
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
I like my hyper whites, but others seem to like the regular phillips H9. It boils down to personal preference.
Old 09-05-2012, 08:17 PM   #150
sennett0r
Member#: 188708
2011 Subaru WRX
I've already ordered my H9 bulbs (phillips OEM replacement off Amazon) but I was wondering because noone seems to be mentioning this step. Is this step necessary for 08+ wrx?
http://i118.photobucket.com/albums/o.../H9toH11_3.jpg
sennett0r is offline   Reply With Quote
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
