Old 08-28-2012, 10:41 AM   #1
bazdrum
Member#: 100157
2014 Civic Si
Default 2012 WRX Stage 1 91 Datalog
Could someone check out my log? Ran this the other day with the temperature @ 84. Running 93 octane gas on the stage 1 91 octane tune - stock intake. I'm not sure what the target boost is for this map but it looks like I'm underboosting.
https://docs.google.com/spreadsheet/...EVjOWhiN1hvcEE
bazdrum is offline   Reply With Quote
Old 08-28-2012, 02:15 PM   #2
WRX_20II
Member#: 298108
2011 Impreza WRX
Spark Silver Metallic
Looks good to me =) No knock, DAM at 1 and stable boost.
WRX_20II is offline   Reply With Quote
Old 08-28-2012, 02:35 PM   #3
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
The log looks good, but you are underboosting. Try the HWG map and take a log....Before I switched to the TP map the HWG map was giving me more boost then the regular map.
subiebosch is offline   Reply With Quote
Old 08-29-2012, 08:51 AM   #4
Cobb Tuning
Member#: 4803
Log looks good. As subiebosch stated, you are underboosting a bit - you can give the high wastegate (HWG) version of the map a try, which you can find in the maps section at cobbtuning.com. Use the AccessPORT Manager software to transfer the downloaded map to the AccessPORT and then reflash to the ECU. Get another log if you decide to go with the HWG map and we can see where your boost is at.
Bill
