Old 08-29-2012, 07:37 PM   #51
Wave17
Member#: 160205
2010 STi
I have the same problem as others with the traction and hill assist lights on as well as the dccd lock. I tried to go back and center the ring but still with no luck. Anything else i should try or suggestions on what to do? Any help is greatly appreciated!
Wave17 is offline   Reply With Quote
Old 09-17-2013, 03:31 AM   #52
SubieLover0008
Member#: 368577
2007 STI
black
i love rally sport direct yall are so helpful!
SubieLover0008 is offline   Reply With Quote
Old 09-17-2013, 06:36 PM   #53
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Thanks! Let us know if there is anything else we can help you with!
Rick
RallySport Direct is offline   Reply With Quote
Old 11-12-2013, 12:26 AM   #54
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Nice write-up and pics.
Is the car shown your first posts a 2008 STi?
As far as you know, this should work on 2008-2014 WRX/STi, 2008-2011 Impreza, and 2009-2013 Forester, right?
Do you know whether it will or won't work on 2012-up Impreza, 2012-up Crosstrek, and 2014-up Forester (which all switched to the "Legacy/Outback" style SWC buttons)?
Old 11-12-2013, 10:09 AM   #55
RallySport Direct
Member#: 33174
We are Open Late!
08 STi was used in this test, but this would be the same for all 08-14 STi and WRX models.
We have not done this install on the Forester or Legacy model so we cant say how similar or different they would be. But my gut feeling tells me they should not be much different.
Kirill
RallySportDirect.com
Old 02-02-2014, 06:58 PM   #56
GregOrz
Member#: 339148
Does the smaller wheel revolutionize the steering response/feel?
Or is this upgrade more for aesthetic reasons, and leg room?
GregOrz is offline   Reply With Quote
Old 02-03-2014, 10:17 AM   #57
RallySport Direct
Member#: 33174
We are Open Late!
As these wheels are smaller in size they do give a slight increase in feedback, and also being thicker grip they do feel much better when driving hard.
They are made out of better materials then stock, so it also gives the driver the feeling of a better driving experience. Its similar to what you find on on E46 M3 Comp packages or the MB Black Series cars, as it overall just improves the driving experience and feel of the interior.
Kirill
Old 12-16-2014, 02:41 PM   #58
salsa-king
Member#: 2028
2009 STi 330s
great write up.
how do you make sure you're lined up with the wheels and the steering wheel?
salsa-king is offline   Reply With Quote
Old 12-16-2014, 03:30 PM   #59
RallySport Direct
Member#: 33174
We are Open Late!
Originally Posted by salsa-king View Post
great write up.
When removing the old steering wheel. Make sure your old steering wheel is as close to a 12 o'clock, 6 o'clock position, with the wheels straight of course. When you line up the new steering wheel you need to try and get it as close as possible. The good thing is that if you're a little off, you can always take the steering wheel off and move it over a groove which ever way you need to move it.
Thanks,
Jeff
Old 12-16-2014, 04:39 PM   #60
bassler
Member#: 167544
'12 DGM STi sedan
'14 Audi S6, '16 XC90
Put some masking tape on both the column and the back part of the wheel. Draw a straight line on both pieces of tape with a straight edge. Do the swap and line up the lines.
And don't let the clock spring spin.
bassler is online now   Reply With Quote
Old 12-16-2014, 04:46 PM   #61
RallySport Direct
Member#: 33174
We are Open Late!
This as well.
Thanks for chiming in.
Regards,
Jeff
Old 12-16-2014, 09:34 PM   #62
bassler
Member#: 167544
'12 DGM STi sedan
I learned from experience. 1 spline to the right...
Old 03-15-2015, 02:12 PM   #63
Banhbaoo
Member#: 320922
2012 STi Sedan
I have no idea where to put this, but during my installation of the DAMD wheel, I now have the same problem as others with the traction and hill assist lights on as well as the dccd lock. I have re-calibrated the clock spring to center about 8 times and still with no luck. What did you do to fix the problem?
Banhbaoo is offline   Reply With Quote
Old 03-15-2015, 06:58 PM   #64
bassler
Member#: 167544
'12 DGM STi sedan
I think what you're seeing over on IWSTI is the best that we have to offer. That is why i asked you if your wheel was straight. My wheel was one spline off to the right on the 1st shot and my TCS was all pissed off when turning. Are you sure you are getting the wheel (and clock spring) completely in the right spot?
You could try driving it to confirm the car's front wheels are straight at whatever position the steering wheel is in and try my masking tape marking on the column and airbag. That will give you the best reference possible. reset the clock spring, put the wheel on straight and see where you're at.
Other than that try to get on the phone with IAG or any other shop that has experience with these issues.
Old 05-12-2015, 05:51 PM   #65
salsa-king
Member#: 2028
2009 STi 330s
I'm now getting a Damd steering wheel... now getting worried about the clock spring thingie!!
Old 10-28-2015, 05:53 AM   #66
Hell_0n_Wheelz
Member#: 432863
thats an awesome mod!
Hell_0n_Wheelz is offline   Reply With Quote
Old 10-28-2015, 05:57 PM   #67
RallySport Direct
Member#: 33174
We are Open Late!
completely adds a new feeling to the whole experience.
Mike
How To: 2008 WRX/STi Coilover Install RallySport Direct NASIOC Project Cars 40 08-11-2014 05:53 PM
How To: Change a power steering pump on WRX/STi Gamble_WRX Service & Maintenance 23 04-06-2013 08:22 AM
How To: Prova Air Oil Separator RallySport Direct NASIOC Project Cars 52 10-12-2010 10:26 AM
sparco steering wheel adapter wrx sti bootman Interior/Dressup/Audio & Security 1 07-07-2009 03:10 AM
Spec C MY06 steering wheel on WRX/STI 02.. How? alfo40 Interior & Exterior Modification 6 03-06-2006 10:14 AM
