Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 08-25-2012, 12:44 AM   #1076
Asharus
Member#: 276300
2011 WRX Ltd 5DR SWP
349awhp/366tq @19psi E85
I'm looking to get 18x8 +48 wheels and 235/40-18 tires on a 2011 WRX with stock suspension. Is this the correct fitment with no fender mods? If not, can you recommend the "proper" 18" fitment?
Asharus is offline   Reply With Quote
Old 08-25-2012, 12:54 AM   #1077
sc00by4life
Member#: 97135
Originally Posted by texascanuck
Assuming 18 inch tires ... here are some comparisons:
For 265/35-18 (approx width of tire is 265)
sidewall height = 92.8 mm
diameter = 642.7 mm
For 255/35-18 (approx width of tire is 255)
sidewall = 89.3 mm
diameter = 635.7 mm
Stock WRX is 235/45-17
sidewall = 105.8 mm
diameter = 643.3 mm
Stock Sti is 245/40-18
sidewall = 98 mm
diameter = 653.2 mm
Of course, as mentioned, different tire brands will have slightly varying specs for the same tire size.
He was talking about section width, not height .
Old 08-26-2012, 12:15 AM   #1078
silverex08
Member#: 299697
Ice Silver
Some of you guys seem to have a good sense on wheel and tire fitments. Next year i wanna plan on putting 17x9 +42 work emotion cr kai wheels on my 2012 wrx w/ a 255-40-17 dunlop direzza star spec tires. Question is will this be an ok fitment cause i dont want to do any fenders mods and i wont be doing any suspensions mods either. (possibly in the future put stiffer sways but not going to lower it, where i live it would be stupid haha)
If any of you can help that would be cool...thanks!
silverex08 is offline   Reply With Quote
Old 08-26-2012, 01:50 PM   #1079
texascanuck
Member#: 317045
2012 WRX Hatchback
yes,
265/35-18 will also be very close to stock tire diameter - but may require rolling.
texascanuck is offline   Reply With Quote
Old 08-26-2012, 02:05 PM   #1080
texascanuck
Member#: 317045
2012 WRX Hatchback
I want what you want too ... but...
I contacted Works wheels and there is no 17x9 with a +42. I was told that +38 is the closest offset they can make to what you want. Same goes for the new Ultimate wheels. Remember that we need the 5x100 and not the STi 5x114 PCD. Weight is about 20 lbs. WRX stock is about 22 lbs per wheel. Sales guy said the new wheels are about 0.5 lbs lighter but also around 20 lbs. ok.
Anyway, if you can get those specs then it will work (although the tire diameter will be slightly shorter - which is, IMHO, better for the WRX's acceleration). ODO will be slightly affected - ie. it will show more miles than what was actually driven - only slightly though.
Not sure if you need to mod the fenders though but it will be very close either way.
Let us know what you do - those wheels look great!
Old 08-28-2012, 02:58 PM   #1081
silverex08
Member#: 299697
Ice Silver
Originally Posted by casey oc
Wheel Specs: Work emotion cr Kai's 17x9 +44
Tire and Specs: Hankook sport k104 245/40
Suspension: stock for now. rce/bilstein combo soon. 20mm front, 15mm rear.
Fender Modification: will be rolling rear soon but atm no, no rubbing.
Wheel Spacers: none.
about a 15mm clearance between inner rim/tire and front strut. next tire will probably be 255/40 depending on if clearance changes with rce/bilstein kit. in the second pic the front wheel seems to stick out pretty far, looking at the car now it doesnt seem as much.
OK so i meant +44 offset not 42 in my last post. And it looks like 255 i might run into problems. What Casey posted up above in another thread is what I think i should be leaning towards. 17x9 +44 rim with 245/40/17 tire. Im trying to figure out the best way to avoid any fender mod on a new car and i dont want to lower it. Of course 255 would be a tad bit more aggressive and cooler but im looking for DD spec to not ruin my car.
What do you guys think about this set up?? Would it look dumb on my 2012 or work? If anyone has similar set up mind posting some pics? Thanks!
Old 08-28-2012, 03:03 PM   #1082
silverex08
Member#: 299697
Ice Silver
Work Emotion CR Kai
17x9 +44
no spacers
still no fender work
same tires as before, 245/40/17 Conti Extreme DW
i loved my gold wheels, and they were a lot lighter than these, but i think these look a little better and the size is more what i wanted in the long run. being a non-lip wheel, they look larger and have that nice concave look because of the width/offset. and still doesnt rub (that ive noticed).
Here is someone else on the forum with the same setup as casey. So it has to be possible i can get away with this.
Old 09-02-2012, 12:48 PM   #1083
Improbus
Member#: 278439
2011 WRX 4dr Stage2+
Just got the new shoes
Wheel Size: 18x9.5" +38
Wheel Style: ROTA Grid
Wheel Color: Titanium Chrome
Tire: Sumitomo HTR ZIII 245/40R18
Fender Mods: Rear Fenders rolled flat
Suspension BC BR Coilovers
Improbus is offline   Reply With Quote
Old 09-03-2012, 01:02 PM   #1084
redsandsilver26
Member#: 306032
Hey Noob Here i have a 08 Red wrx and i am looking a few different choices here one is a
18x8 +48 with a 225/40r18
or
17x8 +48 with a 215/45r17
both in bronze and they are rota torque which do you think would be ok with a stock suspension for now
redsandsilver26 is offline   Reply With Quote
Old 09-04-2012, 02:51 AM   #1085
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
So I will be getting my 18x9.5 +38 RPF1s in December (hopefully) and I'm well aware of the fact that I will be rolling the rear fenders. My question is, which tire size would be more of a comfortable ride. 255/40 or 265/35. I know the 40 on paper would be the wiser choice comfort wise, but will the 9.5 wide wheel stretch the 255 to the point where I should go with the 265/35. I plan on gettin Hankook Ventus V12s if that is to make a difference (I know some tires run wider depending on the brand). Thanks for any info that is thrown at me.
DurtyB is offline   Reply With Quote
Old 09-04-2012, 03:08 AM   #1086
sc00by4life
Member#: 97135
255 wont stretch much on a 9.5" wheel, also depends on what brand you get.
a 255/40 is TALL, you'd want a 255/35 - or the 265/35 since you are going to roll your rears anyways.
Old 09-04-2012, 03:11 AM   #1087
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Yeah I was curious of how tall the 40 would be. Thanks for the info!
Old 09-04-2012, 04:08 AM   #1088
Xer0 SiN
Member#: 290271
13 Tacoma TRD OR
Silver Streak Mica
real quick. i KNOW the offset is not "right" for our cars, but i have a line on these bbs that i can to get for an absolute steal. 18x8.5 +30 (bbs ch). anyway of making them fit with im guessing the oem sti tire size?
car in question 2011 wrx (stock suspension).
Xer0 SiN is offline   Reply With Quote
Old 09-04-2012, 04:24 AM   #1089
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Since the OEM STI wheels are 18x8.5, they should fit fine...
Old 09-04-2012, 04:33 AM   #1090
Xer0 SiN
Member#: 290271
13 Tacoma TRD OR
Silver Streak Mica
would it be equivalent to oem sti wheels with 25mm spacers? (18x8.5 +55 w/25mm spacers) vs (18x8.5 +30)
Old 09-04-2012, 04:43 AM   #1091
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
I think I misunderstood your first question. I thought you were just curious about the tires fitting on the wheels.
Not sure if the wheels will fit without rubbing. And the math looks correct on that equation but Im not 100% sure as Ive never messed with spacers.
Old 09-04-2012, 04:53 AM   #1092
Xer0 SiN
Member#: 290271
13 Tacoma TRD OR
Silver Streak Mica
lol, sorry its a weird question, i know. its worth a shot though, especially when you can get these wheels (still in the boxes) for HALF the price, cause your friend fell on hard times .
Old 09-04-2012, 06:59 PM   #1093
GrumpyPitbull
Member#: 313311
Check the bolt pattern. If the wheels for sale are 5-114, then they won't work. WRX uses 5-100.
Old 09-04-2012, 10:31 PM   #1094
Xer0 SiN
Member#: 290271
13 Tacoma TRD OR
Silver Streak Mica
it is indeed 5x100...everything sounds.good except the offset. just want to make sure before my car spontaneously combusts cause i was running the wrong offset LOL.
Old 09-04-2012, 10:49 PM   #1095
rkjunior
Member#: 112220
2011 WRX 5DR Premium
the car won't combust, just the bearings.. lol
rkjunior is offline   Reply With Quote
Old 09-05-2012, 11:54 AM   #1096
honestabe
Member#: 261730
2011 WRX hatch
I posted earlier, but my car was at stock height. I have lowered the car and it all sits very nicely! My initial concern was that a roll all around may not be enough, but it is.
Enkei NT-03s 18x19.5 +40
Michelin Pilot Super Sports 265/35/18
Feal 441 coilovers 8k/8k
Aligned by Mach V F -1.5, R -2.0, close to 0 toe
honestabe is offline   Reply With Quote
Old 09-05-2012, 11:34 PM   #1097
redsandsilver26
Member#: 306032
just ordered my 18x9e42 rota grids in hyper black with a 235/40/17
Old 09-06-2012, 06:15 AM   #1098
mpristave
Member#: 284761
If i'm going to run 245 star specs do I need a 17x8.5 or 9? I assume they would be too big for the stock wheel on '12 wrx?
Reason I ask is I am told they run wide, I will be using them for autocross.
mpristave is offline   Reply With Quote
Old 09-06-2012, 07:39 AM   #1099
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
18" wheels with 17" tires. Should be interesting fitment
Old 09-06-2012, 08:42 AM   #1100
krzyss
Member#: 8365
2013 Ford Focus SE
It must be this streched look.
Krzys
