Old 07-01-2012, 09:59 AM   #26
zozza8
Member#: 118486
2003 WRX
Anyone buy these? I went with BFGoodrich r1s 255/40/17 and they are specified the same. I wonder what it really measures
zozza8 is offline   Reply With Quote
Old 07-01-2012, 01:02 PM   #27
tuskenraider
Member#: 65699
15 WRX
WR Blue
Originally Posted by JamesWilson2 View Post
Now that RT* is here, may be a tough sell.
Very likely, though there was demand for this size for other cars that may not have as much as an inkling to make the jump to RT, so hopefully they sell well for them as they responded to our request. And with the BFG's here, for certain.
I may take a trip to Tire Rack to check them out physically and compare them to the A6's before deciding which size to go with, in the BFG that is.
tuskenraider is offline   Reply With Quote
Old 07-01-2012, 01:26 PM   #28
zozza8
Member#: 118486
2003 WRX
Nice! You should definitely post your findings. And if you can, see if there is any weight differences?
Old 07-02-2012, 10:16 AM   #29
gimp
Member#: 125220
I've contacted my tire guy. Hopefully I'll have an idea of price and availability soon. Def. going with these over the 295s.
gimp is offline   Reply With Quote
Old 07-13-2012, 05:40 PM   #30
ryansport22
Member#: 157775
2006 WRX
http://www.hoosiertire.com/pdfs/46729_bull.pdf
Now to get these or 255/40r17 BFG R1-S on 17x9 wheels?
ryansport22 is offline   Reply With Quote
Old 07-27-2012, 10:08 PM   #31
101rs
Member#: 38124
2000 Impreza RS
BRP
Just got my set in the mail from tire rack...I can't wait to try them out at the Canadian Nationals, Aug 24-26.
101rs is offline   Reply With Quote
Old 07-28-2012, 01:20 AM   #32
Draken
Member#: 16
1968 Saab
Sonett II V4
That's what I'm talking aboot.
Draken is offline   Reply With Quote
Old 07-28-2012, 08:36 AM   #33
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I don't think I could shoehorn those on a set of 17x7 BRZ rims...
dwx is offline   Reply With Quote
Old 07-31-2012, 01:17 PM   #34
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
They'd fit nicely on my 17x10 RPF1s though. Hmmm. to go back to R-Comps or not to go back to R-Comps
WRX8XB is offline   Reply With Quote
Old 08-09-2012, 07:41 PM   #35
tuskenraider
Member#: 65699
15 WRX
WR Blue
Mine came today. 2 free from Hoosier , 2 from Tire Rack.
275/35's on the left, used unmounted 275/40's in the middle and used 275/40's mounted on 8" wide wheels to the right. I don't find the new 275/35 particularly wide, but compared to the used 275/40's in the middle they are. I'm thinking the usage and mounting/dismounting has changed the profile a bit on the 40 series and makes them look narrower.
Old 08-09-2012, 08:40 PM   #36
gimp
Member#: 125220
Mine arrived yesterday. I just compared them to a set of used 275/40s I had sitting around. They were only mounted once and did less than 40 minutes of track work.
Stack of two vs stack of two, 35s on the right:
And the two on the ground in rolling position, next to each other, 35 on the bottom:
Old 08-10-2012, 08:19 AM   #37
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
Just for the record. Before Peru the Hoosier guy said he was down to 16 in the A compound. Next run was planned for August after Nationals.
CopperTopNWOR is online now   Reply With Quote
Old 08-10-2012, 06:05 PM   #38
tuskenraider
Member#: 65699
15 WRX
WR Blue
Originally Posted by CopperTopNWOR View Post
Just for the record. Before Peru the Hoosier guy said he was down to 16 in the A compound. Next run was planned for September after Nationals.
Fixed?
Old 08-10-2012, 06:09 PM   #39
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
Probably. Might have been late August right before Nationals. I know he did say they were getting close to the end of the first set of A compound. He wasn't sure they would make a second run of the R compound though since it wasn't really moving.
Old 08-25-2012, 10:40 AM   #40
gimp
Member#: 125220
My tire guy, and soon to be GS national champion, Andy Thomas texted me last night:
"about a half inch wider. a noticeable difference when mounting them too"
Old 11-28-2012, 09:52 PM   #41
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Any more input from new 275/35 owners? I am running 275/40's now on 17x10's. I'm due for a new set and will be ordering some soon. I'm thinking about trying the 275/35 out - the shorter sidewall will be nice, but I'm worried about loosing speed in a each gear. I have an '07 though, so 2nd, 3rd, and 4th are a bit taller.
Thoughts?
Acejam2k is offline   Reply With Quote
Old 11-28-2012, 10:09 PM   #42
gimp
Member#: 125220
These seem to like more pressure than the 40s. Strano was watching my runs using my nationals pressures and was wincing as they rolled over. That's probably why I had such a strange wear pattern. Going up to 40 front and 44 rear felt about the same, but wore better.
Old 11-28-2012, 10:14 PM   #43
tuskenraider
Member#: 65699
15 WRX
WR Blue
I was running 40-42 front and 44+ rear and I still got the strange concaved wear at the edge. Only 6 runs on them from Nats and they don't look very good.
Old 11-29-2012, 01:12 PM   #44
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Sounds like I might be sticking with the 275/40's then. Plus the additional speed in 2nd gear can't hurt.
Old 11-29-2012, 01:44 PM   #45
polyol
Member#: 73422
04 STi
JVP
Hmmm...ive been running 275/40 for years...hmmmmmm....35 sound like a fun experiment...
polyol is offline   Reply With Quote
Old 11-29-2012, 01:46 PM   #46
gimp
Member#: 125220
I liked them. Wider and faster acceleration. I'll probably try another set with better pressure and see how the wear.
Old 11-29-2012, 01:58 PM   #47
polyol
Member#: 73422
04 STi
JVP
Is that a 9" rim?
Old 11-29-2012, 02:04 PM   #48
gimp
Member#: 125220
Originally Posted by polyol View Post
Is that a 9" rim?
No. 17x8.
Old 12-01-2012, 03:36 PM   #49
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
What size wheels were you guys using? I'm debating if I should stretch the 275/35 out on my 17x10's. A half inch of extra width would be nice for grip - but if I loose significant MPH in 2nd gear, I won't be too thrilled. I'm thinking shorter (and hopefully stiffer) sidewalls will help with turn-in too.
Old 12-01-2012, 05:41 PM   #50
polyol
Member#: 73422
04 STi
JVP
You might lose a MPH in 2nd...
FS MA: Rota 17"x8" with brand new Hoosier A6 tires neilschelly Wheels/Tires 0 05-01-2008 09:30 PM
17 BBS Gold STI Wheels 5x114.3 with brand new Hoosiers SoDmFst Wheels/Tires 8 05-08-2007 12:56 PM
and now a quick report on the new Hoosier A6 [email protected] Motorsports 32 02-17-2007 09:56 PM
SO4 Hoosier Sizes Scooby Freak Motorsports 11 04-23-2004 01:08 PM
FS: brand new hoosiers Prostho Vancouver Impreza Club Forum -- VIC 6 09-12-2001 02:05 AM
