Old 08-22-2012, 10:15 PM   #1
lowlow05sti
Member#: 279213
2002 ej207 wrx
Default ej207 into 02 wrx avcs wiring help
anyone who can help please about to wire my swap up i have the ds1 instructions but anyone have step by step or more info please lmk
lowlow05sti is offline   Reply With Quote
Old 08-24-2012, 12:58 AM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Do you have shielded wires and pins?
If you need step by step I would just get the IA kit, it has good instructions
http://www.iaperformance.com/product...oducts_id=3217
Old 08-25-2012, 05:15 PM   #3
lowlow05sti
Member#: 279213
2002 ej207 wrx
i have the wires and pins anyone know of the tool u need to remove the pins?
Old 08-26-2012, 11:03 AM   #4
jam007
Member#: 174706
2008 LGT-B
Use an awl or a scribe and be gentle doesnt take much to open the harnes block.
jam007 is offline   Reply With Quote
Old 08-26-2012, 05:25 PM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Dont waste your time, they are a pain in the ass to pull out and you might **** up the connector, its usually easier to just cut and solder the wires.
You only have to add wires so if you have the pins there is no need to remove anything from the connectors unless you are trying to repurpose the TGV wires
Old 08-31-2012, 03:28 AM   #6
tomcat7810
Member#: 194056
07 Sti
Swp
Default ?
I am doing the same swap as him, my question is what harness do I get? Iaperformance has a bulkhead and a engine harness kit for this swap? I am not sure which one I need? I also haven't decided what I want to do. I am either going to run the wrx ecu with a Cobb accessport and no avcs or the full jdm engine with the jdm engine harness and ecu. I don't know what kind of power loss I will take by not running the avcs? Let me know what you guys have done?
tomcat7810 is offline   Reply With Quote
Old 08-31-2012, 11:23 AM   #7
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
AVCS makes the JDM motor and gives it all its low end torque, they really feel weak without it. Run the JDM ECU and get tuned by someone who actually knows how to tune the ej207, if you tune the 207 like a WRX 205 you will be missing out on some decent power. The engine takes more timing than people expect, around 5-10 more than you would on a 205
IA performances AVCS harness is all you need http://www.iaperformance.com/product...oducts_id=2580, it drops in and done, takes ~30 min
you only need the motor harness if you did not get the JDM engine harness.
Old 09-30-2012, 08:16 AM   #8
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
I'm in the same boat, I have an 02 wrx, would i just need the above harness since the 02 already has the bulkhead harness? I also plan on using the usdm ecu.
ShinjiML is online now   Reply With Quote
Old 09-30-2012, 12:56 PM   #9
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
If you are using the USDM ECU you do not need the ACVS harness since the USDM ecu does not support AVCS.
Old 09-30-2012, 02:27 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Running the EJ207 with a USDM ECU means no AVCS, and all the low end toruqe benefit is GONE. I suppose it's easier since you don't need to re-wire anything... but you should drive an AVCS car before you decide not to use AVCS. It makes a huge difference in drivability... enormous.
Old 09-30-2012, 05:33 PM   #11
ShinjiML
Member#: 257231
But then I'd have to get the USDM ecu tuned just to drive it to the inspection site, I was mainly trying to avoid that hassle.
Also, does anyone know if 205 cams will fit in the 207 without regrinding/machining? This is for my backup plan...Couldn't find any posts on this...
Old 09-30-2012, 05:43 PM   #12
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
It will run on the USDM ECU with no real problems, wont be perfect without a tune but it will work. There is no reason to swap cams.
